Mary Jane
Discussion in '3rd Gen. Builds (2016-2023)' started by EvlFlash, Aug 13, 2024.
  1. Aug 26, 2024 at 10:59 AM
    EvlFlash
    EvlFlash [OP] Well-Known Member
    Utah
    2023 Tacoma TRD OR 6MT
    So, I got this kit when I did some work on the pitman arm of my previous Jeep and you would think a 35mm socket would be there but of course not, everything around it but no 35mm socket...
  2. Aug 26, 2024 at 11:00 AM
    EvlFlash
    Utah
    Threw in a ECGS bushing instead of waiting for the needle bearing to fail
    Steves104x4 likes this.
  3. Aug 26, 2024 at 11:02 AM
    EvlFlash
    Utah
    The driver side with all the new shiny installed
    MGMDesertTaco likes this.
  4. Aug 26, 2024 at 11:05 AM
    EvlFlash
    Utah
    Some comparisons of the shocks and UCA's that were replaced
    MGMDesertTaco and Road_Warrior like this.
  5. Aug 26, 2024 at 11:20 AM
    EvlFlash
    Utah
    Didn't take any photos when working on the rear end unfortunately but main things to note would be that I went against Icon's instructions and kept the stock overload spring and added some 3 degree shims to correct the pinion angle of the rear diff. It looks like I am one of the lucky ones with how some of these trucks can have rear end vibrations after lifting. Before install I went through all of this thread as part of my research (it's where I found the rear shim suggestion). After an alignment at a local shop, everything is just as smooth as before. Overall, super happy with the results. Rides a lot stiffer than stock with less body roll in corners and almost no nose dive when braking hard. Here are the before/after measurements from the floor to the bottom of the fender:
    • Front
      • Driver Side
        • Before: 35"
        • After: 38 3/4"
      • Passenger Side
        • Before: 35 1/2"
        • After: 39 1/8"
    • Rear
      • Driver Side
        • Before: 35 3/8"
        • After: 37 3/4"
      • Passenger Side
        • Before: 36"
        • After: 38 3/8"
  6. Aug 27, 2024 at 11:30 AM
    EvlFlash
    Utah
    Joined the OTT crowd and it's been a whole new truck. Did a lot of research on all the different tunes out there and OTT really won out with having proof in what it does with the dyno numbers. It's well known that this engine doesn't create super impressive power numbers and the main thing I was looking for is getting more torque available lower in the RPM range. This did exactly that and now the way it drives matches what I'm expecting from it.
    I did do all of the tuning myself with purchasing VF Tuner because I may end up going down that rabbit hole of tuning and learning about all the complexities of modern engines.
    Overland Tailor was easy to work with in getting the tune files (with some expected hoops to jump through). Only regret is not doing this one sooner!
    STEELeR43, Polythemus and JustDSM like this.
  7. Aug 28, 2024 at 10:00 AM
    STEELeR43
    STEELeR43 Well-Known Member
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    What level of tune you got from OTT? I went to my OTT tuner in my location, and my tune is Spicey for my 2023 TRD OffRoad 6 spd manual Tuner first tried on Super Spicy, but too much sensitivety, so he drop it down one level.:D
  8. Aug 28, 2024 at 10:04 AM
    EvlFlash
    Utah
    Right now I have the medium level. Since I did the tune myself Overland Tailor did provide me with the different levels to flash.
    I have been happy where it's at but I may try the spicy level when I throw an AGM battery in.
  9. Aug 28, 2024 at 3:55 PM
    EvlFlash
    Utah
    Got a nice little package from the neighbors up north
    Front end is all prepped and ready
  10. Aug 28, 2024 at 3:58 PM
    EvlFlash
    Utah
    First stage of the chopping done
    And the finished job, really liking this Greenlane Offroad bumper, going to put their sliders on my list and maybe even the roof rack
  11. Aug 28, 2024 at 4:10 PM
    EvlFlash
    Utah
    Almost caught up with where the truck is currently at.
    Added some bronze Method 701 17/8.5 wrapped with 255/80/17 Wildpeak AT4's. I was gonna go with black wheels at first but I'm starting to embrace the colorfulness of this truck.
  12. Aug 28, 2024 at 4:28 PM
    EvlFlash
    Utah
    Finally got it out into some dirt in the Wasatch, life has been busy with a newborn
    MGMDesertTaco and bryan83taco like this.
  13. Aug 28, 2024 at 4:33 PM
    EvlFlash
    Utah
    While having some fun with everything in the dirt, I heard some possible rubbing with the front end stuffed.
    Back home I dropped a strut and stuffed the front. Houston, we have a problem...
    I think it will clear the cab mount but time for some :sawzall:
  14. Aug 28, 2024 at 4:37 PM
    EvlFlash
    Utah
    Since I plan on keeping this truck forever (wife laughed at me...), decided to get a tint done for UV protection and some glare reduction. Any heat rejection that came along was a bonus.
    MGMDesertTaco and Steves104x4 like this.
  15. Aug 28, 2024 at 4:45 PM
    #35
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Just found your build thread, that’s one awesome looking vehicle! Nice and practical but not overkill. Great work :thumbsup:
  16. Aug 28, 2024 at 4:53 PM
    #36
    EvlFlash
    Utah
    And with this, should be mostly caught up with where the truck sits now.
    Tackled the accumulator delete in a two stage process (because I'm impatient). Started with a prefab hard line while I waited on the delete disc to get delivered. Right now I have the disc installed and going to stick with that. Compared to the hard line, it had a different feel on the pedal at first but that was/is due to some air still in the system. See my initial comparison here.
    The lovely accumulator 'feature'
    The hard line mock up
    The hard line install
    I forgot to take a picture of the disc before install but it is a beautiful piece of machining and now it looks like nothing was done at all.
  17. Aug 28, 2024 at 5:03 PM
    #37
    EvlFlash
    Utah
    Thanks! I've been trying to keep this one light and nimble while still having adequate protection. Coming from a Jeep I just know that I'm going to high center this over a crest without even thinking once I get time to start wheeling again.
    Road_Warrior[QUOTED] likes this.
  18. Aug 30, 2024 at 10:13 AM
    #38
    EvlFlash
    Utah
    Added the Diamond Back cross bin 8 for all the recovery gear/tools. Been liking it so far. Part of me does wish I had gotten the cross bin 13 for more storage but once I install some onboard air a little room will free up.
    MannKrafted likes this.
  19. Sep 10, 2024 at 6:32 PM
    #39
    EvlFlash
    Utah
    while waiting on some c4 fender liners for the rubbing cure, softened the front end bumps with some Duro Bumps
  20. Sep 13, 2024 at 10:30 PM
    #40
    EvlFlash
    Utah
    I wasn't planning on doing this one until later but with the positive feel on the clutch now with the ADD, decided to put a B&M short throw in. Only had a few drives so far and I'm really liking it. No more floppyness in neutral and a nice firm positive feel when putting it into gear.
    bryan83taco likes this.
