Max tire size on 17" rims 2008 TRD Sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Climber311, Feb 16, 2021.
  1. Feb 16, 2021 at 9:37 PM
    Climber311
    Climber311 [OP] Member
    2008 Toyota Tacoma TRD Sport
    Has anyone out there put 17" rims that are 8" wide on their TRD Sport. Mine sits up slightly higher with what I'm guessing is a 1 1/2 to 2" puck above the coils. I currently have 285/75 16s on it and would like to move up to some 17" FN Fx pros if I can. Any experience with say 275/70 17s? 285/75 17s? Thanks for any advice.
  2. Feb 16, 2021 at 11:21 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Are you sure they come in 18"?
  3. Feb 17, 2021 at 5:55 AM
    Climber311
    I messed up I meant 17" thanks for noting that. I guess I'm trying to figure out what the biggest I can get with that 17" rim. It's an 8" wide rim. I want as much tire on the road as possible. Not necessarily the tallest
  4. Feb 17, 2021 at 6:02 AM
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    I'm running 285/65R18s on Fuel wheels. In order to run them, you will need level lift (2-3 inch) and possibly a cab mount chop. It is the width that caused me to get a cab mount chop.
    Climber311[OP] likes this.
  5. Feb 17, 2021 at 6:08 AM
    Climber311
    Wheel spacers wouldn't fix the problem or was it the radius from center to cab that was the issue?
  6. Feb 17, 2021 at 6:11 AM
    ktmrdr
    ktmrdr Well-Known Member
    I run Cooper ST Maxx's 285-75-17 on the 17X7 TRD wheels. Never had an issue.
  7. Feb 17, 2021 at 6:14 AM
    svermilyea
    Scott
    East Tennessee
    max tire size no lift 17 inches will be 265/70R17
    max tire size no lift 18 inches will be 265/60R18
    These numbers are guaranteed fit, no rub. You can experiment with larger sizes, but the actual tire will be the determining factor.
    Naveronski and Climber311[OP] like this.
  8. Feb 17, 2021 at 6:17 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    For the 2nd Gen, which you have, it will be a little more difficult then @svermilyea in his 3rd gen. I have a 2013 sport with 17" rims. I started with 265/70R17's at first without any issue. Keep in mind that I was also running the oem sport rims with a +30mm offset. I moved up to 285/70R17's and I had to do a cab mount chop and added 1.25 spidertrax wheel spacers to clear my JBA UCA's. I just switched over to a new wheel with a -12 mm offset and took the spidertrax off and I am good now. If you have at least a 2 inch lift, you would need a cab mount chop to fit 285's but you should be able to clear 275's without a problem as long as you wel lifted a little and did a small amount of trimming.
