Max tire size without lift on 21 Sport?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ReconSS0321, Jan 27, 2021.
  1. Jan 27, 2021 at 7:39 PM
    ReconSS0321
    ReconSS0321 [OP] Active Member
    Thad
    Fort Collins, CO
    2021 Tacoma TRD Sport
    I’ve got a lift and larger tires going on at separate places. I’d like to throw the tires on first so when the lift is done, it’s done. Is it possible to drive a Tacoma Sport pre lift with the larger tires on already to the shop putting the lift? LT285 /70 R17 Is what I’m going with. I just don’t want to damage anything so just curious if this can be done.
    Thanks.
  2. Jan 27, 2021 at 7:48 PM
    tulataco
    tulataco Active Member
    265/70/70. Probably won't rub, but some do. If it does, look up tacoma fender trimming
    JoeCOVA likes this.
  3. Jan 27, 2021 at 7:48 PM
    tulataco
    265/70/17 my bad
  4. Jan 27, 2021 at 7:50 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Lots of rubbing is in your future. Drive straight and don't turn.
    Also, 285s on stock wheels will most likely rub your upper control arms. Spacers or different wheels will be needed to avoid that.
  5. Jan 27, 2021 at 7:53 PM
    tulataco
    Should have read the whole thing lol. Don't put them on until after your lift. Even after that you'll rub
    boston23 likes this.
  6. Jan 27, 2021 at 7:54 PM
    Beancooker
    Beancooker Alea iacta est
    The middle of Arizona
    2021 Jeep Wrangler Rubicon
    Lots, straight from the factory.
    285’s need a CMC. Cab Mount Chop.
    265’s are where you’re at.
  7. Jan 27, 2021 at 7:57 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    Some people need to learn the hard way
    ReconSS0321[OP] likes this.
  8. Jan 27, 2021 at 9:18 PM
    ReconSS0321
    Thad
    Fort Collins, CO
    I appreciate this info. I’m a little confused on why stock wheels will cause this but new wheels wouldn’t?
    I’m definitely waiting till after lifted to put the tires on. Thank you. But now I’m considering buying new wheels that I was hoping to avoid. Will you help me understand why new wheels will help with rubbing after a lift? Thanks again!
  9. Jan 27, 2021 at 9:28 PM
    boston23
    boston23 Well-Known Member
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    New wheels can push the tire/wheel assembly further from the upper control arm and so it wont rub on the upper control arm
    different wheels have different offset and backspacing
    welcome to TW
  10. Jan 27, 2021 at 9:29 PM
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    Stock wheels dont have enough back spacing and thus, with the wider tire (buldge) will rub the uca. Spacers or different wheel offset will push tire out, away from the uca.
  11. Jan 27, 2021 at 9:31 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    What he said^
    You can also get spacers for like $100 per axle which will push the wheels further away from your upper control arm.
  12. Jan 27, 2021 at 9:39 PM
    ReconSS0321
    Thad
    Fort Collins, CO
    I’m re thinking everything.
    I’m putting a 3 inch lift on and was hoping to be just under 33’s.
    I’d prefer no rubbing. Is their a wheel and tire combo size that would get me there without rubbing issues after my lift is on? What is the recommend wheel/tire combo size for making sure to not have this issue after the lift?
  13. Jan 27, 2021 at 9:45 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    There’s no guarantee. It really comes down to an awesome alignment as well.
    Shoot for 3.75 - 4.3 BS
  14. Jan 27, 2021 at 9:54 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    265/70-17 is your best bet for tire size without rubbing.
  15. Jan 27, 2021 at 9:58 PM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
  16. Jan 27, 2021 at 9:59 PM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
  17. Jan 27, 2021 at 10:20 PM
    boston23
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    255/85/16 on stock wheels is another way to get to a 33 with no rubbing
    skinny though
  18. Jan 27, 2021 at 10:55 PM
    ReconSS0321
    Thad
    Fort Collins, CO
    would a 275/70r17 with upgraded wheels offset -10 get me the bigger tire without the rub?
  19. Jan 27, 2021 at 11:30 PM
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    That will rub.
    If you are considering any tire size with any wheel offset/back spacing - I guarantee there are dozens of others who have already tried that combination and posted about it on TW.
    My biggest piece of advice is, don't rush into it. Give yourself at least 2 weeks to read about different tire/wheel combinations. You are making a 4 figure purchase that you're going to have to live with (and hopefully be happy with) for several years so you want to explore all the options first.
