Motorcycle in my 2017 TRD Off-road 5 ft bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nwemerys, Jan 6, 2018.
  1. Jan 6, 2018 at 7:22 PM
    Nwemerys
    Nwemerys [OP] Active Member
    I am looking for a way to safely and aesthetically extend the floor area in order to fit my KTM 690r dual sport in the bed. It barely, and I mean barely fits in with the tail gait down but any rearward movement at all and the bike could fall off; not ideal. I need another foot or so in order to be safe. Also wondering if the tailgate itself is robust enough to handle the weight.
    Any and all ideas are helpful, thanks.
    mgmdclb and Friedtacolover like this.
  2. Jan 6, 2018 at 7:29 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Whitetail Assassin likes this.
  3. Jan 6, 2018 at 7:32 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Get the bed extender? Isnt that exactly what its made for?
    Tocamo, ORtoCOTaco, remgu2000 and 7 others like this.
  4. Jan 6, 2018 at 7:36 PM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    Have you tried it sideways? Like so....
  5. Jan 6, 2018 at 7:38 PM
    Stefan_Ray
    Stefan_Ray Tacoma TRD Life
    Stefan
    Concord,North Carolina
    2021 TRD Pro
    Cooper STT Pro’s
    Angle it in the truck instead of just straight in. Driver corner to rear passenger corner.
  6. Jan 6, 2018 at 7:40 PM
    skier
    skier Well-Known Member
    Keith
    SW Colorado
    2016 red Tacoma DBSB TRD Sport manual
    I saw a 690 Enduro R in the back of a Honda Ridgeline yesterday. It was angled as above. At the local KTM shop
    verynearlypure and James_Bond like this.
  7. Jan 6, 2018 at 7:41 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Is the truck in your pic a 5 or 6 foot bed?
    Kilokato likes this.
  8. Jan 6, 2018 at 7:51 PM
    Friedtacolover
    Travis
    Ontario, Ca
    Thats a 5’ from what i googled
  9. Jan 6, 2018 at 7:52 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    By far the best option I’ve seen is to use a section of C channel (or U depending on where you come from). Extend it out passed the bed, sit the bike in that. weld some ears on the front of it so you can use the front bed bolts to hole it down. That is some custom work, but it’s by far the safest and best way to carry a bike in a short bed. Sideways is ok, but not for long distances, since the straps are uneven lengths and different at angles, plus tying the back is a pain. Personally I wouldn’t trust the Tacoma tailgate without reinforcement, (like the C channel), but there seem to be plenty who haven’t had any issue with the tailgate on a 3rd gen, Loads of 2nd gen failures with bikes though.
    Mr-Paul likes this.
  10. Jan 6, 2018 at 7:55 PM
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
  11. Jan 6, 2018 at 8:45 PM
    blackohio
    blackohio Well-Known Member
    Cliche Guevara
    white mudflap
    i've carried 2 Husky/ KTM 450/501's. Your 690 has a 59.7 wheelbase, my husaberg fe450 has a 58.7 wheelbase and fits with room to spare.
    Angle the front tire and wedge between tire well and back wall. That'll shorten it up a bit. As far as rearward movement with them strapped down there shouldnt be any. I also run a
    https://www.motosport.com/motogate-tail-gate
    at the rear across the entire tail to keep gear bags etc in. My old 350 and 501 in, see how the front wheel it turned, shortens bikes up alot and has no negative on stability.
  12. Jan 6, 2018 at 9:04 PM
    Spackler
    Spackler Well-Known Member
    http://www.bayareametalfab.com/Bed-Tie-Downs_p_21.html
  13. Jan 7, 2018 at 2:07 AM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Just got back from a dirtbike trip. Just drop the tailgate abd throw the bike in, should be more then enough room. Also could invest in a bed extender.
  14. Jan 7, 2018 at 9:05 AM
    Nwemerys
  15. Jan 7, 2018 at 9:06 AM
    Nwemerys
    Not applicable to my scenario since the rear wheel sits right on the end of the tailgate. Thant leaves the remaining 50% of the tire past the edge of the tailgate. The extender would interfere. Thanks though.
  16. Jan 7, 2018 at 9:11 AM
    Nwemerys
    And...the bike won’t fit at an angle with the 5’ bed since I have a Leitner Designs bedrock in it. Also, this is a dual sport 690 which is considerably longer wheelbase than a typical dirt bike. Throwing it in the back and driving isn’t safe.
    I had a Ridgeline prior to the Tacoma and it also had a 5’ bed. The difference, I discovered post purchase, is the Ridgeline tailgate is far more robust, and taller than the Tacoma’s. The result is a longer base to secure the bike once the tailgate is lowered.
  17. Jan 7, 2018 at 9:14 AM
    Nwemerys
  18. Jan 7, 2018 at 9:18 AM
    Nwemerys
    Interesting. I can see this working with a folding ramp turned upside down. I could load the bike using 2 ramps, 1 for walking, and then use the walking ramp to secure the bike, and remove the loading ramp for stowage. Really helpful, thanks a lot. Any suggestions as to where I could source c- channel?
  19. Jan 7, 2018 at 9:20 AM
    Nwemerys
    Unfortunately I can’t angle it quite enough with the bedrock for me to feel that it is securely loaded. I do like that Motorsport though...will purchase today..Thanks.
  20. Jan 7, 2018 at 9:23 AM
    Nwemerys
