Mix 'high mileage Mobil 1' with regular mobil 1, both fully synthetic
Discussion in 'Technical Chat' started by STLTaco09, Jun 4, 2010.
  1. Jun 4, 2010 at 5:03 AM
    STLTaco09
    STLTaco09 [OP] Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    As the title says, can I mix the fully synthetic high mileage mobil 1 with the regular fully synthetic mobil 1? The Walmart by me never has the regular 5W-30 fully synthetic mobil1 5 quart jug, but they have the stuff labeled "High Mileage" fully synthetic (says for cars with high mileage). My Tacoma only has 20,000 miles on it, but I've been using synthetic since 1200 miles.
    Any Pros/Cons to use the stuff labeled "high mileage" in a low mileage vehicle?
  2. Jun 4, 2010 at 5:04 AM
    STLTaco09
  3. Jun 4, 2010 at 5:06 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    I don't think it's a big deal as long as there the same weight.
  4. Jun 4, 2010 at 5:11 AM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    I don't believe in mixing any oil.
  5. Jun 4, 2010 at 5:19 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Get on Mobile 1's website and send them an e-mail. They are pretty quick to respond.
    Ask them....
    "Is the high mileage / truck & SUV oil the same as the standard oil?"
    "What's the difference between Mobile 1 5W-30 and the high mileage 5W-30?
    I recently e-mailed them about their gear oil. I asked them if the Mobile 1 75W-90 LS (gear oil) was the same as the 75W-90 (without the LS). And YES - it is the same oil. It's marketing....
    I'm halfway tempted to bet, it's the exact same oil.
  6. Jun 4, 2010 at 5:23 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    It won't hurt anything to mix the oils, one can even mix synthetic with non-synthetic.
  7. Jun 4, 2010 at 5:54 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    Sorry to jack your thread OP...so would you still need additive if you use the 75-90LS gear oil? The guy told me i didnt because its already in the oil for LSD gears.
  8. Jun 4, 2010 at 6:18 AM
    STLTaco09
    Good idea, I shot them an email. Thanks for the input.
  9. Jun 4, 2010 at 6:24 AM
    Janster
    Jandy
    Lancaster, PA
    You might want to look at this thread:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/93117-beware-changing-lsd-lube.html
    The LSD's in these trucks tends to be 'picky' and there are lots of conflicting information of what works & what doesn't work in terms of oils/additives.
  10. Jun 4, 2010 at 8:10 AM
    STLTaco09
    So I got an email response asking to call their 1800 number. I called, they told me the high mileage stuff have extra additives to help cleaning the engine, and it is on the thicker side of the viscosity curve to help prevent burning extra oil. I asked if I could use it in a low mileage vehicle, he said as long as I am not under warranty, I could use it. I asked why that had any impact, he said that vehicles require a high efficient (I think thats what he said?) oil, and this oil did not meet those standards. So since I'm under warranty still, he said I should not use it.
    Interesting...
    They did say it could be mixed though with the regular 5w-30 stuff.
    HappyGilmore likes this.
