Mfr body codes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NewRider, Nov 14, 2013.
  1. Nov 14, 2013 at 10:22 AM
    NewRider
    NewRider [OP] Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    So I feel as if I'm a pretty apt mechanic and know most of what I usually need to know but I can't figure this out. Was looking up some stuff on Amazon and it's asking for my "mfr body code"? A google search directs me to my VIN which was my first guess but none of the available option match, or look anything like any part of my VIN.
    here are the options:
    GRN245
    GRN250
    TRN220
    TRN225
    TRN240
    TRN245
    My truck is an 06 AC TRD Sport if anyone knows off hand which coed is correct for me
  2. Nov 14, 2013 at 10:29 AM
    NewRider
    Travis
    '87 4runner
  3. Nov 14, 2013 at 10:29 AM
    BamaToy1997
    Bill
    Navarre, FL
    Look on the label on the inside driver's door jamb. You will find a matching code there.
  4. Nov 14, 2013 at 10:48 AM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    OP, did you really bump a thread after 7 min? Next time check the manual first :notsure:
    Takemehome678 likes this.
  5. Nov 14, 2013 at 3:12 PM
    NewRider
    Travis
    '87 4runner
    Thank you... And to the other post: I've learned through lots of expeierence to typically ignore the owners "manual" on anything over the basics because it's not intended as a shop manual (which I haven't yet bought) and usually isn't helpful for most of what I need to know.
  6. Nov 14, 2013 at 3:24 PM
    ziggynagy
    Stoughton, MA
    Well the attached excerpt from the manual should answer your question (and save you a trip to garage).
  7. Jan 18, 2019 at 3:39 AM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    OP, did you ever find this out? The body code?
  8. Jan 18, 2019 at 1:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Zombie...
    Read the entire thread the answer is in there.....
  9. Jan 18, 2019 at 1:36 PM
    drewskie
    Drew
    Burbank, CA.
    I did. Still can't figure it out.
  10. Jan 18, 2019 at 1:38 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    How about here. ( Hint: Look at the label in the door or the attached link below ).
  11. Jan 18, 2019 at 1:42 PM
    drewskie
    Drew
    Burbank, CA.
    Noice. You da man. Thank you.
