Motiv 2320 filter wrench
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 099, Jun 12, 2024.
  1. Jun 12, 2024 at 8:03 AM
    099 [OP] Well-Known Member
    2022 White Tacoma Double Cab SR5
    I bought the above filter wrench for my oil changes. It works great, but too great. After taking the filter housing off, the canister is stuck in the wrench. I have to put the wrench in a vice to remove the canister. When I install the filter, I use a cheap wrench with so much play that it slides off after tightening the canister. I feel that if I use the Motiv, I'll never get if off the canister. Does anyone have this same issue? I tried to put oil in the wrench before removal, but that didn't help. Any suggestions?
  2. Jun 12, 2024 at 10:36 AM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    When did you buy this filter wrench? I ask because it appears they have changed the design since I bought mine according to Amazon.
    Amazon.com: Motivx Tools Oil Filter Wrench for Toyota Camry, Tundra, Tacoma, 4Runner, RAV4 and More - 64mm 14 Flute Precision CNC Machined Aluminum Oil Filter Removal Tool : Automotive
    If yours looks like the picture of the current product instead of the bottom of the second picture showing the discontinued product I can understand your dilemma. I would not use it either.
    My old style works fine.
    IrishRed likes this.
  3. Jun 12, 2024 at 10:42 AM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    I’ve used mine once and I don’t remember having that problem
  4. Jun 12, 2024 at 10:52 AM
    Motorman1961
    Motorman1961 Active Member
    2023 Barcelona TRD Sport 4x4 dbl cab
    I've only had my truck long enough to do 2 oil changes , but the Motiv wrench also did what you are describing on both changes. I found that you can either hold the filter housing in your hand and turn the Motive wrench backward, (loosen direction), and it will slide off with some wiggling. Or- Leave it on the housing, and after the new filter element has been installed and torqued to the 18 ft lbs, -same thing- a little turn of the wrench in the loosen direction and it slides off.
    It seems to have a very close tolerance fit.
  5. Jun 12, 2024 at 10:54 AM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Oil film on the surface of the filter creates a mild "suction". Tap at the tool edge and work it off, like you would with bolts and nuts on a socket. Then use a degreaser on the filter housing and the tool interior to remove that problem
    Gunshot-6A and gr8-wrx like this.
  6. Jun 12, 2024 at 11:59 AM
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO2s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    I have the older discontinued MotivX wrench and have never encountered this problem.
    gr8-wrx and RIX TUX like this.
  7. Jun 12, 2024 at 12:19 PM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    I have one that I bought in late ‘23. It does get stuck on the housing when I remove it from the truck, but it comes back off when torquing it back on with a new filter element. The only real problem is that I have to install the drain cover with the housing installed, which is definitely trickier than doing on the bench.
  8. Jun 12, 2024 at 12:34 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    It's a tight fitting tool. A couple of smacks with soft hammer and it will come off.
    MDA57 and RIX TUX like this.
  9. Jun 12, 2024 at 1:07 PM
    Josephray70
    Josephray70 Well-Known Member
    Joseph
    Grand Rapids, MI
    2017 Toyota Tacoma limited
    Bilstein 6112/5100 at 2” (6/8 circlip, 3/8” top spacer, sway bar drop bracket, YotaWerx Black Hawk 2.0 tune, Borla exhaust, Freedom Off-Road UCA’s, Alphrex Luxx Series smoked taillights, Westin bull bar, 265/65r18 Cooper Rugged Trek tires, 18x9 Anthem Off-Road wheels -12 offset, 4.5 backspace.
  10. Jun 12, 2024 at 2:04 PM
    I do have the newer one. Thanks for all the replies and suggestions. I'm not due for a few more thousands miles and I'll try something different.
  11. Jun 12, 2024 at 2:12 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    I have had the same issues. Cleared up this last change. Just not so tight. I was worried about my canister so I bought a backup spare, just happens to be the aluminum one.
  12. Jun 12, 2024 at 2:15 PM
    Josephray70
    Joseph
    Grand Rapids, MI
    I would also get your crush washers from Toyota dealership. I ordered some from Amazon before and they sent the wrong sizes. Whatever you do do not use your old washers.
  13. Jun 12, 2024 at 2:16 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    pic of old one and new one? difference?
  14. Jun 12, 2024 at 2:18 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    Mine was purchased in 22 and it is a snug fit. I've learned to just use it to loosen the canister so while there are still plenty of threads engaged I'm able to unstick the wrench from the canister vs trying to fight it off while the canister is completely free.
    RIX TUX likes this.
  15. Jun 12, 2024 at 2:23 PM
    RichochetRabbit
    The Motivx grips the filter housing at the strongest point ... not the side-pinching wrenches built for solid filters instead of the filter housing. But if you insist ... good luck.
    BUZZCUT and RIX TUX like this.
  16. Jun 13, 2024 at 7:48 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    If you are changing the filter with the engine hot this will happen due to the plastic housing expanding.
    Taco_mike73 likes this.
  17. Jun 13, 2024 at 7:49 AM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    mine gets lodged in there as well, I hate that thing
  18. Jun 14, 2024 at 11:07 PM
    Toycoma2021
  19. Jun 15, 2024 at 2:37 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
  20. Jun 15, 2024 at 4:23 AM
    Josephray70
    Joseph
    Grand Rapids, MI
    I torque everything to spec so no issues
