Mobil 1 Synthetic High Mileage vs Extended Performance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AJC84, Mar 18, 2023.
  1. Mar 18, 2023 at 11:26 AM
    AJC84
    AJC84 [OP] Well-Known Member
    Andy
    2011 DC LB V6 4X4 MAG GREY
    Anyone running the Mobil 1 Full Synthetic High Mileage Extended Performance over the Synthetic High Mileage? Price difference is minimal I think $3 more for the 5qt extended performance, but I’m curious if it’s really much better. The extended says protects engine up to 20k and regular high says 10k. I personally wouldn’t go that long between oil changes regardless of which oil, but curious if anyone has noticed any difference between these two oils and if you are still changing the oil at about 5k regardless.
    Bought the regular high mileage but may try the extended performance instead.
    Also, anyone use any any oil additive that helps with burning oil? My uncle said he uses one 1 quart of some Lucas synthetic oil with an additive that he uses in place of one of the oil capacity quarts.
    HanSolo likes this.
  2. Mar 18, 2023 at 11:31 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Marketing gimmick I suppose.
    kidthatsirish, wi_taco and AJC84[OP] like this.
  3. Mar 18, 2023 at 11:48 AM
    TheArea51Rider
    TheArea51Rider Member
    kidthatsirish, HanSolo and AJC84[OP] like this.
  4. Mar 18, 2023 at 1:12 PM
    3X4X4
    3X4X4 Well-Known Member
    JR
    KS
    2006 Indigo Ink Blue TRD O/R
    Snug Top, Toytec Ultimate Lift, SPC control arms, N-Fab light bar with Hella DL, Yakima rack, factory locker, Cooper AT3 265X75X16, TRD exhaust and front skid
    Since neither the 2.7 nor the 4.0 are known for leaking oil or burning oil or any other wear/age maladies of engines (aside from blowing head gaskets). I see no reason to justify use of a HM oil in a Tacoma.
  5. Mar 18, 2023 at 2:21 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Ask (or search) over at bobistheoilguy forums. I believe the EP does perform better over long intervals due to a higher TBN (total base number; helps to counteract acidity of oil as it is used with time).
    But if you change every 5k-10k, the additional cost of EP is most likely not warranted, especially if you have been doing used oil analyses and know for a fact that your TBN is still above 0 by the time you drain your chosen oil.
    There are some people who use bypass filters on their engines and can get 40-50k miles of service from a single oil change (excluding top offs to make up for evaporation or blowby loss); these are the people who would be the customer who buys EP oil.
  6. Mar 18, 2023 at 11:33 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    If you don't currently have problems there really isn't a need for either high mileage or extended interval oils. Marketing wank at it's finest. Change at 5k miles or 6 months, OEM filter + a quality oil, and sleep easy at night. Tacoma engines aren't picky, this is very simple stuff on our trucks.
    OP you seem to keep wanting to buy miracle-in-a-bottle solutions so I'm going to quote myself from your other thread because apparently it needs repeating:
  7. Mar 19, 2023 at 12:11 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    6 gearT444E likes this.
  8. Mar 19, 2023 at 1:10 AM
    erok81
    erok81 Well-Known Member
    Imposter
    After looking at all of Mobil 1’s offerings I ended up just getting valvoline. Mobil just seems to have way too many offerings, none of which fit my uses. I definitely don’t need an oil that can go 20k between changes.
  9. Mar 19, 2023 at 1:58 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    like a Ronco, set it and forget it :rofl:
    Taco 422 and erok81[QUOTED] like this.
  10. Mar 19, 2023 at 2:50 AM
    kwanjangnihm
    kwanjangnihm Timeout Terminator
    Jeff
    Central Florida
    13 DCLB TRD SP PR OTT
    "If it ain't a longbed it ain't shit! :)
    I ran Mobil 1 in my Tundra and now in my 2013 Tacoma 4.0 that just hit 180K.
    I have seen the Project Farm video prior to the OP's thread.
    My only question is why the Mobil 1 HM flows better at lower temps, when both oils are 5w-30? (4:00 min mark)
    CROM123 likes this.
  11. Mar 19, 2023 at 3:49 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    The EP has more conditioner that helps rejuvenate rubber so gaskets stay sealed. I’m at 180K miles and 13 years old. I have and will continue to use standard M1 every 5K miles since nothing is leaking. If it does start leaking enough that it’s a mess, I’ll put in new gaskets where it’s easy (valve covers, oil pan). If the main engine seals go, ill try AT205. When it gets too bad, I’ll buy a new truck.
    CROM123 and AJC84[OP] like this.
  12. Mar 19, 2023 at 4:20 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Castrol is also good. Valvoline & Pennzoil are good too :)
    CROM123 likes this.
  13. Mar 19, 2023 at 7:20 AM
    3X4X4
    JR
    KS
    Since my 06 blew a head gasket at 139,000 miles and ruined the engine completely I am a bit miffed. It was babied receiving red carpet treatment with only the finest oils and filters served on a silver platter every 5,000 miles or less. Now with a new engine, screw that crap. It can use standard 5W-30 M1 and whatever oil filter I grab and it can go 7,500 miles minimum or whenever I get around to it. Oil and filters are not the life limiting factors on Tacomas, car crashes (caused by cell phone texting bimbos), head gaskets and frame rust are the killers. In fact, I think it is getting Super Tech henceforth.
  14. Mar 19, 2023 at 9:42 AM
    2015WhiteOR
    Gainesville TX
    The nominal grade (ex: 5W30) just means its chemical characteristics fit within a range. The kinematic viscosity (centistokes) can vary between oils with the same grade, which is why it probably flowed better at lower temps.
    CROM123 and kwanjangnihm[QUOTED] like this.
  15. Jun 17, 2024 at 11:49 AM
    CROM123
    CROM123 Love my Tacoma
    Garland
    Virginia
    2010 Tacoma 4x4 2.7 reg.cab. 27-k miles
    265/75/16 coopers at3 4s
    I have been using Mobil one extended performance since new and just recently switched at 133-k to Mobil one extended performance high mileage and no leaks no problems. I change oil about 3-k.
