Mobil 1 75w-90 rear diff. gear oil with additive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wendell1, Feb 9, 2014.
  1. Feb 9, 2014 at 1:35 PM
    Wendell1
    Wendell1 [OP] Member
    Nc
    06 tacoma 4x4 sport
    I have an 06 tacoma sport 4x4 4.0 with the LSD ONLY sticker on my rear differential. Will it be ok to use mobil 1 LS 75w-90 in my rear differential WITH Trans-X posi - trac limited slip gear additive?? DOES THE MOBIL LS need an additive?
  2. Feb 9, 2014 at 1:41 PM
    Wendell1
    Nc
    06 tacoma 4x4 sport
    Does anyone no what the tacoma 06 sport gear oil is from the factory? Brand and weight, also is there an additive, the manual doesn't say to add an additive only 80 or 90w GL-5 gear oil, in which the mobil 1 is? Confused?
  3. Feb 9, 2014 at 1:48 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  4. Feb 9, 2014 at 3:04 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
  5. Feb 9, 2014 at 3:11 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    You don't have the mechanical LSD either. Big difference. The mobil1 should work though even with mechanical since it states it has the modifier in it.
  6. Feb 9, 2014 at 4:06 PM
    reece13
    North Carolina
    True, my current truck doesn't have the old school lsd, but my 2005 had the true lsd like the op's. That is what i was referring to.
  7. Feb 9, 2014 at 4:08 PM
    bjboucher
    Brad
    San Antonio, Texas
    Ah, guess I should read closer. Sorry!
  8. Feb 9, 2014 at 4:08 PM
    reece13
    North Carolina
    no worries.
  9. Feb 9, 2014 at 4:19 PM
    lyodbraun
    lyodbraun Well-Known Member
    NW Ohio
    2006 SR5 TRD Sport
    Nothing yet
    Yes you will be fine to use what you have, it's the same as mine and is what I have on hand to change my 06 sports front and rear differential... If the weather ever gets warmer and quits snowing...
  10. Feb 9, 2014 at 4:24 PM
    muddedtaco
    muddedtaco Well-Known Member
    Wesley
    South Mississippi
    96 Tacoma 4x4 2.7
    Rattle caned black, Mossy oak door panels, shifter shroud, and radio cluster surround
    Yesterday at a friends hunting club I crossed a flooded stream and the water was deeper than I thought, the water came over the hood, should I change my gear oil. Sorry to still Thread.
  11. Feb 9, 2014 at 9:07 PM
    fur pig
    fur pig Well-Known Member
    I used that oil in my 2012 when I did my 30k and put it in my tcase, front and rear diff. You're good to go : )
  12. Feb 10, 2014 at 4:40 AM
    bjboucher
    Brad
    San Antonio, Texas
    2012's don't have mechanical LSDs like 2006.
  13. Feb 12, 2014 at 4:56 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I have done this before and when changed didnt show any sign of water intrusion. Would really depend on when it was changed last and if you want to take a chance on it. If ot has been awhile i say change it if time and money allow.
  14. Feb 12, 2014 at 7:02 AM
    adamh1977
    adamh1977 Well-Known Member
    arkansas
    trd sport 4x4
    any time fog,tinted windows to 5% ,plasti dipped gun metal gray,toytec 5100's eibach coils ,led map and dome lights
    good thread im looking to do this when it warms up here
  15. Feb 12, 2014 at 9:17 AM
    oladawg
    oladawg Member
    Phil
    Georgia
    07 PreRunner TRD Sport
    I used the Trans-x additive and had issues after about 5000 miles. Read here where the GM additive was recommended. I changed mine again using the GM additive and all is well.
