Maxtrax Lock size
Discussion in '3rd Gen. Tacomas (2016-2023)' started by microsnook, Jan 15, 2022.
  1. Jan 15, 2022 at 9:50 AM
    microsnook
    microsnook [OP] Well-Known Member
    '20 TRD OR MGM MT
    Anyone have a recommendation for a lock that is thin enough to fit through the mounting pins for the maxtrax?
    Gunshot-6A likes this.
  2. Jan 15, 2022 at 9:57 AM
    Kyle_
    Kyle_ A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
    I use the one from my diary
    On a serious note these would work i believe.
    9A11D83B-DD63-48FF-86EB-1DC2155A60A8.jpg E1CB6DEE-6A61-418E-9950-0CBEC57E2FA0.jpg 7DAD3E6F-7DDA-4FDD-8080-EE10CF427B9D.jpg
    microsnook[OP], vivid02 and Skydvrr like this.
  3. Jan 15, 2022 at 10:02 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    The problem with any lock that's small enough to fit through the mounting pins, is that it's easy to bypass (break).
    I'd recommend a cable lock that goes through the handles.
    Gunshot-6A and microsnook[OP] like this.
  4. Jan 15, 2022 at 10:04 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Heres how I lock mine down...
    508surfcaster likes this.
  5. Jan 15, 2022 at 10:15 AM
    Kyle_
    Kyle
    SoCal (805)
    @tacoma.kyle on IG
    not the best but 1. Its a deterrent for honest people and 2. Maybe it will work. Its a gun safe lock so its probably something decent but not anything great.
    6F31EAD3-8818-4B66-A4A5-399CF00F0EC2.jpg 261D0734-B792-4AE9-AA84-D8F69ABAF9A7.jpg
  6. Jan 15, 2022 at 10:27 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I used the same solution at first. Like you said, it's a good visual deterent.
  7. Jan 15, 2022 at 10:43 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I’ve got four luggage padlocks, one on each post. No sliders or steps though so if someone is going to cut them off the Prinsu they’re going to have to climb up there to do it.
    microsnook[OP] likes this.
  8. Jan 15, 2022 at 12:51 PM
    microsnook
    '20 TRD OR MGM MT
    Yea I’m in a low crime area and think a basic lock will be enough for me. I have a couple zip ties on it now so at least it requires more effort than just sliding off the mounts...
    Thanks for the ideas
  9. Jan 18, 2022 at 8:16 AM
    microsnook
    '20 TRD OR MGM MT
    For some reason I’m stuck on using a lock in the designated lock hole on the mounting pins. I bought a lock yesterday and it doesn’t fit through the hole. It’s amazing I’m having such a hard time finding one that will fit. I finally just ordered a cheap luggage lock that had a thin cable and that should fit. I can’t imagine why they couldn’t make the hole 1mm wider to accommodate most locks that will actually do anything. Maybe a stronger cable lock is in order for the future but like I said low crime area so I’m not that worried.
  10. Jan 18, 2022 at 10:09 AM
    Crosbaugh
    Crosbaugh Well-Known Member
    Are gun locks weather resistant?
  11. Jan 18, 2022 at 11:25 AM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    I think this was under appreciated. Hilarious :rofl:
    Kyle_[QUOTED] likes this.
  12. Jan 18, 2022 at 11:36 AM
    Kyle_
    Kyle
    SoCal (805)
    @tacoma.kyle on IG
    Mine was just rained on and no rust but it isnt stainless 0BFDBB70-C432-41F4-A67B-6E867CE43287.jpg
    I would think most… all guns that people care about are stored inside not under the elements so logically I am sure the locks aren't made typically with rust in mind but I am no expert.
  13. Jan 18, 2022 at 11:51 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Here's an idea...leave them off the vehicle when not off-roading. Or put on a tonneau cover and throw them in the bed where they can't be seen.
    I promise that either of those choices will result in less people laughing at you.
  14. Jan 18, 2022 at 11:54 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    TSA luggage locks or one of those included in the case gun lock cables through the handle are good ways to stop honest people from being dishonest.
    I think I have a few cable locks laying around if you can't get ahold of one.
  15. Jan 18, 2022 at 11:57 AM
    Gunshot-6A
    Conner
    Everett, WA
    Not specifically but some may hold up better than others. Its designed for an ostensible use case where its stored in a safe or other resistant container already so it wasn't meant to be. Those things are like a dollar to make, so you can't expect much from them.
    That said, a little WD40 once in a while may abate the rust a little bit.
  16. Jan 18, 2022 at 12:09 PM
    lalonguecarabine762
    lalonguecarabine762 Well-Known Member
    Brodey
    2022 F150 Tremor
    Previous 2016 TRD Offroad
    I used the 30mm Master Lock that you can get at Home Depot. Also fit through the latch on my Roam Adventure cargo box so it was nice to have something that could serve dual purposes. A little bit of rust after a couple years but not bad, and cheap to replace.
    As far as people stealing your Maxtrax, while it is certainly a possibility, I think they are probably not something that people recognize as valuable or know the resale on. I recommend locking them, but I wouldn't worry about a master class of thieves coming specifically for them like your catalytic converter.
  17. Jan 19, 2022 at 11:13 AM
    microsnook
    '20 TRD OR MGM MT
    I don’t care who’s laughing at me. My boards saved me and it was my only recovery option stuck back on a forest road buried in 3ft of snow. They have also been used to rescue a Subaru. So they’ve been used twice this winter already. Laugh all you want. It’s also nice to have them on the roof when they’re dirty I can keep my enclosed bed clean and free of mud.
    I’ve ordered a tsa style lock that will fit and that’s all I need to worry about.
    Cheers
  18. Jan 19, 2022 at 11:14 AM
    Gunshot-6A
    Conner
    Everett, WA
    Now that you mention it, it is kinda funny innit?
    I have a $1500 tent and $600 of maxtrax accessable to Joe Public and my concern and the statistically probable theft will be my cats. o_O
  19. Jan 19, 2022 at 11:22 AM
    microsnook
    '20 TRD OR MGM MT
    Gotta watch those sly mofos!
    Yea I’m not too worried about theft hopefully the Tsa will be enough.
    Glad to have them mounted to roof instead of the bed and digging for them.
  20. Jan 19, 2022 at 11:24 AM
    Gunshot-6A
    Conner
    Everett, WA
    Don't have to justify yourself to us if you like it. I have a similar setup, and TBH I have used them more when I'm not planning on needing them than when I do, like stuck cars in snowy parking lots, etc.
    But you have to prepare yourself to get lumped in with the IG Broverlander stereotype. Just is what it is. :cool:
