Minimum tire pressure for off-roading
Discussion in 'Off-Roading & Trails' started by R0N, Sep 29, 2021.
  1. Sep 29, 2021 at 1:45 PM
    R0N
    R0N [OP] Member
    Ron
    2021 Tacoma TRD Off Road 4x4 dual cab manual
    None yet
    Just bought a 21 Tacoma TRD Off Road with Goodyear Wrangler Adventure tires of 265/70R16 size (stock). Goodyear tech chat says no pressure lower than 29psi. Nothing crazy in the way of off-roading as I am new to the “game”. What is lowest tire pressure I can go to in your opinion? Thanks.
  2. Sep 29, 2021 at 1:49 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Look at the placard on the driver's door jamb. It will have the information you are seeking.
    tcjacado likes this.
  3. Sep 29, 2021 at 1:59 PM
    Bishop84
    Bishop84 Well-Known Member
    Standard load I recommend 20-25psi. This provides better traction, less chance for puncture, and less opportunity for the bead to unseat.
    The truck will drive like a cloud.
    I usually do 25psi just because its faster to re-inflate after.
    tacoman45 likes this.
  4. Sep 29, 2021 at 2:00 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    That's for normal driving, not off road.
    Just1n, GuacIsExtra, NH-Taco and 4 others like this.
  5. Sep 29, 2021 at 2:00 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Depends.
    On road- keep it at the placard
    Off road - terrain specific: only deflate as much as needed. In soft sand I really hate going below 15 out of fear of rolling the bead. Rocky stuff, 25 if I'm going slow.
    Hammerstorm likes this.
  6. Sep 29, 2021 at 2:11 PM
    R0N
    R0N [OP] Member
    Ron
    None yet
    Placard says 30. As another mentioned above, I feel this is on road “official “ number. Slower Off roading is another story. Wanting the better traction yet not wanting to roll a tire off the bead. Thanks for all the responses.
    SR-71A and tcjacado like this.
  7. Sep 29, 2021 at 2:12 PM
    tcjacado
    tcjacado Well-Known Member
    Don't go below 10 on stock rims and tires.
  8. Sep 29, 2021 at 2:14 PM
    Knute
    Sure, I understand that. Although, it is a good place to begin.
    It'd sure be a bitch to drop to 15-25 psi to roll a bead off the rim......then your out in the boonies trying to figure out a way to jack up the truck to put on the spare.......
    R0N[OP] and tcjacado like this.
  9. Sep 29, 2021 at 2:16 PM
    tcjacado
    Can of brake cleaner and a lighter will get that bead to reseat:cheers:
  10. Sep 29, 2021 at 2:19 PM
    Knute
    I hear starting fluid (ether) is a common choice. Using that method has some high risk.
  11. Sep 29, 2021 at 2:22 PM
    tcjacado
    Yes, yes it does, but if done properly (nobody gets hurt), it cheaper than a tow.
  12. Sep 29, 2021 at 2:23 PM
    R0N
    R0N [OP] Member
    Ron
    None yet
    This will be a learning process no doubt. I’m trying to avoid the trail mishaps :). Do you feel pressures are tire/rim specific? Or, are generic, don’t go below “x” safe enough (nothing in life is guaranteed) ?
    urshur, LoveableWerewolf and tcjacado like this.
  13. Sep 29, 2021 at 2:26 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    One thought: the more you air down, the less overall clearance you have.
  14. Sep 29, 2021 at 2:28 PM
    Bishop84
    I used to think that, but it makes a massive difference on a trail. Less is more.
  15. Sep 29, 2021 at 2:31 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Personally I like to air down only as necessary given the clearance consideration. Last trail I rode, I was scraping a tiny bit on berms. Didn’t air down. Worked out best, in that situation, for me.
  16. Sep 29, 2021 at 2:45 PM
    tcjacado
    Yes, it matters about tire and rim/wheel.
    Stock is a 16, 17 or 18 × 7... these are narrow
    Most aftermarket will be 8 to 9 inches wide running a 33 e load tire. As I am, I can go down to about 8lbs. Wider wheel, thicker tire.
    Superhulk LB likes this.
  17. Sep 30, 2021 at 6:59 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    If you fear busting a dead just stay home. Seriously, if you go into the outdoors you should have the tools to fix simple stuff. Otherwise, it’s like calling a paramedic for a splinter.
    To keep this on track, adjust tire pressure to load and terrain. If you pop a bead fix it and go up a couple of pounds.
    By the way, regarding the explosive reseating of a tire, have someone who knows how teach you how to do it. I once responded to a fellow that decided to use gasoline. He used too much. Major facial trauma. Rubber isn’t as soft as you think!
  18. Sep 30, 2021 at 7:12 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    As low as you can without throwing a bead.
  19. Sep 30, 2021 at 11:59 AM
    jadatis
    jadatis Well-Known Member
    Peter
    I have a list of Michelin, at wich pressure for load on tire, down to 20kmph/12.5mph used max speed on hard road
    And also for in mud/sand about 50% of that for 20kmph on road.
    For on track about 80% of that for 65kmph/40mph max speed on road
    Those speeds then are the maximum allowed.
    I will have to calculate it for you, but probably your tires are that oversised, that on road upto 99mph, safe lowest pressure is in the 20 psi range, so on track 80% of that is 16 psi, and in mud sand mayby even 10 psi.
    But then before you drive home on the road, you need to highen up the pressure to 20 psi.
    Its then yust how far you want to go.
  20. Sep 30, 2021 at 12:49 PM
    R0N
    R0N [OP] Member
    Ron
    None yet
    Great information! Thank You.
