MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Feb 20, 2019 at 8:39 AM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    My latest creation from the MESO lab:
    THE TOTAL TAIL LIGHT KIT
    What is it exactly? Well, not only is it a full LED replacement.. but more importantly it is a complete plug and play wiring harness that redirects the placement and function of the Brake, Turn, and Reverse lights.
    This kit will take the turn signal(which is currently RED and located in the upper section of the tail light) then change it to AMBER and relocate it to the reverse section of the housing. It will also turn the Original brake light(located in the bottom half of the Red "horseshoe") and double the size, turning it into a full solid "C". Essentially, this brings back amber turn signals(which have been on every Tacoma up until the 3rd Gen) and gives you a much larger, more visible brake light. A WIN-WIN.
    It is available in 2 stages;
    STAGE 1-STAGE 2
    Both are brighter than the factory. And both plug into the wiring of the truck with all OEM waterproof connectors. FULL PnP.
    S1 uses a custom made switchback for the reverse hole. 100% DROP IN.
    S2 is brighter, but will require a small modification to the reverse socket of the light housing. In order to clear the new larger bulb.(video below)
    Stage 1: $150
    Includes:
    - 2 wire harnesses with all OEM connectors
    - 4 Red custom 7443 Brake LEDS
    - 2 custom switchback bulbs(reverse/turn)
    STAGE 2
    ***SOLD OUT***
    Includes:
    - 4 VLED 7443 Red bulbs
    - 2 VLED V6 Triton Switchback Reverse/Turn bulbs
    - 2 Tritton Bulb adapters
    To give a better visualization, here is a short video of the Total Tail kit VS Stock
    https://youtu.be/4gzzecHi79c
    Overview of how easy the installation is:
    https://youtu.be/R1e5iTmd5S0
    For stage 2 this is the modification that will need to be done:
    https://youtu.be/PbCZHWGWozU
    TacoDash89, ziggy261, poncer and 54 others like this.
  2. Feb 20, 2019 at 8:40 AM
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
    ITS TIME!!!!!
    jnjoiwngs, Nunya Bizness and KTJO 4x4 like this.
  3. Feb 20, 2019 at 8:40 AM
    Unreliable
    Unreliable Member
    Honolulu, Hi.
    2019 Quicksand DCLB TRD OR 4x4
    I'll take a Stage 1 Please!
  4. Feb 20, 2019 at 8:40 AM
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    still sold out lol
  5. Feb 20, 2019 at 8:40 AM
    Twister
    Twister Well-Known Member
    CJ
    #BBN , KY
    22 Lariat
    Sweet
  6. Feb 20, 2019 at 8:40 AM
    NEPAChuy
    NEPAChuy Well-Known Member
    Jeremy
    2018 Tacoma TRD OR Blue Pearl
  7. Feb 20, 2019 at 8:41 AM
    savethewheels
    savethewheels Well-Known Member
    Nashville, TN
    truck
    still says sold out (?)
  8. Feb 20, 2019 at 8:41 AM
    baileyjfit
    baileyjfit Well-Known Member
    Bailey
    Texas
    2017 Stormtrooper
    We’re no longer living in the days where people are saying they rear ended someone because they couldn’t see their brake lights. Now their excuse is that the brake lights blinded them.
  9. Feb 20, 2019 at 8:41 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    Always the innovator
    SandyTaco4x4 and MrBrooks like this.
  10. Feb 20, 2019 at 8:41 AM
    Totall4285
    Totall4285 Well-Known Member
    Palm Harbor, Fl.
    2017 Tacoma TRD Sport
    Open sales already
  11. Feb 20, 2019 at 8:42 AM
    NEPAChuy
    Jeremy
  12. Feb 20, 2019 at 8:42 AM
    dskakie
    dskakie Well-Known Member
    Dan
    Northern CA
    2016 TRD OR DCSB
  13. Feb 20, 2019 at 8:42 AM
    boywonder77
    boywonder77 Well-Known Member
    Bay Area
    2018 Tacoma Cement DBSB TRD Sport
  14. Feb 20, 2019 at 8:42 AM
    quikandskinny
    quikandskinny Well-Known Member
    2016 Blue Tacoma TRD OffRoad
    Black badging, TRD Pro Grille, Morimoto Elite+ headlights, yellow fogs (soon to be Kustom54 Amber...), white xenon interior LED swap, ShiftSense Pro v2
    GOT A STAGE ONE HELL YES!!!!!!!!!!
    TacoSpence likes this.
  15. Feb 20, 2019 at 8:42 AM
    ridge
    ridge One Gear; No Fear
    North Carolina
    '17 TRD Sport DCSB M6
    MESO!
    Will the stage 1 bulb, custom, be readily available if the original fails?
  16. Feb 20, 2019 at 8:42 AM
    MaxTac17
    MaxTac17 Well-Known Member
    Max
    2017 black tacoma trd or
  17. Feb 20, 2019 at 8:42 AM
    bulldog77
    bulldog77 Well-Known Member
    2018 Tacoma DCSB Off Road Cement
    wooohooo :)
  18. Feb 20, 2019 at 8:42 AM
    Totall4285
    Palm Harbor, Fl.
    Got 1 baby
  19. Feb 20, 2019 at 8:42 AM
    Magnetik
    Magnetik Active Member
    Cecil
    SW VA
    16 Blazin' Blue TRD OR
    Just got the stage 2, thanks Stew!!
  20. Feb 20, 2019 at 8:42 AM
    cemented
    Cole
    Portland, OR
    APPLE PAY FTMFW!!!!!
    dskakie likes this.
