Mickey Thompson Baja Boss ATs 255/85/17 Skinny 35s
Discussion in '4th Gen. Tacomas (2024+)' started by Gmak621, Nov 25, 2024.
  1. Nov 25, 2024 at 7:46 PM
    Gmak621
    Gmak621 [OP] Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Little teaser pic of some 35s I mounted up today on a second set of wheels I found locally.
    Mickey Thompson Baja Boss ATs 255/85/17 (35x10R17) 63lbs.
    The TRD off-road wheels weigh 27lbs if anyone cares.
    I removed the crash pad, not entirely sure it would’ve mattered though. They seem to clear everything without rubbing. I do have one inch Spidertrax installed along with coilovers and rear coils.
    It was dark and rainy, will get some better pics up tomorrow.
    I’ll be driving it to work tomorrow and will have a better update on them.
    max911, BearWithMe, Fast1 and 8 others like this.
  2. Nov 25, 2024 at 9:47 PM
    xykogoalie
    xykogoalie New Member
    Jordan
    Vancouver, Canada
    2022 Midnight Black Taco Off-Road
    Beauty! Mine arrive in a couple weeks!
    Gmak621[OP] likes this.
  3. Nov 25, 2024 at 10:22 PM
    hillcountrytacoma
    hillcountrytacoma New Member
    Alex
    2024 Underground Tacoma TRD Offroad
    How does it ride?
  4. Nov 26, 2024 at 2:46 AM
    monomial
    monomial Active Member
    2024 Silver Tacoma 4X4 SR5
    I prefer a tall skinny tire also. I saw a show that tested the contact patch of wide vs narrow tires and the narrow tire actually had the largest patch. Kind of counter intuitive but makes sense after seeing the video.
    What is a crash pad?
  5. Nov 26, 2024 at 6:46 AM
    Gmak621
    Nørth Çøast
    2024 TRD ØR
    Same. Always liked a skinny tire.
    Im not sure if that’s the correct name for it. But it’s the removable piece that is behind the front wheels. Normally where previous Tacoma’s would do cab mount chops to clear larger tires. It just unblots and gives a lot more space to fit larger tires.
  6. Nov 26, 2024 at 6:47 AM
    Gmak621
    Nørth Çøast
    2024 TRD ØR
    Will have an update later today on that.
  7. Nov 26, 2024 at 6:50 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Your tires look awesome! They are 33s
    https://www.tacomaworld.com/tirecalc?tires=255-85r16-255-80r17
  8. Nov 26, 2024 at 6:53 AM
    Gmak621
    Nørth Çøast
    2024 TRD ØR
  9. Nov 26, 2024 at 6:57 AM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    Awesome! Your right, I was thinking of the 80 version
  10. Nov 26, 2024 at 7:08 AM
    banditcamp
    banditcamp Well-Known Member
    daniel
    2015 Super White DCSB Off Road
    At places like tire rack the that is the only tire in a 255 85 17. The specs seem great on it. Almost made me want to go to a 17 inch wheel. I'm looking forward to updates on what you think of them.
  11. Nov 26, 2024 at 6:10 PM
    Gmak621
    Nørth Çøast
    2024 TRD ØR
    Got a chance to put 75 miles on them today. Overall impressions:
    • They are quiet on the freeway, considering how aggressive they look
    • A fare amount more firm than my P285/70/17s
    • I’m running about 40psi front/38psi rear. May need to make an adjustment(chalk test?)
    • The motor is barely affected. Uses more boost obviously, but doesn’t downshift any more than before
    • Roll smoothly and turn-in is sharp
    • Was able to use dash instrument cluster to register a second set of wheels/TPMS after a few tries
    tonymac, Fast1, PDKTaco and 3 others like this.
  12. Apr 20, 2025 at 7:11 PM
    BearWithMe
    BearWithMe Well-Known Member
    Four Corners
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    @Gmak621 How are these Mickies holding up? Are you still liking them? How are the MPGs?
    Wish we had more than one tire choice in 255/85/17!
    PDKTaco likes this.
  13. Apr 20, 2025 at 10:37 PM
    Gmak621
    Nørth Çøast
    2024 TRD ØR
    Pretty good so far. These are my second set of wheel/tires I use in the winter months. They’re heavy but ride pretty well and track pretty well. Did excellent in heavy snow, and good in rain. I recently switched back to my smaller set of 285/70/17. MPGs with the 35s was 16mpg and mpgs with the 33s are 19mpgs
    BearWithMe[QUOTED] likes this.
  14. Apr 20, 2025 at 10:40 PM
    Gmak621
    Nørth Çøast
    2024 TRD ØR
    There’s always the Kenda Klever 35x10.5r17
    PDKTaco likes this.
