Michelin LTX M/S 2 - Initial Thoughts (Now LTX Defender)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kyitty, Apr 23, 2015.
  1. Sep 12, 2019 at 10:13 PM
    #241
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Just ordered a set through Discount tires. Getting them mounted next Wednesday. I can't wait! :woot:
    stbear likes this.
  2. Sep 13, 2019 at 6:08 PM
    #242
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    ^^ same here about the side walls. I had Michelin LTXs on my previous vehicle and they were quiet, comfortable but the side walls were cracking after about 4-5 years. I replaced them although there were a plenty of tread left. I’m not sure if I would buy them again to be honest.
    TRDSport10 likes this.
  3. Sep 13, 2019 at 7:03 PM
    #243
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    The new Defenders have an updated rubber compound. I'm wondering if they'll maybe not crack like the MS2's.
  4. Sep 14, 2019 at 1:05 AM
    #244
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Had LTX MS on my old Suburban and then 2 sets of LTX AT2 on the Tacoma and after 50k miles I noticed on all the sets that traction is not there dry or wet as before. Easier to spin them or slide more - just a point to mention. Really long wear ratings are what they are but by 55k I change them out always for safety even when I could run them a lot longer.
    Not worth an accident to me. Another thing that the tire stores now all do is limit their tire hazard warranty to 3 years when they did not before.
    R0dzilla75 likes this.
  5. Sep 16, 2019 at 5:24 AM
    #245
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    I'll be buying my 3rd set soon, second for tacoma (defenders). In reality i will probably get 65k from them, an estimate as i also run snow tires. I like running both sets, i feel i get much more bang for the buck on tires as i can run them down further without worry of next snow season. Even the snows i'll run in summer when i know they are done for next winter (studless).
    This winter i'll run the defenders in the snow, they do decent when new and ill buy snow's next winter. My current defenders i have about 4 years on them, no cracking but they are a little hard.
    This may be a post for another thread, but i would recommend to anyone to run dedicated snows if your situation warrants it. I have long commutes to work on back roads, and a harry driveway. I've done the math, running premium tires, defenders and blizzaks, till they are done is almost the same exact cost as a cheap tire. The miles/dollar is very close.
  6. Sep 16, 2019 at 5:42 AM
    #246
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    The first thing I noticed about my Michelin defenders is how much less wheel weights It took to balance them.
    My truck rides so smooth and very quiet.
    teamhypoxia and stbear like this.
  7. Sep 16, 2019 at 7:32 AM
    #247
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Im so stoked guys!!!!! After almost a year of Michelin not producing the Defender LTX 265/75R16 in the SL / 116T rated (Non LT) tire.... they started producing them again. Going to get my set put on this week sometime when they show up to the tire store.... im so done with my shitty loud / heavy / crappy traction Cooper AT3's
    teamhypoxia likes this.
  8. Sep 16, 2019 at 7:44 AM
    #248
    spitdog
    Wait until there on sale. They have promotions all the time. I got a $70 Visa card. I bought mine through tire rack, they were at my installer the next day. Simple process with tire rack. They will list preferred installers in your area.
  9. Sep 16, 2019 at 8:03 AM
    #249
    nd4spdbh
    SoCal
    Did even one better. Costco was having a 70 instant rebate + 40 off installation. Went to the local Americas tire (Aka Discount Tire) and they matched all of that and then some. Was out the door cheaper (without any MIR's) than costco, with much friendlier and better service now / in the future WITH road hazard warranties. Going to keep the old tires n sell them too.
    The defenders definitely are not the cheapest... but i have ALWAYS kicked myself for not going with them on the last 3 sets of tires on the truck... all cus i wanted the AT tire look, i gave up actual drive ability in ALL other categories for it.
  10. Sep 16, 2019 at 8:38 AM
    #250
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    No mail in rebates at Costco and I have always had great service there compared with some tire stores. Only needed road hazard warranty once and no hassle.
    Great on out the door cheaper.
    nd4spdbh[QUOTED] likes this.
  11. Sep 20, 2019 at 11:43 AM
    #251
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    LOL, of course! I waited for almost a year before I gave up and went 265/70/16.
    Having said that - I’ll likely go with 265/70/16 again when it’s time to replace. The truck looks well balanced and practical with the stock size. No complaints from me, and there is no performance different off-road with the slightly larger size. Im so old!
  12. Sep 20, 2019 at 11:59 AM
    #252
    nd4spdbh
    SoCal
    aww sorry man!
    Are you lifted?
    I know i dont like the look of the stock size on my truck with its 2in lift. Holes just arent filled properly IMO.... haha.
    Edit... .Also this is me right now.... appt is at 4pm today to get em put on!
  13. Sep 20, 2019 at 12:12 PM
    #253
    spitdog
    I also chose the 265/70/16 after a lot of research. I think they are a practical size for a non lifted truck.
    They ride nice and quiet with no mpg loss. I will also replace with same.
  14. Sep 20, 2019 at 6:31 PM
    #254
    Accipiter13
    California
    '11 DCLB 4x4 Sport
    I slapped on a set of 3rd gen off road wheels at the same time - really like the look. Updated and clean.
    spitdog[QUOTED] likes this.
  15. Sep 20, 2019 at 6:33 PM
    #255
    Accipiter13
    California
    '11 DCLB 4x4 Sport
    No lift, I felt that a new set of wheels (3rd gen OR takeoffs) did more to update the look of the truck than anything. I could definitely see the larger size on a lifted truck.
  16. Sep 21, 2019 at 9:58 AM
    #256
    nd4spdbh
    SoCal
    3rd gen trd OR rims with 265/70R16 defenders probably looks DAMN good on a stock height truck.
    Got my truck back from the tire shop yesterday with my nice light new Defender LTX MS's 265/75R16 116T's.... INSTANTLY noticed the less rotating mass. and OH MY GAWD, so quiet. I can hear myself think again.
    840 OTD, with road hazard and tax. (7.25%)
  17. Dec 3, 2019 at 9:42 AM
    #257
    ejl923
    Eric
    Western Mass
    Wanted to update here. I put a plow on the taco, and before i can get my snow tires on i have pretty new Mich defenders on. I am very impressed plowing my STEEP drive. I really couldnt ask for more from them. If it wasn't for the incline, i would stick with them but i like the added assurance. Still my favorite tire.
  18. Dec 3, 2019 at 2:01 PM
    #258
    Accipiter13
    California
    '11 DCLB 4x4 Sport
    Ok I think I figured out how to add photos. Took this earlier this year doing a little driving for wildflowers.
    Ehahn84, ppham444 and nd4spdbh like this.
  19. Dec 3, 2019 at 4:52 PM
    #259
    TacomaWilly
    TacomaWilly Well-Known Member
    I bought my truck in April 2015 with Defender MS 265/65/R17. Put 80K on them and they need to be replaced now. I can't compare them to other tires but after reviews and how great they seem to be I will be buying the same tires again. Right now they are past the tread wear indicators and still have good traction, even in the snow which is surprising.
    stbear and teamhypoxia like this.
