Mobil 1 vs Toyota motor oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zenny, Dec 27, 2019.
  1. Dec 27, 2019 at 5:23 PM
    zenny
    zenny [OP] Well-Known Member
    2017 tacoma access cab TRD Off Road
    Hello all. I own a 2017 tacoma TRD 4x4 Off Road. I have a question for you. I have been told to use Genuine Toyoto API SN SAE 0W-20 Motor oil with oil grade ILSAC GF-5 for oil changes. However, my service department uses bulk Mobil 1 synthetic.
    1. Is the Mobil 1 used for oil changes compatible with Genuine Toyota motor oil.
    2. Is the Mobil 1 oil SAE 0W-20 and ILSAC GF-5 specs as recommended by Toyota?
    2. Is it safe to switch from Genuine Toyota Motor oil to the Mobil 1 Synthetic?
    3. It appears the Mobil 1 synthetic oil is a little cheaper then the Genuine Toyota synthetic.
    Can I purchase the Mobil 1 Synthetic oil at a parts store if in fact it is compatible and OK to
    use?
    4. There are many types of Mobil 1 synthetic oils. Which type is best for my Tacoma.
    I just want to make sure that I am doing what is right for my Tacoma without causing any harm. You advise and knowledge is important and means alot. And I do not want to mess with my warranty.
    Awaiting your response and thank you in advance.
    Lou Pecek
    Owner of a 2017 Tacoma TRD 4x4 Off Road.
    YE2KA likes this.
  2. Dec 27, 2019 at 5:24 PM
    Massappeals
    Massappeals Guest
  3. Dec 27, 2019 at 5:26 PM
    MyWifesTaco
    MyWifesTaco Well-Known Member
    OKC/Southern Colorado
    2019 Tacoma Cavalry blue 4cyl access cab 4x4
    TRD pro grille .
    Mobil makes the Toyota oil
  4. Dec 27, 2019 at 5:27 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
  5. Dec 27, 2019 at 5:27 PM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    Don't think about this too much.
    P-Dawg, stun gun, nomnomtaco and 5 others like this.
  6. Dec 27, 2019 at 5:28 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I use Mobil 1 synthetic. It's fine. You are over thinking this. Go buy it on sale at Walmart.
  7. Dec 27, 2019 at 5:28 PM
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    Supertech is just fine for these trucks. Your information is misleading. Plenty of real world results would tell you that Supertech is actually fantastic for our vehicles, and most vehicles for that matter.
  8. Dec 27, 2019 at 5:28 PM
    MyWifesTaco
    TRD pro grille .
    Preparing to get flamed ...
    I use Orielly brand oil
    taco abbo, Wixo, GreyBaldTaco and 2 others like this.
  9. Dec 27, 2019 at 5:29 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    Yup. People hate on Supertech, but it's made by Warren who makes nearly all of the store brands...
  10. Dec 27, 2019 at 5:30 PM
    MyWifesTaco
    TRD pro grille .
    And to stir the barely hard turd pile
    0w20 is way to thin for my peace of mind
    Hoff, rrt49 and outlawtacoma like this.
  11. Dec 27, 2019 at 5:34 PM
    StillNoPickles
    2020 RAV4 Hybrid LE
    Guy down the block with almost 400k between 2 3rd gens has all the bragging rights. He uses Supertech in the engine and diffs and has had zero issues. About 7kish intervals towing and hauling on a daily basis in the southwest. I think that pretty much speaks for itself :thumbsup:
  12. Dec 27, 2019 at 5:35 PM
    MyWifesTaco
    TRD pro grille .
    My truck is the official Orielly fluids test vehicle
    Gear oil
    Trans fluid
    Motor oil
  13. Dec 27, 2019 at 5:39 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Im no oil expert, but after all of the oil threads, ive come to the conclusion that we drive trucks and not sport cars so we can throw any brand in there as long as its the right consistancy.
    Speedfreak, VanGo3, hiPSI and 5 others like this.
  14. Dec 27, 2019 at 5:39 PM
    StillNoPickles
    2020 RAV4 Hybrid LE
    Hey it’s rated and works just fine for normal intervals. For me changing it every 5k, I’m not going to spend more on an oil to get a few thousand more out of it.
    OP: If it’s rated and meets Toyota’s specs, most any 0w-20 should be fine for normal intervals. If you’re dead set on doing 10k intervals, a higher quality 0w-20 would be best. Toyota and Mobil 1 spec very similar on paper, and will both be fine for long intervals with an OEM or quality filter. These trucks aren’t that hard on oil to begin with.
    Wixo and GreyBaldTaco like this.
  15. Dec 27, 2019 at 5:41 PM
    StillNoPickles
    2020 RAV4 Hybrid LE
    I told him the same thing, but funny enough he spends too much time on the roads and running his business to keep up online, and when he’s barely home he’s got his family and house. Busy but real down to earth dude. I’ll see if he can let me snap a pic of his contractor truck Tacoma and the odometer next time I see him.
  16. Dec 27, 2019 at 5:47 PM
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    I use the Mobil 1 advance fuel economy 0w20 from Walmart. I change mine every 5000miles with an oem Toyota filter. Any high end brand will do fine. Amsoil is probably the best , but expensive .
    Tocamo likes this.
  17. Dec 27, 2019 at 5:53 PM
    MyWifesTaco
    TRD pro grille .
    Yes sir before that my fleet was running Service Pro but the source i had for that closed down and the next source for service pro pushes other brands
    My trucks ( aside from the wife's taco) make me all my money and make even more when money isn't wasted
    Side note I run all the gas trucks 10k and use the silver bottle full synthetic Orielly with a wix XP filter
    The super duties I run the Orielly 15w40 with a motorcraft filter and usually right at 12k
    When I do buy a major brand oil I always go Castrol for senemential reasons (My grandpop ) used it
    The Taco has the Orielly house brand full syn 5w30 with currently a fram orange filter and I will have no fear going 10k normally I use a wix XP filter
  18. Dec 27, 2019 at 5:54 PM
    StillNoPickles
    2020 RAV4 Hybrid LE
    The only thing he’s done is added a leaf in the rear and airbags for the contractor canopy/box he has on the back, and when towing his small trailer. Otherwise everything else appears completely stock. He does safety inspections/mitigation and handyman/pest control work for industrial and mining operations in Arizona, Southern California, and Nevada. Kind of a jack of all trades dude they probably hire on to knock out a bunch of stuff at once. So I imagine he sees some light offroading from time to time out at some of the more remote operations.
  19. Dec 27, 2019 at 5:55 PM
    Truc577
    Truc577 Well-Known Member
    Curt
    NOMO
    2005 TRD OR 4x MT, 2020 TRD OR 4x AT
    High output valve stem caps 2020: Bilstien 6112/5100 Mobtown sliders RRW RR-5 Bronze wheels 2005: 2018 frame and full suspension 2017 Dark Anthracite wheels ARB front bumper
    Use the most expensive oil. Then have it tested after each oil change then panic if it’s well within standards. Or use the cheaper stuff and do the same thing. Then you should feel a vibration in the driveline somewhere. This is the way. I have spoken
  20. Dec 27, 2019 at 6:02 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
