Mixing Maxlife ATF with Toyota WS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dewriffic16, Jul 8, 2014.
  1. Jul 8, 2014 at 8:11 AM
    dewriffic16
    dewriffic16 [OP] Well-Known Member
    David
    Flagstaff, AZ
    '09 TRD Off-Road DC
    Custom Perforated Stainless Satoshi Grill, 3" Toytech Ultimate Lift with AAL in the rear, Total Chaos UCAs up front, Bilstiens all around, Diff drop/sway bar drop, Locker Anytime Mod, Map Light on with doors, AUX back up camera on anytime switch.
    Hey guys, I've read a ton of info online and on this site, but nobody really ever answered the exact question on whether or not it is ok to use Maxlife ATF when doing a drain and fill vs a full flush. I went to replace the tranny fluid screen and drain/fill my truck this weekend and read in the manual that I needed WS compliant fluid. I had just finished another vehicle and had leftover jug of maxlife ATF which at first glance reads right on the back meets or exceeds WS.
    I did the drain, followed the refill procedure complete with jumper wire and up down left right select start B A combo to check the temp and everything went fine. Drove the truck around for a day and then last night went to throw out the jug and noticed that it said full synthetic on the bottle.:confused:
    That led to a hopeless search for whether or not Toyota WS is synthetic and whether or not I should have mixed it.
    Deep down I know the conservative response is, go buy 12 quarts of ATF and do the full flush of either maxlife or Toyota WS, but has anyone ever done just the drain and fill (3-4 qts) and mixed Maxlife with stock? I'm at about 45K miles and kind of want to make it to 60K before my conscience forces me to do the full flush, but if you have a convincing argument, I could go home and do it tonight =-)
    Thanks in advance!
    dira1987 likes this.
  2. Jul 8, 2014 at 8:33 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    I have done this every year on my truck. No issues here as I do this with all the families cars/trucks. I was hesitant to try the full on flush here since I was paranoid I'd run the pump dry in the trans.
  3. Jul 8, 2014 at 10:19 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    if it is running fine now, leave it. it isn't like you put water in there...
    next time just stick to Toyota WS to end the guesswork.
  4. Jul 8, 2014 at 4:52 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    OP should be fine. I'd have no regrets.
  5. Jul 10, 2014 at 8:05 AM
    dewriffic16
    David
    Flagstaff, AZ
    '09 TRD Off-Road DC
    Thanks guys, so far so good, I guess I was just looking for some confirmation from someone with more than the 15 miles i'd driven... Thanks for the replies.
  6. Jul 10, 2014 at 12:08 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    I did a drain/refill with this stuff in my wife's 2010 Rav4, and a complete flush and AT filter using this stuff in our 2004 160k mi corolla. No issues with Valvoline Maxlife ATF (or mixing it in with Toyota fluid) at all.
