Mid-repair Help!!! Master Cylinder Gasket???
Discussion in '1st Gen. Tacomas (1995-2004)' started by OleRomer, May 4, 2017.
  1. May 4, 2017 at 6:58 PM
    OleRomer
    OleRomer [OP] Professional Vagabond
    Brandon
    Utah/Wyoming
    04 Tacoma –- Ole Rømer
    ICON 2.5 Ext Travel C/O, Camburg UCAs, AllPro Expo Leaf Springs, ICON 2.0 RR Shocks, ARB/RAT/BAMF/CaptureColorado Armor, Dual Optimas Red/Yellow, 133w Solar System, Custom Bed Build, etc., etc.
    Is there a gasket to replace between the MC and brake Booster?!
  2. May 5, 2017 at 3:19 PM
    Glamisman
    Glamisman Well-Known Member
    yes there is at least on my 2002 Prerunner.
  3. May 5, 2017 at 10:25 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  4. May 5, 2017 at 11:21 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    The gasket is to keep water from getting in between master and booster. There is a seal like the one in the link that seals the vacuum.
  5. May 6, 2017 at 2:22 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Must be something new or mine was gone before I bought the truck
  6. May 6, 2017 at 12:42 PM
    OleRomer
    Brandon
    Utah/Wyoming
    Thanks everyone, I wound up using some RTV that I had around after learning it's just too keep things clean.
    Brakes work again! :woot:
    Dalandser likes this.
  7. May 6, 2017 at 1:38 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    they have a thin wax gasket from factory but its no big deal if yours is missing you can make a new one from wax paper if you like.
    as mentioned its just there to keep water out if your hosing off under the hood
  8. May 6, 2017 at 1:49 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I can see this now time to source a new booster the liquid brine will be in there and it will crumble to pieces here one day soon
    I would much rather rebuild a frame then mess with a brake booster only because of the location
  9. May 6, 2017 at 1:55 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Great.
    But its masking the real problem of the seal inside booster that seals around the rod or master cylinder leaking.
  10. May 6, 2017 at 2:09 PM
    keakar
    karl
    louisiana
  11. May 7, 2017 at 2:07 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Some what serious only because that is how my luck tends to go.
    keakar likes this.
  12. May 7, 2017 at 8:50 AM
    keakar
    karl
    louisiana
    just pull the master cylinder out a little bit and add a smear of silicone behind it and then your good or just make a gasket for it. dont even need to disconnect the brake lines. the vacuum seal is around the inner cylinder part and not where the flange part is anyway
  13. May 14, 2017 at 5:25 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    How well will this work? It seems that I may be having the same leak.
  14. May 14, 2017 at 7:50 AM
    keakar
    karl
    louisiana
    this comment was only about how to replace the dust seal between the master cylinder and the brake booster. it doesn't do anything but keep stuff from getting in there if you hose down stuff under the hood.
    if you have a leak of vacuum around the inner seal then that is something different and most likely you need a new brake booster if the seal wasn't just pushed out of place where it can just be repositioned properly. I guess it wouldn't hurt to pull the master cylinder out and see what the seal looks like but brakes are something not worth taking chances with. when it comes to brakes, if there is ANY doubt, just put new parts in to replace it. brake failure CAN literally kill you
    JPinFL[QUOTED] and mechanicjon like this.
