Mobile 1 Extended Performance High Milage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO_BANDIT4x4, Jun 20, 2019.
  1. Jun 20, 2019 at 12:50 PM
    TACO_BANDIT4x4
    TACO_BANDIT4x4 [OP] Member
    Zach
    Black 2008 4x4 Double Cab Long Bed 4x4
    My last 2 cars I ran Mobile 1 full synthetic extended performance oil. Loved the stuff. It guarantees that it's good for 15k miles between changes, but I usually changed it between 10-12k and it was usually pretty clean still.
    I recently purchased my 08 V6 4x4 Taco with 110k miles. I'm planning on running the Mobile 1 High mileage 5w30 extended performance. I guess the HM has seal conditioners and what not.
    What are some opinions on the Mobile 1 EP High Mileage full synthetic if you run it through your taco? And do you run if for the full 15K miles between changes?
    link below to the product. Hard to beat that price!
    https://www.walmart.com/ip/Mobil-1-...ileage-Formula-Motor-Oil-5W-30-5-qt/111569385
    thanks folks!
  2. Jun 20, 2019 at 1:12 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Oil is oil is oil.
    Guys here change their oil anywhere from 3k ( silly and wasteful) all the way to 15 k ( with blackstone reports to back it up)
    I would go the 15K and not even think twice about it.
    TACO_BANDIT4x4[OP] likes this.
  3. Jun 20, 2019 at 1:18 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    10 K miles is easy enough to remember...
  4. Jun 20, 2019 at 1:19 PM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    I also do extended oil change intervals currently 12,500 miles. I could care less what brand of oil however. Any synthetic I can get on sale works just fine.
  5. Jun 20, 2019 at 1:20 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    I was using the stuff because I figured its only an extra $3-$5 for the extended period, but ultimately I felt like the engine oil level was being neglected. And every car or truck I've ever driven 'sometimes' burns oil and 'sometimes' doesn't burn oil (so I think the oil level is a byproduct of how I drive, not a malfunctioning or poorly designed engine) - so I prefer just resetting the oil level every 5k-6k miles instead of running it for an extended period.
  6. Jun 20, 2019 at 3:50 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    You need to use a like type oil filter such as M1-102A as when they went to the extended life oil they dumped the higher micron M1-102 filter for the current 102A which filters to a slightly lower level to last for the extended period and not clog. Just the facts. I run once to 12K and the oil was very dirty and the filter was very heavy so now change after 6K or so - only costs about $35 and I want to run this engine along time - will outlast the body and frame I bet - at 150k now and 10 years old. I am in FL so hot and tow boat around.
  7. Jun 20, 2019 at 4:35 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    All Mobil 1 synthetic oil is the same. If you think otherwise , well..... :jerkoff:
    mbrogz3000 likes this.
  8. Jun 20, 2019 at 4:37 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I have a question how many have had a oil related problem with any type of oil assuming you change it as recommended? Next question do you service the other parts like drive shaft fittings trans and diff. oil checks general inspection of fame work tie rods, tires etc. or do you wait until 10,000 or more miles?
    Bluetacoma40 and kidthatsirish like this.
  9. Jun 20, 2019 at 4:37 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Most likely yes. The more expensive stuff may have a slight better additive pack, but the difference between basic Mobil1 and Mobil1 EP is only discernible in a UOA.
    Any modern synthetic and 10K oil change intervals should provide very adequate protection.
  10. Jun 20, 2019 at 4:41 PM
    mbrogz3000
    Northern NJ
    That’s hilarious!!
    Bluetacoma40 likes this.
  11. Jun 20, 2019 at 7:29 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I use it on my vehicles, works great. You may also consider getting a bypass filter to extend the intervals even longer.
  12. Jun 20, 2019 at 8:05 PM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I try to stay factory service or better, documenting and saving receipts. The reality is, although I keep my trucks for a long time, they're going to be someone else's someday. My last Tacoma I owned 20 years and when I sold it this past May, got a really good price for it, in part, because I had stuck to and documented the factory service intervals and wasn't some Black Stone experiment.
    Edit: Mobil 1 out and back in everything at 5k
  13. Jun 20, 2019 at 8:07 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Don't forget the rebate that's currently active
    cfj5177 likes this.
  14. Jun 21, 2019 at 5:33 AM
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    If I changed my oil every 15k, that would put me at intervals of every 2 years to change my oil. I stick to every 6 months regardless of miles.
