Marble Rolling sound in dashboard
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacom08, Sep 26, 2019.
  1. Sep 26, 2019 at 8:18 AM
    tacom08
    tacom08 [OP] Well-Known Member
    Isaac
    Simpsonville, SC
    08 DCSB 2WD Rugged Trail Edition
    Flowmaster Super 10, K&N CAI, bumpers, LED taillights
    Anyone else run into this? I can't figure out exactly where it's coming from, it sounds like it's rolling behind the dashboard when I take a sharp turn quickly.
    I had an aftermarket radio installed by a local shop a few months ago if it helps.
  2. Sep 26, 2019 at 8:23 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The dash behind our trucks is actually pretty solid. It sounds like they may had dropped something or a piece of plastic retainer for the harness got loose and is rolling around.
  3. Sep 26, 2019 at 8:28 AM
    JerzRob
    JerzRob Well-Known Member
    Rob
    South Jersey
    2009 SR5 TRD Sport
    tacom08[OP] likes this.
  4. Sep 26, 2019 at 8:30 AM
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    It's a 10mm socket...
    JustinL, TegoTaco, seanb06 and 14 others like this.
  5. Sep 26, 2019 at 8:41 AM
    FishTaco401
    FishTaco401 Well-Known Member
    2005 Tacoma Base 4x4 2.7L
    Its an acorn. Damn mice.
  6. Sep 26, 2019 at 8:47 AM
    tacom08
    Isaac
    Simpsonville, SC
  7. Sep 26, 2019 at 8:55 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    There’s a lot of ones where an installer will set screws on the top of the dashboard. Odds are they did and one fell down in the ac vents.
  8. Sep 26, 2019 at 8:56 AM
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Remove the marble and the noise should go away
    JustinL, bigmw, seanb06 and 3 others like this.
  9. Sep 26, 2019 at 8:57 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
  10. Sep 26, 2019 at 9:41 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    LOL. So that's where they all go...
    THE_KiRRAx[QUOTED] likes this.
  11. Sep 26, 2019 at 9:48 AM
    Muddinfun
    Muddinfun Well-Known Member
    Yep, that was my thought. Turn the heater on high for an hour and see if that solves the problem.
  12. Sep 26, 2019 at 9:51 AM
    THE_KiRRAx
    Tampa, Florida
    I found one tied to a seagull once...true story.
    Seriously though, found one tied to fishing line that a seagull had swallowed the hook to, so he was dragging around a 10mm socket, and some nuts. And my gf at the time chased after that mofo and tackled it, and we got the park ranger to come remove the hook. So we waiting on the park bench....holding our new seagull friend. XD Named that mofo Milly like, 10 "Milly"meter. XD
  13. Sep 26, 2019 at 10:14 AM
    tacom08
    Isaac
    Simpsonville, SC
    Damn lol
  14. Sep 26, 2019 at 1:15 PM
    tacom08
    Isaac
    Simpsonville, SC
    It’s not the ac vents
  15. Sep 26, 2019 at 1:18 PM
    THE_KiRRAx
    Tampa, Florida
    Probably a dumb question but are you sure it's in the CAB? Does it sound like it's rolling on plastic, or on metal? Any chance there is something rolling in the channel below your window (engine bay) under that shroud? If that's the case it would be a prominent metal sound versus plastic. Thoughts?
  16. Sep 26, 2019 at 4:04 PM
    Rebirtha
    Rebirtha Well-Known Member
    Lance
    PDX
    2015 TRD OR DCSB
    Some installer is missing a socket ....
  17. Sep 26, 2019 at 4:08 PM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
  18. Sep 26, 2019 at 4:23 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    It's mine! Lol...By far the hardest socket to keep track of. Lol
  19. Sep 27, 2019 at 12:22 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    If not due to install, then remove the cabin filter and look in there. May have to drop the fan motor out 3 screws. Could be something dropped into the outside air vent intake area under the hood rear area plastic cover - pics on forum and yes squirrels and mice do get in there and leave stuff. Also rocks in the skid plates make same noise - been there removed many so after long gravel roads running at higher speeds I expect it as front tires throw rocks up underneath.
  20. Sep 27, 2019 at 8:55 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    It could be a bullet, have you been shot at recently?
