Most Powerful Fog Lamp
Discussion in 'Lighting' started by grubburg, Jul 18, 2019.
  1. Jul 18, 2019 at 7:00 PM
    grubburg
    grubburg [OP] Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    Who makes the most powerful fog lamp light?
    I don't plan to ever use it on the road. I want basically 4x4 off road lights, but mounted in the fog lamp location so it's easy plug-n-play and not sticking out where someone can steal it.
    I'm looking for some straight POWER.
    These are 3,150 lumens at $365
    https://www.bajadesigns.com/products/Toyota-Tacoma-Tundra-4Runner-Squadron-Sport-WC.asp
    These are ? lumens and $347
    These are (?) lumens and $175
    https://caliraisedled.com/collectio...a-tacoma-led-fog-light-pod-replacements-combo
    Thanks guys.
  2. Jul 18, 2019 at 7:02 PM
    mcm808
    mcm808 Well-Known Member
    Micah
    Kane’ohe, O’ahu
    3rd gen
    power as in lumens?
  3. Jul 18, 2019 at 7:03 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    crashnburn80 and grubburg[OP] like this.
  4. Jul 18, 2019 at 7:34 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    if you are just after the brightest and wont use them on road then look at the squadron pros from baja designs. stupid bright
    vicali, Beretta4x4 and crashnburn80 like this.
  5. Jul 18, 2019 at 7:42 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This for actual fog lights.
    If looking for crazy bright in a non-fog pattern, with no cut offs and to be used off road/when nobody else is around only, the Squadron Pros. 4900 raw lumens:
    https://www.bajadesigns.com/products/Squadron-Pro-LED-Light-Black.asp
    elduder[QUOTED] likes this.
  6. Jul 18, 2019 at 7:44 PM
    grubburg
    2019 TRD OR MT
    Those are 4900 each??? Can you run em in the fog housing or ditch only? Those are sweet!!!
  7. Jul 18, 2019 at 7:46 PM
    paranoid56
    San Diego
    14 double cab taco
    they have kits to mount in the factory fog position. but the higher you can mount them the better normally. if you would like a set just let me know.
    Shane
    crashnburn80 likes this.
  8. Jul 18, 2019 at 7:49 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    4900 raw lumens, not actual, but yes. I’ve not heard of anyone having issues running them in the fog spot, but they will certainly run hot. I would not recommend a wide cornering light in the ditch location as you will get a flood of hood glare, so choose your location and pattern together.
  9. Jul 19, 2019 at 12:22 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Pros with spot lenses for ridiculous light.
    I use Squadron sports in the fog pockets with combo lenses and then are plenty bright. You will need to relay and rewire them because driving lights function completely different than the stock fog harness.
    grubburg[OP] and crashnburn80 like this.
  10. Jul 22, 2019 at 10:46 AM
    Zachs_Tacomer
    Zachs_Tacomer Well-Known Member
    Zach
    2017 TRD Off Road 4x4
    King Coils W/ adjustable reservoir, Icon UCA, Icon air bump stops, 16" Method NV, 285/75/16 Toyo AT2
    I just bout SAE fogs by Baja designs for my 3rd gen! So far I’m impressed! Much wider light output than stock. Haven’t tested them on a fully dark road yet.
    grubburg[OP] likes this.
