Most reliable water pump brand?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bodhi armor, Jul 5, 2020.
  1. Jul 5, 2020 at 1:59 PM
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    Hey TW
    I need to replace my water pump and timing belt because my water pump was leaking antifreeze. I was told there’s a better than not chance my timing belt was also damaged.
    I replace all that stuff an 80,000 miles ago. I don’t know what brand it was because the mechanic that worked on it ordered the parts, but I would expect something as simple as a water pump to last way longer than 80k!
    What brand should I order this time to ensure longevity of service?
    Should I pay the extra $$ for Aisin, or is there a super reliable replacement out there that isn’t so pricey??
    I’m hoping to order a full kit with the pump, belt, and everything else included but I’m not sure which one to go with.
    Also, is there anything else I should replace while it’s all disassembled to avoid future repairs?
    My truck is an 02’ sr5 4door auto 4wd 3.4L With 280,000 mi.
    Thanks in advance for any help!
    Jimmyrace likes this.
  2. Jul 5, 2020 at 2:13 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Nobody here is going to have that kind of data. Get the Aisin.
    Jimmyrace and machotaco91 like this.
  3. Jul 5, 2020 at 2:23 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    I bought a water pump from the dealer for an 06 2.7 and it was about $80. It's not very much for a good quality car part when a $30 water pump might not last and leave you with a tow bill and a repair bill. Buy once, cry once.
  4. Jul 5, 2020 at 2:31 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    You are correct in thinking a water pump SHOULD last longer than 80k miles. If that was an OEM pump, I would consider it an anomoly, many folks get 200k miles without leaks from an OEM water pump, Aisin makes the water pump for Toyota.
    If it's an aftermarket, non Aisin made, water pump than I would consider 80k miles par for the course or even better than par for the course.
    There are couple sellers on eBay that put together the full OEM parts kits or if not labeled 'Toyota' OEM, the parts are made by the same manufacturer that makes it for Toyota.
    'Aircabinman' is a seller name that comes to mind from here on the TW.
    DO NOT LET YOUR 'MECHANIC' INSTALL AFTERMARKET PARTS AGAIN ON YOUR TACOMA, especially engine components. Some things the risk is okay to take on aftermarket parts. Engine timing kits are not one of those things
  5. Jul 5, 2020 at 2:40 PM
    bodhi armor
    Joshua
    East TX
    Excellent info! Thank you
    I always try to replace engine and drivetrain parts with Toyota original. However due to Covid BS money is tight.
    What else should be replaced while doing this?
  6. Jul 5, 2020 at 2:44 PM
    cruiserguy
    Elijah
    SEKS
    You don't need new accessory belts right? You did those belts 80k miles ago? Shoot, if he installed a cheapy water pump I wonder if the other stuff was similar as well? Hopefully not.
    Do you have any oil leaks at all? Reason I ask is the cam seals and crank seal is most accessible to replace while one is doing the timing belt/water pump job.
  7. Jul 5, 2020 at 4:09 PM
    cruiserguy
    Elijah
    SEKS
    enil01, Jimmyrace and jbrandt like this.
  8. Jul 5, 2020 at 5:19 PM
    bodhi armor
    Joshua
    East TX
    I do have a small oil leak. I may look into doing that also.
    Thanks!
  9. Jul 5, 2020 at 10:21 PM
    04tacoma trd
    04tacoma trd Well-Known Member
    Watch the Timmy the Toyotaman video on the timing belt replacement and what I did is also replace everything in there, including the seals he shows you how to do.
  10. Jul 6, 2020 at 10:21 AM
    bodhi armor
    Joshua
    East TX
  11. Jul 6, 2020 at 10:22 AM
    bodhi armor
    Joshua
    East TX
    I watched that video and it is very detailed and in depth.
    Thanks a ton for the tip!
    It may be a little beyond my skill set, but I may attempt it with my father in law.
  12. Jul 6, 2020 at 10:26 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    +1 for the Aircabinman kit. I generally advise against buying critical car parts from Amazon/ebay, but his kits are the real deal; all OEM. I got that kit when I did my timing belt a few years back.
  13. Jul 7, 2020 at 9:53 AM
    bodhi armor
    Joshua
    East TX
    How much $$ should I expect to pay a mechanic shop to install that kit?
  14. Jul 7, 2020 at 10:11 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Depends on shop rates where you live. Here in Socal a timing belt job (labor only) can go anywhere from $500 - $1000+ (dealer price). Add another $200 - 300 for a kit if you're getting an OEM one.
  15. Jul 7, 2020 at 10:57 AM
    bodhi armor
    Joshua
    East TX
    Good to know!
    I ordered his full oem kit for $300
    Eagerly awaiting its arrival
    Jimmyrace and jbrandt[QUOTED] like this.
  16. Jul 7, 2020 at 9:15 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I'd recommend new from Toyota. I have 414,000 miles on my original water pump.
  17. Jul 15, 2020 at 11:31 AM
    Jimmyrace
    Jimmyrace Well-Known Member
    JR
    Louisville, KY
    Betty '03 Taco MTM Xtra-cab DLX 5VZFE
    OME struts / springs / leaf pkg :: SPC upper A ::
    Probs what I'll be doing in another week as well - let us know how goes!
  18. Jul 16, 2020 at 12:54 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Price, Quality, 90% of the time you get to pick just one. Go OEM. Aircabinman is who I used and I filled in some missing parts I wanted to replace from Toyota. Idler pulleys I think and something else...been a while.
    I paid $700 for the install at Toyota. I would have done it myself but she's my daily. I didn't have the time for all that.
  19. Jul 16, 2020 at 11:06 AM
    Jimmyrace
    JR
    Louisville, KY
    not a bad price for labor. she was my dd, weekend rec for quite some time - I def neglected this part of the operations for too long. I been giving her some good tlc past buncha mo's, knew I needed to inspect this area of mechanical, but didn't think it had already gone (probs b/c I did not change the fluid at least once in past .... well, many yrs lol. So yeah, I went w/ the Aircabinman set-up on ebay, & since I am not working at present (semi-retired by choice (jokingly)) I will be doing it this time around ... and Finally have a garage in which to do it (if I could just get rid of the in-law's temp storage sooner that'd be even better lol)
  20. Jul 16, 2020 at 12:03 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    When you can take it to the dealer and it costs under $1000 to replace timing belt, water pump, thermostat and some seals. OEM for the Win
    JJ04TACO and Jimmyrace like this.
