Mod ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gundam_Kyoto20, Mar 23, 2023.
  1. Mar 23, 2023 at 3:40 AM
    Gundam_Kyoto20
    Gundam_Kyoto20 [OP] Well-Known Member
    2012 White Tacoma SR5 Prerunner
    Steering wheel cover
    Heyo I just wanted to get some ideas of mods to do for my daily 2012 Tacoma prerunner. Has the 4 cylinder so there isn’t anything performance I’m after. May do a k&n filter because I don’t want my rewards points from autozone to go to waste. Also may do a magnaflow muffler because why not. I’m not really looking to lift the truck because it’s 2wd so there’s no point.
  2. Mar 23, 2023 at 12:29 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Enter your CC# here and I’ll send you everything you never needed :rofl::rofl::rofl:. And yes you need to lift it just because you can.
  3. Apr 21, 2023 at 4:38 PM
    Gundam_Kyoto20
    2.7 Liter, 2700 cc
    TacoTimbo and deanosaurus like this.
  4. Apr 21, 2023 at 4:42 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Is it 6 lug or 5?
  5. Apr 21, 2023 at 4:45 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Dingle balls across the top of the windshield are always in fashion... Maybe a big rake and fatties on the back?
    ToyoTaco25 and HondaGM like this.
  6. Apr 21, 2023 at 5:00 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Keep changing out parts until you have a Corvette of Theseus.
    HondaGM and 0xDEADBEEF like this.
  7. Apr 21, 2023 at 5:35 PM
    Gundam_Kyoto20
    6 lug, sr5 prerunner 2wd
    HondaGM likes this.
  8. Apr 21, 2023 at 7:00 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    I would say forget the K&N filter. They are crap at filtration compared to paper filter. If you want to keep the truck running longer stick with paper filters.
    I would say that even a 1 or 2 inch level will make the truck look nice especially as it gets rid of the rake. Extra clearance when changing out the oil makes it easier.
  9. Apr 21, 2023 at 7:59 PM
    Gundam_Kyoto20
    I should probably get rid of the filter then. Maybe a leveling kit may be a nice mod, I did always wanted to drive through dirt roads, seems like fun. Just no overlanding because I’ll probably die somewhere in a mountain.
  10. Apr 21, 2023 at 8:10 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Prerunner? Find Chad's thread and do everything on the first page
    Gundam_Kyoto20[OP] likes this.
  11. Apr 21, 2023 at 8:30 PM
    Gundam_Kyoto20
    Do you have a link to the thread? I’m not sure who chad is sorry.
  12. Apr 22, 2023 at 2:01 AM
    Gundam_Kyoto20
    Never mind, found it.
  13. Apr 22, 2023 at 5:13 AM
    TacoTuesday1
    FL
    rewards points can buy a normal filter
    K&N has a very well known reputation for being oiled (bad, why would you want oil coming into your intake tract) and ruining MAF sensors
    but, if that is what you're looking for, Autozone will certainly be able to get one
    there really isn't a problem with stock filters
    and a factory Tacoma engine is going to be slow regardless of what filter is on it
    you can even keep a filter clean by putting a snorkel with skylone pre-cleaner, or maybe even cowl induction mod
    to relocate the inlet out of wheel arch (dirt and dust headquarters)
  14. Apr 22, 2023 at 10:41 AM
    blairrad
    blairrad Yoter
    Missouri
    I just bought a cleaning kit for my stock TRD OR K&N style filter -- should I have just bought a new paper filter?
  15. Apr 22, 2023 at 11:00 AM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    I have seen a few threads on the K&N filter running fine for 50k miles or whatever then, when the filter is re-oiled per K&N instructions users start having mass air flow (MAF) sensor issues because the oil gets on the very fine wire of the MAF sensor and causes problems. Do your due diligence before K&N engine air filter. Some go with WIX in the engine compartment and K&N in the cab to avoid MAF sensor issues. Not sure if this impacts your 2nd Gen 4 banger like it does the 3rd Gen V6s so I may be muddying the waters here. Something to check.
  16. May 21, 2023 at 8:20 PM
    Gundam_Kyoto20
    had the filter for about 1,500 miles, haven’t noticed anything negative. Will keep taking note of things but I can kind of feel the small extra torque. Next week I’m going to be ordering some all terrain tires because the ones I have right now are all season, barely any tread left and there’s a nail stuck in one of the tires so it gives me the excuse of upgrading. I’m also curious if there are any trails I can go to near Los Angeles or somewhere in California where I can have some fun with the truck without worrying about getting stuck in a ditch.
  17. May 21, 2023 at 9:07 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    I'd get ceramic tint (doesn't have to be dark), sound deadening and upgraded sound system. Good tires, battery, take care of the paint. Don't waste money on performance anything, it won't work.
  18. May 21, 2023 at 9:08 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    K&N filters are trash, I've seen that oily mess take out more than one motor. Get good paper filters
  19. May 21, 2023 at 11:11 PM
    Gundam_Kyoto20
    Tint is on my list, sound system isn’t something I won’t be doing for sometime because this is my daily.
  20. May 21, 2023 at 11:12 PM
    Gundam_Kyoto20
    I’ll probably just grab a paper one in the morning, do you recommend a brand?
