Matt’s Off Road Recovery
Discussion in 'Recovery' started by Thunder Fist, Mar 23, 2020.
  1. Jun 2, 2020 at 3:29 PM
    #41
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
  2. Jun 3, 2020 at 12:41 AM
    #42
    MarkStanW
    MarkStanW 394,000 kms and counting...
    Mark
    Vancouver/Nelson, British Columbia
    1998 Tacoma. 3.4L V6.
    I sure did! The kid learnt a new trick. Haha. I have my big rig license and have driven many different 10-18 speed trucks and would occasionally float the gears on some of the trucks. I haven't had to do it in a "normal" car or truck. Personally, I like to double clutch. You press the clutch lightly(1/4 of the way down) to break torque so I your not "breaking your knees". It's the proper way to drive those things. I don't big rig drive trucks much anymore. I worked on high voltage powerlines in some pretty gnarly terrain. All 6 wheels had chains on, full axle and wheel lockers in the back and as much momentum as you could get. If we got stuck or had some really steep/muddy/snowy hills to climb (45 degree hills with barely enough room for the truck at times) we'd have an excavator or bulldozer pull us up. I put a bucket truck on it's side once. The embankment gave out and I went for a ride. Luckily I didn't have far to go and didn't get hurt. The truck was totaled though.
  3. Jun 3, 2020 at 12:53 AM
    #43
    MarkStanW
    Mark
    That's how I learnt. The "veteran" linemen I worked with didn't know how to drive using the clutch. I went to do my test and failed because I didn't use the clutch once after I started in 3rd. Haha! The woman said I drove like a cowboy and made me take driving courses in order to get my license. I learnt how to double clutch and just drove like that all the time. I don't drive trucks anymore, occasionally my buddy's 1984 Mack dump truck. That thing is awesome. 15 speed. 5 speeds in reverse if I recall correctly.
    Taco 422 likes this.
  4. Jun 21, 2020 at 10:03 AM
    #44
    RadioTaco
    RadioTaco Well-Known Member
    SoCal
    2019 MGM TRD OR DCSB
    Love this channel on YT. I’ve gained a lot of recovery knowledge just watching his techniques.
    I don’t think he is just a tow truck driver who bought a Jeep. He definitely knows the area very well!
    Dude drives out most of the cars people think are stuck.
  5. Jun 22, 2020 at 6:32 PM
    #45
    FirstGenTundra
    FirstGenTundra Well-Known Member
    Knoxville, TN
    2002 Tundra
    ICON suspension, SCS Ray 10's, Brute Force Fab bumper,
    I'm just shocked that Jeep has been able to pull out some big vehicles. I knew they had a lot of torque but pulling a RV was ridiculous.
  6. Jun 22, 2020 at 11:05 PM
    #46
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Recovery is 99% thinking and 1% working. If stuck STOP. Look at things from every angle and then think it through. Not just the first step but a complete plan, including what to do when it doesn't work, cuz lots of times it won't so you start thinking again not working harder.
    Taco 422, 1buzzbait and JVL1985 like this.
  7. Jun 23, 2020 at 10:37 AM
    #47
    Thunder Fist
    Thunder Fist [OP] Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    That’s the beauty of a kinetic rope.
    ToyotaDriver likes this.
  8. Jun 23, 2020 at 11:35 AM
    #48
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I don’t think torque is the key here. It’s momentum combined with an elastic rope.
  9. Jun 24, 2020 at 10:26 PM
    #49
    JVL1985
    JVL1985 Well-Known Member
    2019 Tacoma Double Cab, short bed,4x4, v6, TRD Off-road
    This has been my favorite YouTube channel for the last month. I like that that he does everything low tech, cost effective, simple and straightforward. He does not resort to any high speed low drag gimmicks. He does not rock any expensive bling on his rig. He just needs to get the job done. In my opinion he debunks a lot of "recovery" myths out there that have all of us overweight and over budget for the type of use we actually see as weekend warriors. He has a few episodes where he explains the gear he uses and why he choses a cherokee. At the end of the day it's about the business bottom line and efficiency while still being smart and safe.
    1buzzbait, grogie and RadioTaco like this.
  10. Jun 25, 2020 at 8:04 AM
    #50
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    What are some basic recovery things I would need for a stock taco? I have a recovery strap, but am unsure where I would attach it to. Maybe I need one of those chain things he uses on most small car's factory tow hooks? Shackles, if thats what theyre called? I have a folding traction board, deff need to upgrade to a real set for Colorado mud and snow (been caught in snow before, wasn't too fun in my jetta). I have a small folding shovel that will probably break the second or third time.
  11. Jun 25, 2020 at 11:38 AM
    #51
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    Remember any of the episodes that he talks about why he chose a Cherokee? I was always kind of curious about that. Obviously low cost and ease of finding parts is probably up there, but the unibody construction leaves a lot to be desired (assuming he doesnt have chassis stiffeners). I have an XJ sitting in the driveway and love it but would probably have chosen something with body on frame for the job that he does.
    Taco 422 and 1buzzbait like this.
  12. Jun 25, 2020 at 8:35 PM
    #52
    JVL1985
    His rig is a beast. I'll try to find the episode where he explains it. But you are basically right. The in-line 6 in that thing is pretty reliable and easy/cheap to fix. I think he said he could replace the rig for under $5k. Minimum electronic gadgets. No comforts. Great Aftermarket support. Used ones everywhere. And he doesn't care about it/ get attached to it. So from a business perspective it's better than buying a high value "collectible" 4x4 that might be a small % better in some aspects.
    1buzzbait likes this.
  13. Jun 25, 2020 at 9:06 PM
    #53
    JVL1985
    I think others on here can add to the list but this is what I would recommend to get started.
    https://www.amazon.com/Leather-Adju...keywords=leather+gloves&qid=1593143076&sr=8-4
    https://www.amazon.com/LIBERRWAY-Sh...=tacoma+front+tow+hitch&qid=1593143336&sr=8-8
    https://www.amazon.com/Rhino-USA-Re...=1593142806&sprefix=tree+saver,aps,262&sr=8-6
    https://www.amazon.com/RHINO-USA-Re...ld=1&keywords=tow+strap&qid=1593142864&sr=8-6
    https://www.amazon.com/Synthetic-Br...id=1593142905&sprefix=soft+sha,aps,293&sr=8-9
    https://www.amazon.com/REDCAMP-Military-Shovel,High-Entrenching-Cover,Green/dp/B07GVGN3C4/ref=sr_1_5?dchild=1&keywords=folding+shovel&qid=1593142966&sr=8-5
    If you plan on going solo (not recommended until you have more experience)
    https://www.amazon.com/Maxtrax-MTX0...qid=1593143002&sprefix=maxtrax,aps,266&sr=8-3
    https://www.amazon.com/ECOTRIC-Moun...3143227&sprefix=whinch+cradle=,aps,305&sr=8-2
    https://www.amazon.com/X-BULL-Water...d=1&keywords=winch&qid=1593143252&sr=8-8&th=1
    https://www.amazon.com/cableado-universal-conexión-amperios-cabestrante/dp/B0722J4ZQR/ref=sr_1_3?crid=IBQC5C0JULO6&dchild=1&keywords=winch+wiring+kit&qid=1593143700&sprefix=winch+wireing+kit%2Caps%2C228&sr=8-3#customerReviews
    https://www.amazon.com/CURT-31075-2...=tacoma+front+tow+hitch&qid=1593143315&sr=8-5
    https://www.amazon.com/ORCISH-Recov...593143396&sprefix=pulley+block,aps,285&sr=8-3
    I'm sure I'm missing some items and others can chime in. But most important is to learn how to use all this stuff. Get out and practice.
    Also, the winch on a cradle is nice in my opinion but you can get it permanently mounted on a bumper instead. But if you are alone it would be hard to pull yourself out in the opposite direction of where you mount the winch. Alternately to the winche I've seen some gadgets out there that seem to be good in theory but I have never personally used them. For example this thing https://www.youtube.com/channel/UCIrN_LagqolLlAa8SdE6R4A
    I can see my self successfully using this thing but you definitely need to know how to use it and it looks it could turn into a pain in the ass. The advantage is cost savings (compared to a winch and bumper) and space and weight savings.
    You probably don't need the second part of this list. The first part is a good start.
    Edit: winch on a cradle setup incase you are wondering https://youtu.be/ZwTwRqUuFUU
  14. Jun 25, 2020 at 9:40 PM
    #54
    RadioTaco
    SoCal
    Also he usually airs down to like 9 psi. Drives around like it’s nothing cause he isn’t driving like a jackass.
    Matt definitely has a vast knowledge of off-road driving, not just recovery.
    It feels good to know that if I am ever out wheeling in southern Utah and get broken down or stuck beyond my own recovery means that his services are just a call away.
    he also made a great point about the cost of his rig....that he can afford to lose 5k on a rig cause it’s just a Jeep really and cost efficient. It’s not a 12 ton 75k wrecker or hook truck that he is risking messing up out in the dunes.
    1buzzbait, Grindstone and JVL1985 like this.
  15. Jun 25, 2020 at 10:30 PM
    #55
    fatty ac1d
    fatty ac1d Well-Known Member
    Kansas
    15 MGM DCSB SR5
    Not the same YT channel, but it does feature Matt in this video:
    1buzzbait, grogie, uurx and 3 others like this.
  16. Jun 26, 2020 at 12:06 AM
    #56
    JEEPNIK
    Re: the shovel. Get a full length shovel. Entrenching tools will work you to death. A D handle shovel is a compromise. Believe me if you need to shovel much dirt or sand you'll really appreciate the long handle.
    D. Lengua, des2mtn, jackn7 and 7 others like this.
  17. Jun 26, 2020 at 7:46 AM
    #57
    mrtonyd
    Tony
    Colorado
    thanks for the recommendations. i'm not sure if ill need a winch and stuff until i'm more experienced, but the shackles, tree saver, and traction board are top of my list.
  18. Jun 26, 2020 at 8:07 AM
    #58
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Yep! I just picked up a full length shovel and it is so much nicer to have than a e tool or short shovel. If push comes to shove, I can saw it to length to get under a vehicle, but I don’t foresee that happening.
  19. Jun 26, 2020 at 8:12 AM
    #59
    ToyotaDriver
    Idaho
    I’ve learned a good bit from Matt’s Channel and thoroughly enjoy it. It’s definitely inspired me to simplify my recovery gear. I have an ARB snatch strap that I’m getting ready to retire. Matt has me very seriously considering a Yankum Rope, although I do like the way the snatch strap stores a lot better than the rope.
    JVL1985 likes this.
  20. Jun 26, 2020 at 9:18 AM
    #60
    JVL1985
    I carry two e tools to save space in the bed. I'll make the wife help me. I also have the two matrax that dig pretty well in sand and snow. I can have 4 people digging and it doesn't take up much space. I used to carry a full size shovel and axe until I realized I used them once in 13 years! So I switched.
