Mirror Swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fernridge, Oct 22, 2014.
  1. Oct 22, 2014 at 2:56 PM
    Fernridge
    Fernridge [OP] Fernridge Fabrication and Designs
    Jake
    Oregon
    02 SR5 ext cab
    3" leveling kit, custom roof rack,custom headache rack and bedtop protection
    Has anyone thought about or have experience with swapping out the side view mirrors of an '02 with another vehicle? Do you know of any that are close to a plug and play?
    Any help into this endeavor would be a great help!
  2. Oct 23, 2014 at 7:56 AM
    markmb45
    markmb45 Well-Known Member
    Mark
    Utah
    99 4x4 Reg Cab 3.4, auto, e-locker
    V6,Auto, e-locker 4runner dash, seats
    I installed electric 4runner mirrors on my 99 tacoma. Bolted right up. Little tight running the wires behind the door panel. The 3rd gen 4runner mirrors are a direct bolt up.
    Hamer95USA likes this.
  3. Jan 16, 2021 at 2:28 AM
    Loadout66
    Loadout66 Member
    Eastern,TN.
    99 Taco,v6;4wd;2.5" lift.
    2.5 inch lift.Donahoe coilovers in front,Downey leaf springs in rear,4 Runner buckets and console inside,5100 Bilstiens in rear.
    I have a 99 Taco and are looking at 97 4runner power mirrors to buy,so the swap will work?
  4. Jan 16, 2021 at 8:04 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    99-02 4runner mirrors are the same shape as 01-04 Tacoma power mirrors with the same mounting locations.
    ALMOST all 99-02 4runner mirrors are heated (99 was a transition year). You can verify this by making sure there are 5 wires in the wire harness instead of 3.
    The 4runner mirror base (part that mounts to the door) is the same physical dimension as the 01-04 Tacoma mirrors. There are a couple differences:
    4runner mirrors use bolts, Tacoma mirrors use studs
    4runner mirrors have a retaining screw that cannot be used on Tacomas unless you modify your door
    4runner mirrors have an alignment pin that cannot be used on Tacomas unless you modify your door (I just ground this down flat)
    99-02 4runner mirrors have a 6 pin connector, Tacoma mirrors have a 3 pin.
    96-98 4runner mirror have a 3 pin connector (I believe this is the same as the Tacomas)
    96-98 4runner mirrors
  5. Jan 16, 2021 at 9:26 AM
    Loadout66
    Loadout66 Member
    Eastern,TN.
    Do you know what years specifically will fit my 99 Tacoma? I seem to have all the wiring in the truck already and armrest stubbed out for switch,thanks again!
  6. Jan 16, 2021 at 9:41 AM
    Madjik_Man
    Colorado Front Range
    I would love the heating element for my 04 mirrors.
  7. Jan 16, 2021 at 6:16 PM
    nzbrock
    Noah
    San Marcos, TX
    I believe the 96-98 4Runner mirrors could be plug and play since I think they use the same wiring connectors. The 99-02 mirrors use a different connector so you’d have to rewire it, but that’s not hard at all.
  8. Jan 17, 2021 at 5:13 AM
    MCJohnston
    MCJohnston Well-Known Member
    Matthew
    CT
    02 Tacoma SR5 TRD 3.4L 4x4 X-tra Cab
    Same.
    My drivers mirror shakes in the housing and it’s starting to get annoying.
    I’m in the NE and I feel like heated mirrors are necessary so I’m gonna try and snag some from the junkyard come spring. Hopefully find some seats and an overhead console too.
  9. Nov 27, 2021 at 11:54 AM
    Krzykraker
    Krzykraker Well-Known Member
    1998 Toyota Tacoma Base, 2.7L, 4wd, Regular Cab, Shortbed
    Has anyone here done enough research to know what year 4-Runner mirrors fit what year 1st Gen Tacomas? I don't want power mirrors w/heat and lights or anything fancy like that. Just a manual mirror. I'm just tried of my mirror being bumped by someone or having to readjust it after the carwash.
  10. Nov 27, 2021 at 4:57 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    6 posts above yours is a detailed answer to your question.
  11. Nov 27, 2021 at 4:58 PM
    Abeyancer
    Jimmie
    PNW
    The non heated electric ones can be installed and you just manually push the mirrors into adjustment
  12. Nov 28, 2021 at 5:30 AM
    rybern
    rybern Well-Known Member
    N Alabama
    2023 TRD OR & 2000 SR5
    5100's & 3AAL, 265/70r17 Toyo AT3
    Agreed. I installed power mirrors on my 2000 Tacoma(w/o power mirrors). I manually push the mirrors to adjust, not being able to adjust them with a switch isn't a big deal because once I have them adjusted, I never move them. Having said that, I do think it's cool when folks install the controls to make it work. :cool:
    Abeyancer[QUOTED] likes this.
