Most frequently used socket sizes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, May 11, 2015.
  1. May 11, 2015 at 9:18 AM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    As my Tacoma general preparedness OCD is advancing, I am trying to include the most frequently used sockets in my mobile tool kit.
    From having completed numerous repairs on my own, so far I can recollect mostly using 10, 12, and 14 mm sockets. Do you think most roadside and away from garage kind of emergencies could be attended to with those three sizes if I had each in 1/4 and 3/8" drive socket versions and had respective ratchets/drivers in my kit? I know that the crank nut is 22 mm on a 1/2" driver but that's an outlier in terms of size.
  2. May 11, 2015 at 9:25 AM
    Telkins88
    Telkins88 Well-Known Member
    Ohio
    2021 TRD Sport 4x4 Premium
    Goodyear Ultraterrain AT 265/70r17 1” front and rear lift
    17mm and 19mm
  3. May 11, 2015 at 9:28 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    10, 12, 14, 17, 19 are pretty much the most commonly needed sizes on the truck. Can do alot of things with just those 5 sockets. I have like a 27 piece socket set and I can do just about anything on the truck with that, I just have a few extra individual sockets I bought as needed to fill in the gaps... and honestly thinking about it most of those sockets were purchased for jobs other than the taco.
  4. May 11, 2015 at 9:29 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    if you offroad quite a bit, i would recommend getting all the sockets needed to replace a cv
  5. May 11, 2015 at 9:30 AM
    foampile
    Mid-Atlantic
    which would those be ?
  6. May 11, 2015 at 9:30 AM
    foampile
    Mid-Atlantic
    what are those used for ? i've never had to use them.
  7. May 11, 2015 at 9:31 AM
    foampile
    Mid-Atlantic
    That's great, I'm trying to carry only the most essential, for space conservation and minimalism.
  8. May 11, 2015 at 9:35 AM
    Telkins88
    Ohio
    Upper control arm bolt, lower shock mount, lower ball joint bolts on the spindle,cam bolts,and lug nuts are just a few that are 19mm on my truck.
    foampile[OP] likes this.
  9. May 11, 2015 at 9:37 AM
    ramonortiz55
    Ramon
    Texas
    stock
    :notsure:
    i offroad in my 4runner. not the tacoma.
  10. May 11, 2015 at 9:54 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Start looking at what may commonly fail and leave you stranded, and you'll quickly realize you need a stockpile of parts and fluids more than a just a bench of sockets:
    Radiator hoses and hose clamps
    Wiper blades
    Headlight bulbs
    Belts
    Fuses
    Vacuum hoses and clamps
    CV split boot repair kit
    Generic tire plug kit
    Brake line splice kit, fluid, and bleeder tools
    Tire pump
    Battery jump pack
    Along with all the angled- and straight pliers, screw drivers, breaker bars, socket extensions... necessary to do the work. The list gets pretty daunting, and is just for on-road use. For daily driving in the city (where I'm always within 10 miles of a Toyota dealer), it's better to just get a AAA membership and leave the stuff at home. For wheeling you'd want to bring your entire tool set, spare CV driveshafts, hubs, tie rods...
  11. May 11, 2015 at 10:01 AM
    lemons
    lemons LOCO 4X4
    Virginia
    07 TRD DC Offroad 4X4
    Icon coil overs W/King 14 inch 700lb springs and super bump bump stops, Allpro Expo leaf springs, Allpro Ubolt kit W/timbren Bump stops, Dif Drop Kit, Magnaflow Cat-Back Exhaust, Badges painted Rust-Oleum bed liner, Color Matched TRD Sport Grill W/Grille Craft Insert, TRD seat covers, Weather Tech Floor Mats, Flyzeye's , fog light anytime mod, ABS Off mod, ATO skid plates, ATO rear H/C bumper, BAMF sliders w/kick out, CBI front bumper, Engo 10000lb winch, Rigid D2 foglights, Piaa 510 fog lights, cobra CB w/firestix antenna, AFE snorkel
    35MM for the hub nut, Needle nose pliers for cotter pin, large flat tip for the dust cap, Pry bar for popping out the CV from the diff, basic 1/2inch drive sockets and wrench's (already mentioned) as well as gear oil. And maybe some 550 cord or rope to hold the spindle out of the way while you pull the CV.
    foampile[QUOTED][OP] likes this.
  12. May 11, 2015 at 10:04 AM
    jrg24
    jrg24 Well-Known Member
    You must have been reading my mind. I want to do the same thing. One suggestion I would have is to include wrenches as well. Both have their benefits in different situations.
  13. May 11, 2015 at 10:09 AM
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    8, 10, 12, 14, 17, 19, 21mm
  14. May 11, 2015 at 10:52 AM
    foampile
    Mid-Atlantic
    what are the 8 and 21 for? the crank nut is 22
  15. May 11, 2015 at 11:28 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    21 for lugs.... 8 for various things.
    Just carry a set that goes from like 8-24 and a big mexican socket set (crescent wrench) and you will be good.
  16. May 11, 2015 at 11:41 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  17. May 11, 2015 at 11:42 AM
    Wile
    Tim
    New Mexico
    8 is used for various interior areas under the dash. Stereo mounts being one of them. I think it is used for the battery terminal bolts too.
  18. May 11, 2015 at 11:47 AM
    plurpimpin
    PDX
    I like my deep well 19mm socket for lugs
  19. May 11, 2015 at 11:58 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    SMKYTXN and lemons like this.
  20. May 11, 2015 at 5:04 PM
    lemons
    lemons LOCO 4X4
    Virginia
    ^^^dig it
