Mickey Thompson's Baja Boss A/T
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Micbt25, Mar 26, 2024.
  1. Mar 26, 2024 at 3:46 AM
    Micbt25
    Micbt25 [OP] Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    Anyone running the Baja Boss AT in 265/70R17 with load range LT. Right now, I’m running BFGoodrich - All-Terrain T/A KO2 in 265/70R17 in C. Just seeing how you like the tire, wear and tear, rideability and traction. Thanks
  2. Mar 26, 2024 at 10:39 AM
    TacoTuesday1
    FL
    People don’t like KO2’s.
    If I got Baja Boss tomorrow it would be 35. Got Kenda instead. It is cheaper.
    I’ve heard good things about Baja Boss. It’s probably better than KO2.
    I’d have no second thoughts about quality. Only second thought was the fact it’s like $350 a tire vs $200 Kenda.
    jackn7 and Micbt25[OP] like this.
  3. Mar 26, 2024 at 10:44 AM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    They're very very good tires, much better than K02 especially in the wet and snow. However - keep in mind that they are a heavy tire in load e configuration. 58lbs for the Mickeys vs the 44lb load c K02's you're running currently. If you don't need the extra plies then you can go with the load XL's in the same size for only 44lbs, same as what you're running currently.
    Micbt25[OP] likes this.
  4. Mar 26, 2024 at 11:30 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
  5. Mar 26, 2024 at 3:48 PM
    Micbt25
    TM
    What’s the difference between Cs and SLs, I’ve looked it up, but din’t really get a clear answer.
  6. Mar 26, 2024 at 3:49 PM
    Micbt25
    TM
  7. Mar 26, 2024 at 3:58 PM
    Naveronski
    Fort Worth
    So you saw that and somehow thought we needed a new thread to address "how you like the tire, wear and tear, rideability and traction"? Like a multi page discussion thread would be a bad place to find that information?
  8. Mar 26, 2024 at 4:04 PM
    Micbt25
    TM
    Yes
    02Duck, doublethebass and jackn7 like this.
  9. Mar 26, 2024 at 4:36 PM
    Micbt25
    TM
    To be completely honest, I searched this 2nd generation forum for the Mickey Thompson tire and initially I saw treads here and there, but nothing substantial. I added my post, prior to finding the mother load post, hind sight, I probably wouldn’t have posted my thread. However, I appreciate your 2 post, although unhelpful, to an unnecessary forum.
    jackn7 likes this.
