MESA = Avital Alarm Fob questions.
Discussion in 'Audio & Video' started by BKinzey, Apr 24, 2022.
  1. Apr 24, 2022 at 2:34 PM
    BKinzey
    BKinzey [OP] Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Looking to replace my key fobs as the plastic loop for the key ring is wearing out. One has already broken off.
    Had the alarm system installed around 2018. Said MESA on the box and key fob. The key fob looks exactly like one from Avital.
    https://www.amazon.com/Avital-Remot...&qid=1650833405&sprefix=Avital,aps,197&sr=8-4
    MESA Model number is 7143M. Avital model is 7143L Anybody know if these will work?
    In programming the new fobs it mentions using the valet button. I don't have one but it seems to be an easy install of a monetary switch. I can do that.
    I suppose I could simply swap the internals into the new cases, but why not use the "new" electronics as well?
  2. Apr 24, 2022 at 8:33 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i'm not very good at counting. i would just swap the cases.
    Uthmoelleri likes this.
  3. Apr 25, 2022 at 12:17 AM
    MannyTheAudioGuy
    MannyTheAudioGuy Well-Known Member
    Emmanuel
    Napa
    2017 Tacoma TRD Sport
    I have put in Racesport gen3 leds I'm the process of doing a custom audio overhaul which will include Hybrid audio unity 6x9 mid bass, unity 3 inch mid driver in the dash and fiberglassing tweets in pilar soundeading all the doors, floors, and headliner and I will be using a helix processor to retain the factory radio and as far as subs I might make custom brackets to move rear seat foward a few inches to get a full size sub in there or I might just go with a pair of jl tw5 or tw3 and it will all be powered by jl audio HD amps or I might try out the new hybrid amps
    Yes it will work there identical besides branding mesa is a private label for special mesa dealers
  4. Apr 25, 2022 at 6:24 AM
    BKinzey
    Beauford
    Hollywierd, CA
    Next question is, anyway to make these more robust? Certainly is a weak point in the design if you keep your keys in your pocket.
  5. Apr 29, 2022 at 7:57 AM
    BKinzey
    Beauford
    Hollywierd, CA
    So, the new fobs came in and as the internals looked fine on the old ones I just swapped the old internals into the new case.
    Thinking of the plastic loop on the fob this is a stress point between the plastic and steel key ring. So I tied a loop in a piece of 550 paracord and used that to join the two. Hopefully that takes care of it.
    soundman98 likes this.
