Marlin Crawler's New Rock Crawling Long Travel IFS Suspension System (#RCLT)
Discussion in 'Long Travel Suspension' started by BigMike, Feb 2, 2019.
  1. Aug 21, 2023 at 12:53 PM
    #2581
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    The guy in my area needed a new rear axle because his front was now 5.5 inches wider.
    He got a Dana 60 axle.
  2. Aug 21, 2023 at 12:55 PM
    #2582
    Kamille.bidan
    2017 Blue TRD OR MT
    looking at the website I guess stock width is available.
    I wonder if it is something I’d regret
  3. Aug 21, 2023 at 4:57 PM
    #2583
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    its not necessary by any means. you can just throw some 1.25" good hubcentric spacers on if width is your worry, but it really won't matter too much only being a 2.25" kit. and yes spacers are fine as long as you buy nice ones with there own studs, plenty of guys have jumped there trucks on rear spacers so it is not an issue. but if you really want to buy a dana 60 than by all means.
  4. Aug 21, 2023 at 5:03 PM
    #2584
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    I don't see a stock width RCLT option on Marlin's website?
  5. Aug 21, 2023 at 5:24 PM
    #2585
    airkewled
    airkewled Well-Known Member
    Kevin
    Moab
    2006 Tacoma DCSB
    It’s in the name? rcLT idk how there’d be stock width. AFAIK it’s 2.75 or 3.5
  6. Aug 22, 2023 at 1:06 AM
    #2586
    Kamille.bidan
    2017 Blue TRD OR MT
    I saw the 2.75 and 3.5, and I thought they were add-ons rather than mandatory options.
  7. Aug 22, 2023 at 10:03 AM
    #2587
    airkewled
    Kevin
    Moab
    2006 Tacoma DCSB
    2.75 is the OG release version. The 3.5 is a more recent addition.
  8. Aug 22, 2023 at 10:06 AM
    #2588
    essjay
    Concord, CA
    Yeah, that was a big part of my confusion. I was sitting here like: "I like the narrower track. I wonder how much RCMT costs..."
  9. Aug 22, 2023 at 5:28 PM
    #2589
    Kamille.bidan
    2017 Blue TRD OR MT
    do drivers normally leave the front wider than the rear like a Land Cruiser 70 series?
    Is that safe in normal situations? Never had or drove a setup like this before.
    I already installed 4.56 gears and a rear locker. As you can imagine, that was not cheap. If I have to put a Dana 60 axle, then so be it. it would be a shame to have to repurchase gears and a locker, but if that is the proper path forward, that’s the way it is.
    everyone on the Lexus forums with RCLTs also have Dana 60 rears. I thought was mandatory.
  10. Aug 22, 2023 at 6:16 PM
    #2590
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    You’re fine with a front track width being wider than the rear. Leave your rear axle alone if you don’t want to redo it all.
  11. Aug 22, 2023 at 7:09 PM
    #2591
    Kamille.bidan
    2017 Blue TRD OR MT
    there’s no disadvantage to have a front track that’s wider than the rear? I know a guy with a Land Cruiser 70, and he is spending thousands to change the rear axle.
    why spend the money if there is no advantage? Why spend 10K+ on a Dana 60?
    I did a few google searches, and I just end up back to Tacoma world.
  12. Aug 22, 2023 at 7:44 PM
    #2592
    RonRon23
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    They’re spending the money on STRONGER rear axles. Yeah they’re wider. But I don’t think these guys are spending the money to be wider…
    JordanTaco6 likes this.
  13. Aug 22, 2023 at 10:46 PM
    #2593
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Idk what other Lexus guys are running rclt other than a handful of the gx470 crowd, but most of those people in particular, as example, already know the 8” rear diffs are weak given a GX470 is a little over 700 lbs heavier than a 4x4 double cab taco for and factor in a v8 with more torque. Compound that with a lot of these guys slapping on 37-40” tires and I can see why they want to spend some extra money on a diamond rear end or whatever they throw under there. And then some people have a heavy offroad foot and snap everything they can apply throttle to.
    And like Rob Ron said they aren’t dropping the cash with a primary goal to match front width. That would be asinine and could be solved by quality spacers.
    Buttskevin21 likes this.
  14. Aug 22, 2023 at 10:49 PM
    #2594
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    A dana 60 rear isnt really any stronger than the 8.75 axle thats in your truck, maybe even weaker ontop of weighing more and having less diff clearance. If you're doing a rear axle, do a ford 9 as it will be better in every way compaired to a 60 rear.
    A wider front is unnoticeable in both desert and in the rocks, if anything more handy in the rocks since if your front tires fit thru something, your rear definitely will lol. On these long trucks, the rear wheels take a beating since they snag on everything.
    *edit, just saw your earlier post about you doing it on a gx. The 8"/8.2" or whatever the heck comes in those, they are garbage strength wise in the rocks with trucks this heavy, so a 60 would be an upgrade for that.
  15. Aug 23, 2023 at 9:29 AM
    #2595
    airkewled
    Kevin
    Moab
    2006 Tacoma DCSB
    The fine nuances of different track width front to rear to tune for under/oversteer/traction I would say are not something to worry about. If it were a big difference you *might* see some wandering on heavily crowned pavement as the front and rear are in slightly different paths in the valleys... I see your biggest concern here being the 4.56 gears you've got setup. Quite a few folks going to RCLT are running 37+ and if that's your intention as well, 4.56 might not be where you want to be at.
  16. Dec 1, 2023 at 7:40 PM
    #2596
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Anyone else see this on Insta today?
    That's a big steaming pile of awesomeness right there.
    :rofl:
  17. Dec 1, 2023 at 7:52 PM
    #2597
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    Didn't you know you're also supposed to spend $20k on portals for new spindles to avoid breakages like that? Get with the times...
  18. Dec 1, 2023 at 8:20 PM
    #2598
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Shit my first gen has done the twice and the entire truck cost me $5k
  19. Dec 1, 2023 at 9:31 PM
    #2599
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    just looked up his insta and I guess he already sas’d it…
    Ricardo13x likes this.
  20. Dec 2, 2023 at 7:20 AM
    #2600
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    wtf broke? between this and all the axle shaft problems why would you buy?
