Midas sucks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nalpak99, Jul 28, 2024.
  1. Jul 28, 2024 at 7:52 AM
    Nalpak99
    Nalpak99 [OP] Booty Hunter
    Kyle
    2005 Toyota Tacoma pre-runner
    mid travel
    I was about to drive my truck up to collage and I was putting new brake bleeders on as the old ones were getting rusty. I couldn’t get any fluid to come out of the new ones so I eventually gave up and took it to my closest shop, Midas, To see what they would say. After 2 days of me going back and forth with them, they said my new bleeders are clogged and so is my master cylinder. So I said screw it if you guys are going to fix it back to 100% then I’ll pay the $600 in repairs as I need to drive this truck from Cali to Idaho the next week.
    after 5 days of going back and forth with them because they couldn’t get all the air bleed out they said they finally got it right. I picked it up and the pedal was extremely soft. But I needed to leave so I had no choice but to deal with it when I got to Idaho.
    fast forward a few months, yesterday, I decided I should adjust my drums as they haven’t been adjusted in a while. After I flushed the job I was pumping the pedal just to see how it felt with the car off. And I think I found the problem. With the truck off and all air out of the brake booster, the pedal goes half way down (to the height of the gas pedal) before it is stiff. I’m thinking the push rod was never adjusted when Midas put the new master cylinder on. Is the push rods even adjustable in these? Any help or recommendations would be appreciated!
    I know that the gap is not from my drums because if I put the parking brake all the way down it’s the same way and the parking brake is super stiff.
    OffroadToy likes this.
  2. Jul 28, 2024 at 8:53 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    :rofl:
  3. Jul 28, 2024 at 9:04 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    Op apologies I can’t answer whether the push rod is adjustable as I never had to service it, I just wanted to let everyone know of the replacement bleeder part numbers:
    47547-04010 for the fronts and 47547-12010 for the rears
    and that this works:
    Motive Products 0101 Universal Power Bleeder 2-Quart Tank with Hose and Round Adapter https://www.amazon.com/dp/B00CJ5DWKO
    I also made a homemade master cylinder adapter:
  4. Jul 28, 2024 at 9:29 AM
    TacoTuesday1
    FL
    Water is wet.
    I don’t think Midas is a mechanic shop nor do mechanics work there.
    I might have to try this.
    Kind of disappointed with Motive right now. Bought their bleeder which from day one leaked at the gauge. Contacted them and to date they’ve done nothing about it.
    haven’t figured out how to make it fit my Toyota res adapter power probe ba10 (quick connect style) which it seems many other company bleeders fit.
    ToyoTaco25 likes this.
  5. Jul 29, 2024 at 8:55 AM
    Nalpak99
    Kyle
    mid travel
    What’s wrong with the normal way of bleeding? I am not a mechanic and have only done the old grab a buddy to pump the brakes.
  6. Jul 29, 2024 at 9:03 AM
    Nalpak99
    Kyle
    mid travel
    I’m an engineer for a reason, can’t spell but great at math. haha.
    Squirt and OffroadToy[QUOTED] like this.
  7. Jul 29, 2024 at 9:03 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Motive used to make a version with the quick release chuck for those master cylinder adapters. I have one on mine. Still might. It was on their site.
  8. Jul 29, 2024 at 9:16 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Just be careful. Some brake pedal strokes are greater than the thickness of a vacuum-operated power booster and when you reach the limit of the diaphragm in the booster you could damage it. It happened once to me.
  9. Jul 29, 2024 at 9:45 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    This is typical of these type of jobs given to people with no experience or training nowadays. So your results and what you pay will reflect the individual’s experience.
  10. Jul 29, 2024 at 9:55 AM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    Midas expensive, possibly all stupid. I went one time from other crap, never again did I go back. If bleeder screws was that @#$! up, instead of back and forth crap, they suppose to quoted you, new front loaded brake calipers, and rear wheel cylinders
  11. Jul 29, 2024 at 12:48 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Cut him some slack he’s an art major
  12. Jul 29, 2024 at 1:49 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    works well for me for past 40 years
  13. Jul 29, 2024 at 2:06 PM
    Clearwater Bill
    Billy
    Largo Florida
    The quality of any shop is subject to the quality and oversight of the management, including making good hires, keeping training up to date, releasing problem employees, etc.
    This is even more noticable in big box shops and franchises.
    I'd wager there are some very good Midas, Firestone, Gooyear and even Jiffy Lube shops. But if you don't know the management personally, or a least a high ranking staffer, IMHO you're taking a significant risk in using such places
  14. Jul 29, 2024 at 3:50 PM
    Micbt25
    TM
    This way is simpler, no need for a second person and from what I understand it’s easier on the internal components of the master cylinder.
  15. Jul 30, 2024 at 6:00 PM
    TacoTuesday1
    FL
    the normal way is a pressure bleeder. That is guidelines. It is easier and cheap.
    if you want to deviate by throwing hammers at the engine though that could be good just post a video for entertainment. Gotta spice up life.
    I have a clutch. Manual is not gonna cut it. Nor would it with ABS.
    if I wanted a bleed I’d grab a $50 pressure bleeder. If I wanted a shitshow I’d grab another person. To each his own can’t all do it right.
    Micbt25 likes this.
