Mounting 23Zero Awnings to Prinsu Cabrack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by in2seconds, Mar 24, 2022.
  1. Mar 24, 2022 at 1:58 PM
    in2seconds
    in2seconds [OP] Well-Known Member
    Edmonton, AB
    2021 TRD Offroad Premium
    Hi All - I have asked this question in the Outdoors subforum and have not gotten a reply yet (low traffic), so I'm redirecting to this subforum. Please delete this threads mods if cross posting is not allowed.
    I have a 3rd gen. Tacoma sporting a Prinsu cab rack, and I'm looking to put in 23Zero awnings (Peregrine 180R and Shower Enclosure) for this summer.
    I'm casting a wide net to ask how to approach mounting the awnings; the Peregrine 180R has a supplied stout L-bracket that unfortunately does not match the Prinsu cross bar channels, so I am wondering if I should get a separate Prinsu awning mounting bracket.
    To the 23Zero owners: how did you mount your awning?
  2. Mar 24, 2022 at 3:34 PM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    1/4” X 3/4” stainless carriage bolts. The heads slide into the 80/20 slots. Stainless washer, and nylon washer nut on the top of the bracket. Or you could use T-slot nuts, but I think the carriage bolts are easier to work with.
  3. Mar 24, 2022 at 3:45 PM
    in2seconds
    Edmonton, AB
    I suppose the problem with that is that only 2 or 3 of the slots in the L-bracket can be utilized. I can also drill through the cross bar but I want to avoid doing that as much as possible.
  4. Mar 24, 2022 at 5:26 PM
    Tacoma091919
    Tim
    2019 OR DCLB
    My awning is held on with L brackets. I’m using 3 of the possible 4 holes with carriage as mentioned above. The awning isn’t going anywhere, it is solid. Even if I hit a tree with it, the slotted aluminum rail that attaches the awning to the steel brackets would be the failure point. Do whatever makes you happy tho.
  5. Mar 24, 2022 at 5:28 PM
    in2seconds
    Edmonton, AB
    Do you mind if you can post pictures to give me a better idea?
  6. Mar 24, 2022 at 7:21 PM
    Kyle_
    Kyle_ A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
    Spacers below an L bracket so when it is raised up you can extend the L bracket past the top side of the rack.
    Gunshot-6A likes this.
  7. Aug 8, 2023 at 2:32 PM
    BBlack
    BBlack New Member
    Brandon
    17 Tacoma TRD Sport
    I know it's been a while but did you ever figure out how to mount it and what did you do. I'm looking into a 270 and had similar questions. Would you please post a picture. Thanks
  8. Aug 8, 2023 at 2:34 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    This is what I did. Raided all the 3/4in spacer tube things from the lowes hardware aisle and then used long 1/4x20 bolts through the t-slots.
  9. May 29, 2024 at 2:51 PM
    Heats13
    Heats13 Member
    Heather
    2020 TRD sport
    Diff breather 265/70R17 KO2 Rear air bags Brake controller RSI smartcap
    Could someone post a picture? I'm also trying to mount the 23zero 180R awning on a prinsu rack.
    Thanks!
