Morimoto D2S retrofit with Apollo Shrouds (lots of really big pics)
Discussion in 'Lighting' started by tooblutacoma06, Oct 16, 2010.
  1. Oct 16, 2010 at 8:20 PM
    tooblutacoma06
    tooblutacoma06 [OP] Member
    Kellon
    Houston
    I'm a light fanatic so I found it necessary to retrofit my lights. After quite a bit of searching and debating (mainly with myself) I decided to go the following route:
    Ballasts: cheap ballasts I had from my PnP kit. Will upgrade soon.
    Bulbs: Phillips 85122+ D2S
    Bulb adapters: Amp to D2S
    Projectors: Morimoto Minis D2S
    Shrouds: Apollo
    I'd have to say, if you plan on retrofitting and want an easy location to get all your parts, head to The Retrofit Source. They have all the stuff you need and are very helpfull. Call them and talk to Matt if you need information.
    Here's a little about the process:
    With these particular projectors, the install is very simple. Follow the BHLM write-up in order to get the lights apart. The projectors slide into the pre-existing opening in the reflector bowl and clamp to it via a nut that threads onto the projector.
    The projectors come with a three-pronged alignment tab as seen on the 9003 bulbs. That tab then aligns with a slot on the projector so that the projector gets mounted in the correct rotational orientation. As simple as this system is, there is some slop in the rotation so keep that in mind.
    The solenoid wires ran easily through where the bulb shield was originally attached. I did, however have some cheap OEM "replacement" lights that my body shop installed so the shields were attached via a nut and threads on the shield, so there was already a round hole there. I simply snipped the connector off the solenoid wires, fed it through and then soldered the connector back on. Easy as pie.
    BE CAREFUL hogging down on the nut that clamps the projector to the bowl. I used a set of channel locks to aid in my grip which worked well. Until the nut split. They are cheap casted nuts that have terrible threads, so be gentle. I'm going to contact TRS and see if they can send me a new nut.
    After the projectors were mounted, it was time to move onto fitting the shrouds. Here's a shot of just the projectors mounted:
    The shrouds weren't as hard to fit as I anticipated. Once the projectors were mounted, I set the shrouds in place, and marked where the shrouds would come into contact with the bowl. I found it was easy to remove the necessary material on the bottom rim of the shroud with my orbital sander instead of my RotoZip. I did do a little trimming on the inner lips of the shrouds with the RotoZip in order to clear the projector's 4 fastners. It was hard to get good pictures of the shroud trimming but here's some attempts. There wasn't much to take off.
    I mounted the shrouds with epoxy. I used the projector's 4 fastners (as seen in the picutre above) as attachment points and I put a bead around the black plastic of the projector. Once it cured, the shrouds are on there no doubt. Very solid.
    I modified the rubber boot to work with the D2S adapters. Once the adapters were pushed into the boots, and installed on the bulb, I ran a bead of silicone around the D2S adapters to seal up any gaps between them and the rubber.
    While I had everything apart, I also painted the bezels with Krylon Fusion satin black. I followed Viet2100's write up and preburned them after the paint was dried up. This will gloss them up a little but gives a nice look.
    It was time to seal them up. Following Viet's write up, I removed all the old adhesive from the light in order to make room for 3M Window-Weld. My masterpiece:
    With the window-weld installed:
    Once all was said and done, I think they came out awesome. I'm very pleased with the look.
    Before:
    After:
    Here's a PRE-AIMING picture of the cut-off. I'll have better pictures to add later:
    Thanks for reading through it all!
    Let me know what you think!
    PacoPreRunner likes this.
  2. Oct 16, 2010 at 8:46 PM
    IamTacO
    IamTacO red balls got me!
    adam
    QC az
    01 Prerunner SR5 TRD-Offroad
    4x2 Prerunner. Hankook Dynapro ATM rf10 265-65-16, e-locker FTW! Morimoto d2s bi-xenon HID projectors, Philips 85122+ 4300K, Cobra 75 w/ 3' firefly, Kenwood KDC-MP342U w/ SIRIUS, Line-x bed liner, 4' coretrax(black)
    good job, they look awesome
  3. Oct 16, 2010 at 9:04 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Looks great! I like that you don't have to cut and modify the headlight for the install, that makes it much nicer I am sure (I wish I could find some like that for my dodge) I will definitely have to use these on Sami's truck if we ever do the retro on hers
  4. Oct 16, 2010 at 9:13 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Sweet man! That made your front end 10X better looking. I'm planning to do a retro with my lights too, but I'm going with FX-R projectors. Good info from your write-up though!
  5. Oct 16, 2010 at 9:20 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    I love it. Just did not have time to do it.
    How hard to seperate the housing? How many degree and take how long?
  6. Oct 16, 2010 at 9:20 PM
    tooblutacoma06
    Kellon
    Houston
    Thanks guys!
    That was my great debate. I was set on the FX-R projectors before I ordered the Morimotos. It's not that I lack the ability or drive to do the FX-Rs, but I talked to Matt with his information and just the ease of the installation, I decided that they would be great for a first time retro. Perhaps if these don't work out in the long run, I will upgrade to TLs. But I'm loving them so far!
  7. Oct 16, 2010 at 9:24 PM
    tooblutacoma06
    Kellon
    Houston
    Thanks!
    I followed this write up to pull the lights apart: BHLM Write-Up
    This was my third time pulling lights apart. Mine were difficult this time because they were cheapo OEM "replacement" lights that had really cheap plastic. Everytime I would try and pry on the warm plastic with a screwdriver it would just bend out of the way. But OEM headlights and most other aftermarket headlights are easy to pull apart. Just follow that link and you will be fine!
  8. Oct 16, 2010 at 9:32 PM
    ppham444
    Phuong
    Portland, OR
    Well, first time retros are always the hardest. This will be my second retro. My first was TSX projectors inside a 96 Tacoma headlight. Yeah, remember those sealed-beams style? lol It was pretty tough getting the TSX to fit, but I got them in. Hmm...hold up, I might have some pics of it.....
    IMG_0663_a6e99d6b66ca6f1da613b9775d7b33eeaad75e6e.jpgIMG_0674_c350dc917eaacbf73857e416622a094bb22f36b7.jpg
  9. Oct 16, 2010 at 9:44 PM
    cummins6speed
    What makes the FX-R's better than these?
  10. Oct 16, 2010 at 9:46 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I want
  11. Oct 16, 2010 at 9:49 PM
    tooblutacoma06
    Kellon
    Houston
    From what I understand, there isn't too much difference in the output. I was told the FX-Rs would produce a wider throw though. They are just more involved to install.
  12. Oct 16, 2010 at 9:51 PM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    is this do able for someone that doesnt have experience with lighting?
  13. Oct 16, 2010 at 10:11 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    2017 Tacoma Dbl cab long bed.
    Hood Strusts, remote Start, truck came with Leveling kit and wheels.
    VERY NICE! I have seen theses on there site a few days ago.. I am def now going to get these..
  14. Oct 16, 2010 at 10:17 PM
    tooblutacoma06
    Kellon
    Houston
    I would say yes. Once you get all the parts (easy to do with a phone call to TRS), it's basically following some directions for taking the lights apart and having some tools (rotary tool, sander) available. I can help answer some questions to if you decide to go this route.
  15. Oct 16, 2010 at 10:25 PM
    schiz94
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    ok sweet man. i am almost positive that at the beginning of next year i am going to tackle this and BHLM my headlights. so for the Morimoto Mini stage III(d2s) with these components-
    Ballasts:Morimoto 3five
    Bulbs:Morimoto 4300k D2S
    CCFL Angel Eyes: None
    i could just open the headlights, cut the shrouds a little bit and set it up like HIDs and i would be good to go?
    Projectors: Morimoto bi-xenon
    Shrouds: Gatling
    Wire Harness:H4 bi-xenon
  16. Oct 16, 2010 at 10:52 PM
    tooblutacoma06
    Kellon
    Houston
    Yup! That'll do!
  17. Oct 16, 2010 at 10:59 PM
    schiz94
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    do you have any suggestions for like troubleshooting.
  18. Oct 17, 2010 at 4:04 AM
    IamTacO
    adam
    QC az
    pretty much sums it up
  19. Oct 17, 2010 at 8:19 AM
    MC1983
    MC1983 Well-Known Member
    Mark
    Indianapolis, IN
    2005 DCLB
    Looks really good. I am also deciding between the FX-R and the miniD2s. I am leaning toward the miniD2s as well just for ease and convenience. Yeah, they aren't as wide, but the FX-R also does not give much foreground so it might not work as well in a lifted truck. I figure its not that much difference between the two, they are both much better than stock. Would love to see in-truck shots of the output once they get aimed.
  20. Oct 17, 2010 at 11:43 AM
    DonOmar
    DonOmar Member
    Omar
    Fontana, Ca.
    Black 02' PreRunner
    Duuude... sweet set-up... anyone want to set mine up on my 02... PM me and name your price. I WANT THAT!
