Metal oil filter housing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bigkracka, Jun 2, 2023.
  1. Jun 2, 2023 at 9:34 AM
    Bigkracka
    Bigkracka [OP] Well-Known Member
    Tx
    20 Tacoma SR5 Crew Cab V6
    How do I make sure to get the correct metal oil filter housing for 2020 v6 sr5 double cab tacoma?
  2. Jun 2, 2023 at 9:36 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Did your truck not come with the oil filter housing that was designed for it?
  3. Jun 2, 2023 at 9:48 AM
    happyvirus
    happyvirus Well-Known Member
  4. Jun 2, 2023 at 9:58 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    How is this response helpful to the OP?
    Nevin, 23MGM, Barsoom and 19 others like this.
  5. Jun 2, 2023 at 10:06 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I think OP is looking to replace the plastic housing with an identical metal one to avoid possible issues
    Barsoom, D.A.S. Taco and HondaGM like this.
  6. Jun 2, 2023 at 10:30 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Keep in mind it isn't a drop-in replacement. You need to swap over the correct height center tube from your old housing.
    Use plenty of oil to lubricate the threads as aluminum-on-aluminum will gall, which is the reason Toyota switched to plastic in the first place.
    Plaintaco, RIX TUX, golfindia and 6 others like this.
  7. Jun 2, 2023 at 10:32 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Except for alum vs composite, it appears the 3.5 engines use the same oil canister. Our 07 ES350 Lexus has alum, but our 18 RX350 had composite, it now has an alum - part # listed above. Make sure you get from a dealer to ensure it is oem. I would not count on the quality of china-made canisters. Even if the oem canister is china made, quality control will be higher. Our RX also has composite valve covers, not a fan of that but it is what it is.
    Zuba Gooding Jr likes this.
  8. Jun 2, 2023 at 10:34 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I switched to the aluminum and then back to the composite. The composite cools down more quickly after the engine stops running. I see no problems the aluminum solves. Save your money.
    RIX TUX, pdxTacoSR5, MannyS and 2 others like this.
  9. Jun 2, 2023 at 10:38 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You should not have any issues with the composite if it’s installed correctly. The problem is, that a lot of people crank the housing on too tight.
    The way the housing is designed, it doesn’t seal any better the tighter you get it. Snug is good enough.
    shakerhood, SR-71A, HondaGM and 3 others like this.
  10. Jun 2, 2023 at 11:09 AM
    Chuy
    Lakeside, CA
    Silver Taco
    There is a general mistrust in the durability of composite vs alum. As to heat dissipation, it could be that composite insulates better, thus it feels cooler to the touch on the outside. For example, I know glass fibre reinforced plastics have significantly lower thermal conductivity but better insulation properties over alum. I don't know what materials are used in Toyota filter canisters but I think it has to do more with cost production than heat dissipation. There was mention of galling, our ES350 with 290K and an oem alum housing has had no galling. It could be that the motor oil residue on the threads helps prevent galling. Point is, I’ve never lubed the threads.
  11. Jun 2, 2023 at 11:16 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    There is no issues with the composite one, unless you have a brain dead mechanic with the wrong tools doing the job.
  12. Jun 2, 2023 at 11:31 AM
    ToyoTaco25
    North Carolina
    lol I know....but the plastic housings that come stock work just fine. It's the morons that don't use the correct tools that create the "issues".
    zoo truck likes this.
  13. Jun 2, 2023 at 11:33 AM
    ToyoTaco25
    North Carolina
    How is your response helpful? I'm just saying that there is nothing wrong with the OEM plastic housing.
  14. Jun 2, 2023 at 11:44 AM
    Buck Henry
    Nice try!
    HondaGM likes this.
  15. Jun 2, 2023 at 11:53 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    SR-71A and TnShooter[QUOTED] like this.
  16. Jun 2, 2023 at 12:48 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Still using the plastic one on my 16 and zero issues. Save your money.
    zoo truck and HondaGM like this.
  17. Jun 2, 2023 at 12:52 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    You're telling the OP to keep his truck stock. We don't do that here :smack:
    HondaGM likes this.
  18. Jun 2, 2023 at 2:25 PM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    What is wrong with the center tube? I have this part with two part #'s on the box label. #15620-31060 as well as 15643-31050 and all looks good.
    5nahalf and HondaGM like this.
  19. Jun 2, 2023 at 5:01 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^If the center tube is the same height as the original one in your truck, then all is good. IIRC the center tube in the aluminum housing was a different height.
    HondaGM likes this.
  20. Jun 2, 2023 at 5:13 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    only if you buy a generic/Amazon metal cannister, and not the oem. I swapped mine with oem but, I am not near the garage to provide an exact fit part number I used on my 2019 sport 3.5 l V6.
    Ski
    HondaGM likes this.
