Maxtrax and Rotopax: Front Runners Rack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by glitch1213, May 24, 2017.
  1. May 24, 2017 at 2:19 PM
    glitch1213
    glitch1213 [OP] Well-Known Member
    2024 Tacoma TRD Offroad 4x4
    So I ordered a set a Maxtrax with the pins and the two Rotopax universal mounting plates to install on my Front Runners roof rack. I can't seem to get any of the holes to match up with my rack rails. Anyone else have this problem or a solution? Maybe the plates and pins don't work with the rack, but I wanted to check before attempting to sell or return them. I see a lot of guys running the maxtrax and rotopax on their front runners racks.
  2. May 24, 2017 at 3:12 PM
    MilkTeacoma
    MilkTeacoma Well-Known Member
    I have the RotopaX dual mount, I had to drill holes slightly larger to use the existing FRO rails. That's mounting front to back.
    As for Maxtrax, it depends on how you mount it. Across the rack from left to right, it should work flawlessly. But if you mount front to back, then you would a special mount that FRO makes.
    glitch1213[OP] likes this.
  3. May 24, 2017 at 3:18 PM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    You need extra brackets/mounts if you want to mount the MaxTrax lengthwise. Easy to make a set from aluminum:
    glitch1213[OP] and MilkTeacoma like this.
  4. May 24, 2017 at 3:25 PM
    glitch1213
    Thanks guys. I may need to think about a custom bracket as I'm leaning towards running it front to back (Maxtrax).
  5. May 27, 2017 at 2:03 PM
    glitch1213
    Do you have the measurements on that bracket?
    texbambam likes this.
