Misfire on cylinder #2 and #5
Discussion in '1st Gen. Tacomas (1995-2004)' started by Adamski812, Dec 20, 2017.
  1. Dec 20, 2017 at 4:05 PM
    Adamski812
    Adamski812 [OP] New Member
    Hey Tacoma World,
    I’ve got a 98 Tacoma Pre Runner V6. The check engine light just came on. I had it diagnosed and the result was misfire on #2 and #5 cylinders. There are a couple older threads on here discussing the same problem but they don’t seem to have a conclusion. Any tips or advice before I start down similar path of plugs, wires, coil etc?
  2. Dec 20, 2017 at 4:11 PM
    Bishop84
    Bishop84 Well-Known Member
    Your v6 uses waste spark, one coil for 2 cylinders, 2 and 5 are paired using a single ignition wire.
    Start by inspecting the spark plugs and conditions of the wires. Toyota stamps production dates on the wires, if yours is original it will say "1997/8" on them. Original is bad and likely the problem.
    If both are new or in good condition, simply swap the coil pack on cylinder #5 to #3 to see if the code moves, this will determine the coil is at fault.
    64398d1337227175-need-help-spark-plug_wi_7cd559962a01140c74a9d148624aaee540becbde.jpg
    lmhp1985 and Toyko Joe like this.
  3. Dec 20, 2017 at 8:24 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Referencing the diagram, it makes me want to say it's either: one or both of the spark plugs not allowing spark to travel through the wire (damaged or not gaped properly), the coil itself is bad, the wire is bad, or the pigtail is bad (highly doubtful).
  4. Dec 21, 2017 at 6:37 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Swap coils and see if misfire code changes.
    lucky13don likes this.
  5. Dec 22, 2017 at 10:53 PM
    Adamski812
    Hey Tacoma Crew,
    Today I changed the coil, wires, and plugs. This seems to have fixed the issue. I’m not sure what the exact problem was. The plugs and wires looked good. If I had to guess it was the coil. Thanks for the input.
    Merry Xmas.
    lucky13don, mechanicjon and Biscuits like this.
