Mod to reduce turning radius?
Discussion in '4th Gen. Tacomas (2024+)' started by BearWithMe, Sep 29, 2024.
  1. Sep 29, 2024 at 1:12 PM
    BearWithMe
    BearWithMe [OP] Well-Known Member
    Four Corners
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    I had a 3rd gen that turned tight as heck. The new 4th gen is forcing me to make 3-point turns on tight switchbacks on trails. I wonder if the turn-stop on the knuckle could be shaved down to allow a few more degrees of pivot? Hoping the steering rack and pinion has a few extra teeth at both ends...
    Thoughts and prayers?
  2. Sep 29, 2024 at 1:15 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Fast1, fiftysix, Delta09 and 10 others like this.
  3. Sep 29, 2024 at 2:38 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    bad idea … it’s a bigger truck .. it’s not going to get better turning radius
    Cows Have Claws and Stevie17 like this.
  4. Sep 29, 2024 at 2:43 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    You’re probably limited to the same amount of wheel turning angle as you had in the 3G. The difference being now your wheelbase is 6” longer.
    It’s been a while since I looked but are there even steering stops on the knuckle? I thought they’re built into the rack. Anywho, I would not mess with it for fear of over-traveling a component further than it wants to go.
  5. Sep 29, 2024 at 6:33 PM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    The distance between the axles was increased to gain a greater approach and departure angle.
  6. Sep 29, 2024 at 6:39 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    In addition to stretched wheelbase -- the 4th gen Jackoma has a LONGER wheelbase than a 2nd gen single cab long bed TUNDRA -- doesn't the 4th gen Jackoma also have a WIDER track width?
  7. Sep 29, 2024 at 6:43 PM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2021 4runner "Luna" 2023 Solar Octane MT "Solaris"
    Ouch bro... If you are ever in the Northern Colorado region. I'll buy you a steak.
    One of the points of marvel with Taco is how narrow she was how tight she turned..
  8. Sep 29, 2024 at 9:14 PM
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    Despite its overall improvement versus the 3rd gen, the 4th gen design and engineering teams made some had scratching decisions on the turning radius, reduce fuel capacity, and absence of LED DRLs, to name a few. Turning my 3rd gen LB is no picnic in tight quarters as it is.
    23MGM likes this.
  9. Sep 30, 2024 at 12:51 PM
    ericin1984
    ericin1984 Well-Known Member
    2023 TRD OR Auto
    Not happening. Longer WB, plus wider, heavier, and less ground clearance did not a better off road truck make.
  10. Sep 30, 2024 at 5:31 PM
    JC 4th Gen
    JC 4th Gen Well-Known Member
    Raleigh, NC
    2024 TRD Sport
    Turning radius is awful - at least it is for the long bed. My '06 F-150 (super crew/5.5" bed) can make a MUCH tighter turn!
    I pulled out a tape measure and found that the Tacoma actually had a longer wheelbase than the F-150, which was surprising to me. Long wheelbase = big turning radius! The Tacoma long bed turns like a freakin' school bus...
    My old American trucks usually had adjustable stops which you could adjust for large tires to eliminate rubbing, but I doubt that there is an easy DIY fix to tighten the radius on the new Tacoma.
    stealthmode likes this.
  11. Oct 1, 2024 at 4:13 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    The headlights will probably be the 1st thing Toyota changes, many manufacturers are getting away from the DRL LED blade. Lower trim F-150 and Ram 1500 2025+ have LED reflector headlights that aren't to different from the halogen reflector lamps. Adaptive LED would also be welcome on the Tacoma with auto leveling and turning beams. The turning radius and fuel capacity can't be changed.
