Motorcycle truck bed chock
Discussion in '1st Gen. Tacomas (1995-2004)' started by BlackSportD, Nov 15, 2020.
  1. Nov 15, 2020 at 12:41 PM
    BlackSportD
    BlackSportD [OP] Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Anyone rocking a motorcycle chock in their truck bed? Any brand and or install tips? I think @Speed Freek rocked one (I bought your bed liner so it's pre-drilled for one haha).
    I want to start going to track days and am looking at ways to avoid having a trailer.
  2. Nov 15, 2020 at 12:55 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
  3. Nov 15, 2020 at 1:03 PM
    BlackSportD
    Los Angeles
  4. Nov 15, 2020 at 4:33 PM
    BlackSportD
    Los Angeles
  5. Nov 15, 2020 at 9:01 PM
    ben20004x4
    ben20004x4 Well-Known Member
    TAMU
    2000 SR5 104k miles
    Looking for one for my Hodaka as well. Finally gonna get it running for some trails, and it's the one bike that fits in the bed
  6. Nov 15, 2020 at 9:20 PM
    sled dog
    sled dog Well-Known Member
    Your truck bed is a motorcycle chock. Roll it up a ramp on the right side of the bed, turn the wheel to the left once it's up, into the front left corner (behind the driver's side). The front wheel is chocked into the corner of the bed, put it on the side stand, it's on three points. Two straps to pull it forward and side to side, your done. Tailgate closes too. I did 12-15 trackdays a year with this setup, never an issue.
  7. Nov 15, 2020 at 10:07 PM
    BlackSportD
    Los Angeles
    You a bad mamba jamba. I like it.
    But usually this forum makes me spend money, I'm suspicious with this turn of events...
    Greenbean and 9mmMike like this.
  8. Nov 16, 2020 at 2:43 PM
    Xtremsiege2
    Xtremsiege2 Well-Known Member
    Norwalk CT
    21' LR Pro. Lots of fast bikes
    I loaded mine like below for the first time in February and didn't feel comfortable with the tailgate down. So played with a few options and decided to wedge the front wheel into the passenger right corner and lift the rear tire and wedge it on the driver side quarter panel/fender area and it keeps the bike standing without any straps..strap it down and that thing is not going anywhere. Must've done 7 track days this year and had zero movement and been transporting it recently to get fixed. Works like a charm, and you get more bed space for larger items like cooler, tent, canopy etc. see last photo.
    BlackSportD[OP] likes this.
  9. Nov 16, 2020 at 3:04 PM
    rtwbound
    rtwbound Well-Known Member
    uurx likes this.
  10. Nov 16, 2020 at 3:15 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I never liked the idea of carrying it with the kickstand down. I just tie mine in by the handlebars, compress the forks a little (not alot), and call it a day. If its gonna be bumpy, I'll run one over the back tire to keep the rear end planted.
    jeosbor1 and Bigal90 like this.
  11. Nov 17, 2020 at 10:31 PM
    BlackSportD
    Los Angeles
    What ramps you guys use? Wide and walk it up? Ride it up? Full send?
  12. Nov 18, 2020 at 5:59 AM
    sled dog
    Two ramps, throttle it up the right ramp, walk up beside it on the left. I've had my bike loaded and strapped by myself in less time than 3 guys loading a bike with a single ramp. You can use the ramps to weight your canopy too.
  13. Nov 18, 2020 at 6:04 AM
    sled dog
    Night before.
  14. Nov 18, 2020 at 6:18 AM
    0xDEADBEEF
    I have a set of the harbor freight ramps. I use a ratchet strap to the hitch to keep the one with the bike from sliding out.
    Also keep in mind the length of the ramps. If they're too short you can high center the bike.
  15. Nov 18, 2020 at 6:55 AM
    9mmMike
    9mmMike Well-Known Member
    Michael
    SE PA
    2019 TRD OR 4x4 DCLB - Cement
    Ha! You win the Internet today!
  16. Nov 18, 2020 at 7:06 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Be mindful of the side rails.
    Their load rating isn't very high. Tie downs on the floor are more secure.
    Hate to see a bike dumped if a side rail pulls out. Could make for serious seat foam pucker marks before you get stopped.
  17. Nov 18, 2020 at 11:36 AM
    BlackSportD
    Los Angeles
    That dual exhaust out the tail of R1s makes me feel things... tingly things. Move aside thots, I'm looking at something important.
    More seriously, I went into bikes knowing the Japanese sport bikes were all good, but the CBR600rr's tail exhaust really did it for me.
    Alright so looks like I should need dual ramps and should be good. I already have a crap ton of straps and even the handle bar chinga thing for straps.
    My truck is lifted so when I can't find dips/driveways I'll probably be pretty nervous. @0xDEADBEEF can you describe high center more? Like the center of gravity changes and balance gets whacky? Scrape/get stuck on bottom of bike? Dropping bike from elevation/breaks different stuff?
  18. Nov 18, 2020 at 11:41 AM
    0xDEADBEEF
    Scrape on the bottom and get stuck, which if it happens and you're not expecting it can put you and the bike on the ground.
    I once loaded up someone else's cruiser and it hung up on the edge of my tailgate. It wanted to fall over but I managed to keep it upright and then back it down again so I could go find a hill to load with.
  19. Nov 18, 2020 at 11:49 AM
    BlackSportD
    Los Angeles
    Oof, roger that.
    Hmmm, would hate to get ramps and find its not good enough when level. The CBR is on ohlins but stock height, truck has the OEM overload leaf removed but Wheelers 3 leaf AAL added. OEM leaf's are pretty tired + removed overload leaf + rear bumper weight = its not much much higher than stock (IMO, I don't have before/after measurements) so these vids of guys loading into full size trucks are probably right around my height as well. Guess we will see.
  20. Nov 18, 2020 at 10:08 PM
    BlackSportD
    Los Angeles
