Milage after gas light comes on?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomaj, Apr 4, 2014.
  1. Apr 4, 2014 at 4:10 AM
    Tacomaj
    Tacomaj [OP] Active Member
    Texas
    Just curious.
    Like in my old Chevy I could expect to get about 30 miles (after fuel light Came on) before I ran completely out.
    What about the Tacoma 2013 v6 tx ed. ?
  2. Apr 4, 2014 at 4:24 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Your answer lies in the owners manual. I don't remember out of top of my head, but I know I saw it in there awhile back.
  3. Apr 4, 2014 at 4:29 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    As many as it takes to get to a gas station.
    Have been forced to run like 35 miles after light, sweating looking for station in unfamiliar area.
    Made it.
  4. Apr 4, 2014 at 4:35 AM
    CorpsmanUp
    CorpsmanUp Well-Known Member
    Gibby
    Suffolk, VA
    2013 Taco DCLWB 6in lift 35s 4.56s, air lockers AP F&R bmpers warn 10k winch Rigid fogs & floods custom pro top shell
    6in procomp stage 2 lift with PC Coilovers, 35x12.50 Nitto MTs, Moto metal 18x10 with -44 offset HID and LED's everywhere, ladder bars, rear disk brake conversion, hood struts, K&N cold air intake, Flowmaster 40 series, pro comp skid plates, train horn, pa system, all silver trim inside painted black all pro apex front bumper with full hoops warn 10k winch, all pro high clearance rear bumper with custom door hinge tag holder, pro top custom windowless camper shell. ARB onboard air compressor, rear ARB air locker, 4.56 gears front and rear, waterport pressurized water system, pop and lock tailgate.
    pretty sure you've got about 2.5 or 3 gal left when the light comes on i've got a 13 trd sport and sweating to death and made it 50+ miles after light on hwy
    although wouldn't advise pushing it that close cause if i remember right it took like 20.5 gal or so to fill it up and they are like 21.1 gal tanks
  5. Apr 4, 2014 at 4:39 AM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I've got over 60 miles a few times. Best way to check, as soon a your light comes on, fill up, subtract the gallons from overall tank capacity, multiply that number by your MPGs and that will be your answer.
  6. Apr 4, 2014 at 4:43 AM
    CorpsmanUp
    Gibby
    Suffolk, VA
    quick off subject moment here but, ramon where'd you get your roll bar????
  7. Apr 4, 2014 at 4:44 AM
    Smoke
    Smoke Well-Known Member
    Eastern Ontario
    2006 SR5
    Thats some what concerning.. lol. I rarely ever let mine get below 1/4 tank.
  8. Apr 4, 2014 at 4:45 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    From my observation, its roughly <4 gallons of gas remaining once the needle gets to that 1/8" space away from E, both in my truck and my 3rd gen Rav4. Tacoma has a 21 gallon tank, Rav4 has a 16 gallon tank...Tacoma fills up about 16-17 gallons when I let it get low, Rav4 takes 12+ gallons when the light comes on.
    IMO, Toyota does the fuel gauge smart...make you think your are using less fuel than you really are when there is greater than 1/2 tank, then make you realize you really are using gas when there is < 1/2 tank . Its not like this with other manufacturers.
  9. Apr 4, 2014 at 4:46 AM
    Tacoma VT
    Tacoma VT Well-Known Member
    R. Kessler
    Vermont
    10 DCLB TRD sport
    OME 884s, Bilstein 5100 Shocks, Icon 3 leaf progressive AAL (with overload in), Rear leaf TSB, ImMrYo mirror relocater, ARE Z series cap, Hi Lift jack W/ DIY mount, trimmed Mud Flaps, Devil Horns by Andres, EGR In-Channel rain guards, LED bed lights, Weather Techs
    2.5-3 gallons
  10. Apr 4, 2014 at 5:01 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    I have refueled several time almost immediately after the light comes on and I consistently put in about 17 gallons, leaving right around 4 left in the tank. With a conservative estimate of 12mpg (I know I get more) I expect to make it ~50 miles without any issues. Not really good to run them down that low though.
  11. Apr 4, 2014 at 6:22 AM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    I ran 31 miles after the light came on and put in 18.5 gallons yesterday. Makes me think it comes on around the 17 gallon mark or so.
  12. Apr 4, 2014 at 6:23 AM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    the light comes on with 4 gallons left in the tank
  13. Apr 4, 2014 at 6:28 AM
    ssanders2211
    ssanders2211 Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, sliders, ATO plate rear bumper, hood/bed lighting, always-on 12v outlets, dashcam, Viper 5806V w/ GPS
    Does anybody know how much gas you need to leave in the tank to keep the fuel pump cooled?
  14. Apr 4, 2014 at 7:00 AM
    TheMuffinMan
    Coeur d'Alene, ID
    About a half gallon to a gallon.
  15. Apr 4, 2014 at 7:03 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    None, the pump is cooled by the fuel running through it, not the fuel it is immersed in. You would need to keep the tank 3/4 full at all times if that was the case.
    I can (And regularly do) drive about 60 miles after the light turns on. this was the same as my 99' 4runner, they "reserve" is much larger than a GM
    06Tacooo likes this.
  16. Apr 4, 2014 at 7:04 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    My experience ... right around 4 gallons in tank when light comes on. FWIW
  17. Apr 4, 2014 at 7:24 AM
    billinwoodland
    billinwoodland Well-Known Member
    Bill
    N. Cal
    Talking about fuel pumps, I have always been told not to let the fuel get so low that the light comes on as the pump is sucking up bottom debri and it affects the longevity of the pump.
  18. Apr 4, 2014 at 7:30 AM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    I have not tried that yet, don't plan on doing so.
    When I reach just below a 1/4 tank, I'm at the gas station.
  19. Apr 4, 2014 at 8:59 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Doesn't make sense - the tank pickup is fixed at/near the bottom of the tank, so it wouldn't make any difference on picking up bottom debris whether the tank was full or almost empty. Also, pump is cooled by gas flowing thru it, not from pump being immersed in fuel.
    BTW, on a long trip, especially when I will be driving over 50 miles after a fillup, I will fill my truck to the very top. Am able consistently to put in 2.5 gallons after the filler clicks off (slow process, and I only do on a road trip). No codes or problems in 47,000 miles. Have put 21 or more gallons in the tank several times. I also did this deliberately to initially calibrate my ScanGauge to set the fuel used adjustment factor, since the variances between pump pressure, whether or not someone else is using the other side of the pump, whether or not the ground at the pump is flat, phase of the moon (kidding) all make an accurate "fill" a crap-shoot anyway.
    One last thing - manual does NOT address how much gas is left when the light comes on, at least not in my 09 manual.
  20. Apr 6, 2014 at 3:38 AM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    One other thing, if you have a ScanGauge, recalibrate distance about every 10-15,000 miles to correct for tire wear, which keeps your SG speed and mpg more accurate. Replacing worn tires with new gained a full inch in diameter, took about a 5% adjustment.
