Mass airflow sensor question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toywoodsguy82, Jun 6, 2019.
  1. Jun 6, 2019 at 5:35 PM
    Toywoodsguy82
    Toywoodsguy82 [OP] Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    For all of you that have changed or cleaned your mass airflow sensor have you had any issues getting it out or breaking it?? I’m about to clean mine in the next couple days and just wanted to see if people of had issues.
  2. Jun 6, 2019 at 6:17 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Afaik, just dont strip the heads of the two fasteners when loosening/tightening them. If i recall, the sensor is then just pressure fitted with a rubber o-ring to seal/mate the surface.
  3. Jun 6, 2019 at 6:29 PM
    JD_P
    JD_P Well-Known Member
    Terrebonne, Oregon
    2015 TRD Off Road Access Cab
    Just cleaned my MAF sensor yesterday on my 2015. It was one of the easiest things to do. Took about 5 minutes. Remove engine cover with 2 10mm bolts and phillips screwdriver to remove 2 MAF screws. I will say that the screws are smaller than your standard #2 phillips. Maybe #1 would work better. I pressed the button on the retaining clip and separated with a flat head screw driver. Popped out MAF sensor placed on a piece of cardboard and hosed it down with CRC MAF sensor cleaner. It was warm out so it dried quickly. Replaced everything and was good to go.
    The Napa sales clerk asked if I had a CEL and is that why I was purchasing the cleaner. I don't, just want to keep i clean and this is the first time doing so at just over 100,000 miles.
    It is pretty straight forward. I watched a video from here after some other posts about the sensor, Good luck to you.
  4. Jun 6, 2019 at 7:01 PM
    Toywoodsguy82
    Patrick
    Oregon
    Yea I have watched a couple of videos they just say be careful because the part is expensive if I break it.
  5. Jun 6, 2019 at 7:04 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    when putting it back in, go easy on the lil screws that hold it in the intake, they are simply coarse threaded small screws threaded right into the plastic, which makes the hole they go into easily stripped.
    Other that that, the maf's on our trucks are packaged in such away you would have to be real dumb to screw em up.
    SUMOTNK likes this.
  6. Jun 6, 2019 at 7:05 PM
    Bishop84
    Bishop84 Well-Known Member
    I've cleaned probably hundred, biggest risk is dropping the screws. If you're truly worried, remove the intake entirely (to clean the throttle anyway) and remove the MAF on a bench.
    Lester Lugnut and PzTank like this.
  7. Jun 7, 2019 at 7:11 AM
    mojojojo78
    mojojojo78 Well-Known Member
    2007 Prerunner Access Cab SR5 V6 6 Speed Manual
    None... yet
    I just cleaned my yesterday on my 07. It was really simple like others have said. I did it just like JD_P.
  8. Jun 7, 2019 at 8:02 AM
    CStafford
    CStafford Well-Known Member
    Cameron
    2006 Silver Tacoma TRD Access
    Replaced my MAF a month ago, super super simple. The OEM part isn't that expensive either if you do somehow manage to break it... I think I got mine on Amazon for around $60
  9. Jun 7, 2019 at 8:53 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    It’s easy to do. I do mine every 30K. Since I got everything apart I clean the throttle body as well.
    tacoma guy and TACOMA2NDGEN like this.
  10. Jun 7, 2019 at 8:58 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The only trick is to use MAF cleaner. It’s not the same stuff you use on the throttle body, etc.
  11. Jun 7, 2019 at 9:05 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I do this yearly on all our cars. I even take the throttle body off for a good cleaning. Like someone said, dropping or losing the screw would be the biggest risk.
  12. Jun 7, 2019 at 9:24 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    After cleaning, I would also remove the neg battery cable for a couple of min to reset the ECU. If the MAF was dirty, the ECU would need to relearn. Not a required step, but why wait for it to relearn on its own.
  13. Jun 7, 2019 at 2:23 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I do mine every 20k with the throttle body. Usually pick up 1-2 mpg. Like said above use the crc cleaner for the MAF and use there throttle body cleaner as well. Just a tip when you’re cleaning the MAF there’s two spots that need cleaning the one that looks like a glass tear drop and then down inside just spray the snot out of it. If its hot out it will dry quickly
    tacoma guy likes this.
