Manually shifting an Automatic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by teneighty, Aug 1, 2013.
  1. Aug 1, 2013 at 2:35 PM
    teneighty
    teneighty [OP] I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Anybody manually shift their Automatic? I searched and found a few threads but not what I was really looking for. I was wondering about brake wear.
    I've had mostly manual cars in the past and make it 80k or more before new brakes.
    I don't down shift all the time and when accelerating I just put it in drive but when I'm on known road/routes and I know where the hills and stop signs are I wouldn't mind down shifting to save the pads and rotors...
    Thoughts/experience?
    Flame me for such a stupid question?
  2. Aug 1, 2013 at 2:37 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Always manually shift mine. Feels weird not to. Works great. I've trained the computer to change gears at 3000-3500 rpms to keep the speed up. 20 MPGs baby.
  3. Aug 1, 2013 at 2:38 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    I do it often and I have not had any issues.
  4. Aug 1, 2013 at 2:40 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    I don't know if you just talking keeping out of 5th, or starting in 1 and shifting all through the gears? You're going to try and save $80 on brake pads by possibly missing a shift on a $3k trans?
  5. Aug 1, 2013 at 2:45 PM
    teneighty
    Negative
    like I said, only downshifting.
  6. Aug 1, 2013 at 2:46 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Rev limiter will keep the engine safe. Also even if you put it in 1st from 60mph the computer may shift down to 3rd (Or maybe even 2nd) but it won't let you hurt the tranny/engine.
  7. Aug 1, 2013 at 2:49 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Just a thought--what about the bands in the tranny-are you adding unnecessary wear? Higher rpms and a harder shift.
    BRAKES are cheap to replace-tranny work is NOT.
  8. Aug 1, 2013 at 2:51 PM
    teneighty
    That's why I'm asking...
    I was thinking about the smaller moving parts as well. Linkage and the actual shift lever...
  9. Aug 1, 2013 at 2:51 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    The A750 is a beast. Torn out of the 4.7L V8 4 Runner.
  10. Aug 1, 2013 at 3:15 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    What a stupid question!!!! No it's not, seriously.
    All I have ever owned is manual transmissions and I do the samething in my Tacoma too. You're not going to hurt anything if you downshift before a light, stop sign, on a hill etc. I am not sure how much it's going to make a difference on saving your brakes, it might, it might not. All I know is that going down a hill, I hate the smell of burning brakes. But you should be safe.
  11. Aug 1, 2013 at 3:19 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    It's not going to hurt the tranny to shift it
  12. Aug 1, 2013 at 3:25 PM
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
    The stupid thing downshifts itself when you press the brakes on a hill. God, I wish I could disable that.
  13. Aug 1, 2013 at 3:30 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    I do some. down shift and up shift. somes times if i get kinda board driving. or if it’s raining and i’m starting out going up hill from a stop i’ll down shift to 1st and shift my way back up to D, helps keep it from spinning.
  14. Aug 1, 2013 at 3:32 PM
    JKD
    JKD Well-Known Member
    The powertrain controller already downshifts to help with braking. There are some circumstances where I could see the point of manually downshifting (such as going down a mountain road where brakes might overheat), but in general I would rather wear cheap and easy to replace brake pads/rotors/shoes/drums than expensive and difficult to replace transmission parts.
  15. Aug 1, 2013 at 4:28 PM
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    you could install jake brake on it
  16. Aug 1, 2013 at 4:31 PM
    mr2mki
    mr2mki Well-Known Member
    Man, that might be a little rude, but could you imagine hearing the "brapbrapbrap" and looking over and seeing a dinky little Taco? :D
    Of course, with the much smaller engine and such, I'm sure the noise wouldn't be quite as impressive.
  17. Aug 1, 2013 at 4:33 PM
    OZ-T
    Peter North
    British Columbia
    Why do people think you are going to damage the tranny if you manually select a gear ?
    That's stupid
  18. Aug 1, 2013 at 4:35 PM
    mr2mki
    I've always been a little hesitant to over-use the manual select in an auto box, because most autos I've driven do not make downshifts smoothly. It's no big deal for occasional use for maneuvering in a snowdrift or engine braking down a monster hill, but I avoid using it all the time to avoid needless strain from the choppy shifts that are its wont.
  19. Aug 1, 2013 at 4:38 PM
    OZ-T
    Peter North
    British Columbia
    Wonder why they bother putting anything other than P - R - N - D on the selector
    :notsure:
    Maybe Toyota wants us to destroy our transmissions
  20. Aug 1, 2013 at 4:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They better do something different then....I shifted the shit out of mine and never had issues.
