Minimum volts to start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TroyFJ, Mar 10, 2020.
  1. Mar 10, 2020 at 9:46 PM
    TroyFJ
    TroyFJ [OP] Well-Known Member
    Troy
    2017 TRD OFF-ROAD
    2” lift
    So I installed a volt meter to keep track of battery status after using aux lights. Led me to wonder, what is the minimum volts needed to start my 2017 Tacoma? Anyone know? Thanks.
  2. Mar 10, 2020 at 9:58 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    It’s all about cold cranking amps.
    Edit :
    Cold Cranking Amps (CCA)
    CCA is a rating used in the battery industry to define a battery's ability to start an engine in cold temperatures. The rating refers to the number of amps a 12-volt battery can deliver at 0°F for 30 seconds while maintaining a voltage of at least 7.2 volts.
    whatstcp likes this.
  3. Mar 10, 2020 at 10:11 PM
    heybronicetacoma
    heybronicetacoma Meat Popsicle
    Claro
    Seattle
    ‘20 DCSB MT OR SSM
    Mods? Yes.
    this
    Jlevitt95 likes this.
  4. Mar 10, 2020 at 10:14 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Is the question, How many bolts, as in lightening bolts? I would say 1 would be enough start just about any if that's the case.
    SR-71A and GreyBaldTaco like this.
  5. Mar 10, 2020 at 10:17 PM
    Bishop84
    Bishop84 Well-Known Member
    Many factors but voltage does tell a lot.
    In good weather, near room temp, a battery with 8-9v can start a truck.
    In hot weather, the cranking power is reduced and you need more voltage, usually 10v is minimum. Same for cold, due to resistance from the motor.
    I would never let my vehicles run lower than 11.5v intentionally.
    Gunshot-6A, tonered and stun gun like this.
  6. Mar 10, 2020 at 10:21 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Title edited to reflect question
    shakerhood and heybronicetacoma like this.
  7. Mar 10, 2020 at 10:22 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Battery temperature makes a huge difference. In my testing a battery out all night below 0°F would drop down to less than 11.6v even if it was fully charged. Warming the battery up with a battery heater for a a couple hours would cause the voltage to increase back to around 12.2v generally.
    ancient11 and Gunshot-6A like this.
  8. Mar 11, 2020 at 7:07 AM
    Spazum888
    Spazum888 Well-Known Member
    Spaz
    Orlando, FL
    2017 Taco TRD off-road 4x4
    You can have a 12.7v (fully charged) battery but only have 20cca(bad batt). But if you only have 9.2v, your not gonna have the amps to start...
    You can get a batt that has 1000cca, but your motor is only gonna take what it needs. In theory if you get a higher amp batt, it should last longer.
    Anything below 12.0v is considered a zero charge battery.
    Some batteries are not maintenance free. You will have to check the fluid levels every few months to make sure they are above the lead fins that you can see when you pop the top.
    Our batteries are stickered at 80%. So if a new battery says it has 600cca, it's most likely higher (700-800cca) if tested as new.
    If you are experiencing any difficulty in starting, take it into a car/battery shop and have them run a test on it (usually for free, takes less then a min). They will take a look at what your battery is rated at, and what your getting. If its below a certain threshold, they will advise you if it needs replacement. Also, dont be afraid to take it to other shops and have the batt tested. You might not need a new batt, could be an alternator issue or power leak somewhere.
    Actually at work right now typing this[​IMG]
  9. Mar 11, 2020 at 7:12 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    The starter doesn't deliver amps, it uses them...
    MR E30 and Lawfarin like this.
  10. Mar 11, 2020 at 8:05 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl:
    Great answer!
    You to @Bishop84 .
    :cheers:
  11. Mar 11, 2020 at 8:11 AM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    You're no fun :boink:
  12. Mar 11, 2020 at 8:11 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Everyone keeps talking cca. That is what the battery is rated at 0f and Ca rating is 32f. you can have a battery with a dead cell that can read 12.3 volts. And you can have a battery with good cells read 11.8 volts or lower. There are many variables. However as already stated it’s not about the voltage, it’s about the amperage.
    tonered likes this.
  13. Mar 11, 2020 at 8:32 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    One other note here. If your VM is not attached directly to the battery, the displayed voltage is most likely lower than the actual battery voltage. Do a comparison with a multimeter right on the terminals. You may see a difference that you will have to compensate for.
    This was from a similar question when we were discussing the volts reported through the OBD II port:
    shakerhood and Spazum888 like this.
  14. Mar 11, 2020 at 9:12 AM
    Spazum888
    Spaz
    Orlando, FL
    Each cell is about 2.2v. So if you have a dead cell it would read 10.4v.
    Some places might not test a 10.4v batt thinking its discharged. Test it anyways. Might come back as a bad cell
    Usually bad cells smell. Sulfuric acid smells like rotten eggs. It's a smell you can't forget.
    tonered likes this.
  15. Mar 11, 2020 at 9:22 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I've got a PMP running parking mode on my dash cam, it switches off at 12.0v. Most of the year it will switch off around 6am, and truck starts and runs with no issue around an hour later.
    Once the weather dips below freezing I turn off parking mode because although it has never non-started, I've lost trip distances before - which is a symptom of bad batt/low amp start..
    Spazum888 likes this.
  16. Mar 11, 2020 at 10:02 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    you don’t test a low battery when it’s discharged. You charge it first then test. A have worked on vehicles with a bad cell and they won’t read 10.5 volts just because one cell is bad.
    tonered likes this.
  17. Mar 11, 2020 at 11:37 AM
    Bishop84
    Interstate was already my favorite brand haha, this thread makes it so much better.
    ancient11 and Spazum888 like this.
