Momentary rocker switch for lower center console
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WalkinTaco, Dec 2, 2018.
  1. Dec 2, 2018 at 10:42 AM
    WalkinTaco
    WalkinTaco [OP] Well-Known Member
    2018 TRD OR M/T
    Does anyone make a momentary rocker switch for our lower center console?
    Here (borrowed picture):
    I want to mount in cab winch controls there (I have 3 blanks there - MT) and CH4x4 has a power switch that fits (https://www.ch4x4.com/product/ch4x4-toyota-small-push-switch-winch-power-symbol/).
    But I haven't been able to find a matching momentary rocker for the in/out controls. CH4x4 has one for the larger switch panel (https://www.ch4x4.com/product/ch4x4-rocker-switch-winch-in-out-symbol/). But I'm concerned the 2" tall outer diameter will be a tight fit there.
    As other options I've been toying with the feasibility of re-purposing a Toyota rear power window switch (seen on the right) as they have been confirmed to physically fit in the normal switch "hole" though I'd don't want it to have identical labeling to the rear window... or just mounting the in/out in another location like the overhead console.
    Has anyone put winch controls there? Maybe it's a bad idea?
  2. Jul 30, 2019 at 7:00 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Did you ever figure anything out? I'm in the same boat.
  3. Jul 31, 2019 at 9:13 AM
    derelique
    derelique Well-Known Member
    Derek
    2004 Tacoma
    I don't think they make rocker switches for that size switch unfortunately. Might need to go with the larger ones in this area like the picture below.
  4. Jul 31, 2019 at 9:15 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Nothing that I've found yet. That area over near the steering wheel is full. My Switch-Pro panel is where the cubby used to be and the last blank on the bottom is taken up by something else.
  5. Jul 31, 2019 at 9:21 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    A bit off topic, how are your air lockers working? Any seal leaks?
  6. Jul 31, 2019 at 9:23 AM
    derelique
    Derek
    2004 Tacoma
    Great so far, no leaks. I've used the rear 3 times and the front just once since installed. Ran out of snow just after I was able to get the front installed.
  7. Jul 31, 2019 at 9:35 AM
    Grossomotto
    2017 4WDV6LB6MT
    Nice, the word is run less than 100 psi so you don’t blow the seals
