Max bed weight you've had?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2006whitetacoma, Oct 13, 2018.
  1. Oct 13, 2018 at 12:09 PM
    2006whitetacoma
    2006whitetacoma [OP] Well-Known Member
    2006 White SR5
    I want to put a 2000lb pallet of flagstone in my tacomas bed, and am not sure this would be ok. The only number I can find is 1300 lbs for passengers and cargo, surely the bed capacity can't be this low can it?
  2. Oct 13, 2018 at 12:11 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    That is correct. These trucks don’t have a large payload. Check the door jam, it should have the label that will tell you the max payload of the truck which includes passenger weights.
    I married my tacoma likes this.
  3. Oct 13, 2018 at 12:12 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I’d put that on a trailer.
  4. Oct 13, 2018 at 12:13 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    2000lbs is a ton!
    My father in law did 6 trips 50 miles hauling a ton of crushed stone. 25 miles on the interstate and 25 secondary/mtn roads. It’s a 2.7 manual!
    He also has moss growing on the back of his cab!!
    I wouldn’t recommend either!
  5. Oct 13, 2018 at 12:20 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    This.
    Dlakerguy13 likes this.
  6. Oct 13, 2018 at 1:04 PM
    2006whitetacoma
    2006 White SR5
    Thanks guys, just seemed wrong to me that three friends and myself in the cab could take the bed capacity down to 300 lbs.
  7. Oct 13, 2018 at 1:06 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Go for it. I put more than that in wet topsoil in the bed.....it was spread over the entire bed though.
  8. Oct 13, 2018 at 2:02 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I'd trailer that. It'll tow easy.
  9. Oct 13, 2018 at 2:13 PM
    R490
    R490 Well-Known Member
    Upgrayedd
    VA/PA
    I've gone over payload a couple times with no bad side effects. I wouldn't recommend it though.
  10. Oct 13, 2018 at 2:42 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    Just over 2000lbs in my lowered XRunner lol!
  11. Oct 13, 2018 at 3:46 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I had to haul some metal to school-pallet with @ 2000 lbs. of steel for my welding class. Truck was low on the springs (not maxed out) but drove fine. Not an everyday thing for sure...
  12. Oct 13, 2018 at 3:55 PM
    timbobzimbob
    timbobzimbob Well-Known Member
    Tim
    Ottawa, Ontario
    05 DCLB 4x4
    I've loaded thousands of half ton trucks with dirt, stone aggregates, sometimes skids of pavers, flagstone etc. The tacomas are almost like the ford rangers, it doesn't take much before they squat with the mudflaps dragging on the ground. You could put 2000lbs in the back (~1 cubic yard of topsoil) but it will be really hard on your rear suspension and pretty dangerous. If you're not going far, probably be fine. don't do it everyday lol
  13. Oct 13, 2018 at 3:55 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    FWIW, that would be overloading many 3/4 ton trucks. Most of the super cabs are in the 2200 lbs payload range. Add a 200 lb driver and any tools or other gear in the truck and you'd be over. I'd haul it in a 3/4 ton, and even most 1/2 tons. You'd be slightly over loaded. But in a Tacoma after you factor in for the driver and other gear you'd be almost double the payload.
  14. Oct 13, 2018 at 5:38 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I would trailer that shit.
  15. Oct 14, 2018 at 4:22 AM
    Ryeguy
    Ryeguy Well-Known Member
    43* North
    2021 TRD Off Road 4X4 Blackout
    OEM Bed Extension, Bed Mat, Lomax Bed Cover, Auto lock tailgate (OEM)
    I had 1/2 a yard of top soil in the bed and another 1/2 yard in a trailer. The truck was very low and probably more than borderline unsafe. I only had to go about 8 miles on back roads and glad I didn't need to go any further.
    Trailers are a great option, but combining a heavy tongue weight with the material already in the bed definitely overloaded the truck.
  16. Oct 14, 2018 at 4:46 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Well at least you asked the question. Many people just say “send it” and wonder why suspension or axles are having issues.
    Home Depot rents F-250 trucks. First hour is 20.00.
    Reason 327 why I buy new trucks. :thumbsup:
  17. Oct 14, 2018 at 5:09 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Many times I’ve had 35 cases of milk (about 1300 lbs) in the bed of my truck (stock suspension) and driven it a couple hours GENTLY and it did ok, but 2000 lbs? I would be hesitant...that’s a lot of weight.
  18. Oct 14, 2018 at 5:29 AM
    Sky_Hawk25
    Sky_Hawk25 Well-Known Member
    2014 MGM Tacoma
    I carried a 1 ton pallet of stone pavers, over 1 ton total with me in the truck driving. I did this twice for two separate pallet loads of pavers. Had them slide the pallet in over the axel as best they could. Stock suspension and it’s my daily driver. No issue with the suspension to date and this was over a year ago.
    I drove with the weight for about 45 mins to get home, very slow and just was cautious as far as hitting bumps and stopping. I also read about the same max payload but didn’t have access to a trailer. I crossed my fingers and went with it. I figured Toyota suspension engineers had to have some safety factor for the suspension limits. It ended up being ok, but was a stressful drive both times. If you have a trailer go with the trailer, less risky. It can and has been done though; dat your own risk though.
  19. Oct 14, 2018 at 5:31 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    In before pictures of fat chicks start appearing
  20. Oct 14, 2018 at 6:16 AM
    2006whitetacoma
    2006 White SR5
    Funny story about those trucks. Before I owned a truck I was building a retaining wall out of these big heavy square blocks from Lowes and rented their truck, bought 200 of these stones at 22lbs each. They loaded them onto their truck the suspension compressed pretty good. They asked if that was too much for the truck, I said hell if I know, it's your truck.
    On my way home (in a sort of "urban" area) this woman ran out in front of me waving he arms and yelling. I thought someone was dying, I almost didn't get stopped, all I could think of was the paperwork if I ran over someone in the Lowes truck. She got to the door and tried to open it, gladly it autolocked. I started cranking down the window and she says "got a cigarette?". It was one of the crackhead hookers that frequent the area. It is probably a good thing the door autolocked cause I would have probably punched her. I yelled get out of here you cracked whore, I almost ran over you.
