Matching Fog Lights to DRL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacodude_93, Nov 8, 2021.
  1. Nov 8, 2021 at 11:04 AM
    Tacodude_93
    Tacodude_93 [OP] Active Member
    Mark
    2017 Black SR5 4x4
    I was hoping to find the amber color of fog lights to match the same color as the DRL. I have the 17' SR5 so they're just the standard headlights... I haven't found anything to justify with matching the amber color but its looks like the Morimito XB would be the closest I've seen so far?
    Asking my fellow experts for approval and justification lol.
    Junkhead likes this.
  2. Nov 8, 2021 at 12:10 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Can always try amber lamin-x.
    :notsure:
    Millhouse516 and Tacospike like this.
  3. Nov 8, 2021 at 12:46 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Tacodude_93[OP] likes this.
  4. Nov 8, 2021 at 12:50 PM
    brandon78lusch
    Brandon
    Here’s mine with the Diode Dynamics SS3 Pro yellow fog lights
  5. Nov 8, 2021 at 1:56 PM
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    I would buy more for functionality than looks. The yellow's on the market may not match the DRLs, but there's probably a reason for that.
  6. Nov 8, 2021 at 2:07 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    The 2017 lights suck. I had one. Upgrade the low beams to HID if you haven’t already. Thats a much more important upgrade.
  7. Nov 8, 2021 at 2:13 PM
    tacotoospicy
    tacotoospicy Well-Known Member
    Luke
    P'cola, FL
    2019 TRD OR
    sirius xm
    Are you saying you don't have factory fogs and looking for aftermarket options?
    I would say the Lamin-X option that @Junkhead mentioned would work if you had factory fogs installed.
  8. Nov 8, 2021 at 2:33 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    FWIW I bought white LED fog light housing replacements from Amazon and applied amber lamin-x film. Very good throw and proper cut off, I’m very happy with them.
    It’s this “siemid” brand from Amazon, they look just like Tundra LED fogs.
    nightcrawler likes this.
  9. Nov 8, 2021 at 11:17 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    No. Heretic sells products falsely advertised as fogs, just like Baja used to. That is not an SAE fog in the slightest, it will not have a fog light pattern and cause blinding glare to oncoming drivers while not being street legal and also making them ineffective in fog.
    If you truly want amber (not yellow) fogs, the best performing option is KC G4 ambers covered here: KC Amber. However, as mentioned amber is a very low performing output color for fog, the intensity is low, the contrast is low, the color accuracy is low., there is very little good about it while selective yellow is vastly superior with all the benefits of long wavelength light for performance in poor weather and far less draw backs. The mid-grade Diode Dynamics SS3 Pro in selective yellow is 3.6x+ higher output than the KC ambers, while offering better color for visibility, higher contrast, running hot enough to clear snow, having a larger pattern area and non-reflective long wavelength light output. That isn't even the top of the line Max. The ambers are actually lower in output than the stock 16-19 H11 TRD fogs.
    Long story short, quality amber options do exist. But vastly superior selective yellow options do as well, which would be a much wiser purchase.
    Biscuits and Junkhead like this.
  10. Nov 9, 2021 at 5:08 AM
    Tacodude_93
    Mark
    2017 Black SR5 4x4
    I went with the TRD Pro Rigid fogs a few months back from a fellow TW member. I wanted a little more output, and to somehow maybe match that DRL amber color on the headlight. I have the cali raised LED combo beam light bar coming in to mount under the grill so I didn't want to be lit up like a christmas tree of LED, needed a little contrast IMO.
    From what I'm hearing from y'all the functionality of the amber fogs will not give as much output so maybe a more luminating LED fogs would work? Thanks for the input guys!
  11. Nov 9, 2021 at 5:18 AM
    Snoman002
    Snoman002 Well-Known Member
    Sno
    21 DCSBORSWMT
    Remember Fog lights are only effective in FOG. They are not a suitable accessory driving light and regardless of color should not be used as such. They also should not be used when it isn’t foggy as they can actually reduce your , and others, vision.
    So if you need good FOG lights take crash’s advice.
    If you want matching color down there some clearance lights or similar should give you the look without the downsides. No harm in wanting the look and there are ways to do so that look nice and have little drawbacks.
    As far as actual headlight, driving, ability to see stuff in front of you improvements it’s best to tackle the factory headlights for those updates. There is the awesome sticky and the $20 for H9’s is unbeatable, and crashe’s thread on supplemental high beams is another great read.
  12. Nov 9, 2021 at 7:03 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Interesting.
    I had yellow lamin x over the same LED fog lights and the output looked a bit greenish yellow, now with the amber lamin x the light out output is a nice yellow color.
    I see a lot of icelandic builds with amber fogs, I wonder why. Yellow does seem like a better color for fog and snow.
  13. Nov 9, 2021 at 9:18 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The yellow laminex is used for a warm white halogen light source ~3000k-3000k. When you try to correct 6000k using yellow laminex, there is too much blue in the light. Blue + yellow = green. Similar to how the SS3 Sport/Pro which use 4000k emitters have yellow lenses vs the Max that has 6000k emitters requires a different amber lens to achieve proper yellow output.
    Junkhead[QUOTED] likes this.
  14. Nov 9, 2021 at 9:33 AM
    ripRavioli
    ripRavioli Well-Known Member
    Evan
    SLC
    2017 Tacoma Access cab 4cyl 4x4
    SR with factory lights and Morimito XB's
  15. Nov 9, 2021 at 10:06 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Looks great!
    Man that’s the tent I want. Where did you get it if you don’t mind me asking.
  16. Nov 9, 2021 at 10:06 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    You always have great info, thanks.
    crashnburn80[QUOTED] likes this.
  17. Nov 9, 2021 at 10:12 AM
    Millhouse516
    Millhouse516 Traveling by Tacoma
    San Diego
    Silver 2019 DCSB SR5
    5100's - Icon AAL - RTT - DIY Awning - DIY Mods
  18. Nov 9, 2021 at 11:18 AM
    ripRavioli
    Evan
    SLC
    not at all! Its a Super Pacific X1 its a pretty sweet tent. there is a form in tacoma world about them but also their site has some good pics and vids https://www.superpacificusa.com/
