Manually locking up the torque converter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by S.B., Oct 19, 2012.
  1. Oct 19, 2012 at 7:54 PM
    S.B.
    S.B. [OP] Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Has anyone ever done something like thing on our A750 trans? How well does this tranny respond to this?
    I've been researching valve body upgrades and came across a company called West Coast Cruisers. They sell a "kit" that with a flip of a switch will lock up/keep the torque converter locked up, but they want over $200. http://www.westcoastcruisers.com/transfer.php
    I think I have figured the wiring out for this, just need me a relay.
    I figure this would really help towing and goin slow down hill.
  2. Oct 19, 2012 at 8:00 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    what are the benefits of this? and are the potential benefits worth 200 bucks?
  3. Oct 19, 2012 at 8:05 PM
    S.B.
    Sean
    San Diego
    15 Taco
    My thinking is:
    -Less heat build up from the torque converter, especially when going slow and loaded up.
    -Can control down hill speed, like a manual, better
    I wouldn't buy the "kit". I would do it my self for like $30
    I'm just wondering if anyone has done this and if anyone thinks there would be adverse effects?
    I know on the older dodge diesel auto, you had to do this kind of mod unless you wanted to replace the tranny all the time.
  4. Oct 19, 2012 at 8:13 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    That kit looks like a $5 rocker switch wired to a $3 relay...
    Interested to hear more about the principle. It would help with gas mileage too I would think. (highway)
  5. Oct 19, 2012 at 8:15 PM
    S.B.
    Sean
    San Diego
    15 Taco
    exactly.
    I just wonder if anyone here has done it. I've been searching other forums (IH8MUD, TTORA, XRU, and here), but have come up with nada.
  6. Oct 19, 2012 at 8:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The tranny not only locks and unlocks, but can achieve different levels of "lock up" in gears 3 thru 5. Toyota seems to have gotten it right, so I cant see a reason to mess with it.
  7. Oct 19, 2012 at 8:29 PM
    S.B.
    Sean
    San Diego
    15 Taco
    U think their would be any adverse effects?
  8. Oct 19, 2012 at 8:32 PM
    650H1
    Michael
    VA
    so this would lock the transmission into one gear and not let it shift? that has the potential to be awesome...
  9. Oct 19, 2012 at 8:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont know. There could be.
  10. Oct 19, 2012 at 8:41 PM
    S.B.
    Sean
    San Diego
    15 Taco
    No, just so it "acts" like a manual in a sense. It locks the converter so that it will not do partal shifts, it will stil shift.
  11. Oct 19, 2012 at 8:42 PM
    650H1
    Michael
    VA
    well our downhill assist BS is practically the same thing. i actually think its obnoxious when i tap my brakes going downhill and it shifts down on me instead of coasting.
  12. Oct 19, 2012 at 8:43 PM
    S.B.
    Sean
    San Diego
    15 Taco
    I can see there some if its used incorrectly, but my intensions are going down hill and towing, except for starts.
  13. Oct 19, 2012 at 8:45 PM
    S.B.
    Sean
    San Diego
    15 Taco
    But this has the potential to acctually slow the truck down, unlike now where it may down shift but unlocked which does not slow it much, just builds a lot of heat (I think). I'll be installing my tranny temp gauge this week and I'll check on the temps.
  14. Oct 19, 2012 at 8:46 PM
    650H1
    Michael
    VA
    could you just leave it locked all the time?
  15. Oct 19, 2012 at 8:59 PM
    S.B.
    Sean
    San Diego
    15 Taco
    I don't think so, cause from starts or coming to a stop, I think it would stall.
  16. Oct 19, 2012 at 10:01 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Slow and loaded up, the TCC is not locked anyways.
    Depends on the vehicle, but most will only lock in direct and overdrive... some of the 5 and 6 speeds will lock in 3rd or 4th, but under any moderate load at all, it unlocks.
    Locking under those conditions is going to be hard on the driveline.
    Downhill speed control is a benefit, but the 2nd Gen system is already pretty tight... I don't think the TCC is unlocking.
  17. Oct 19, 2012 at 10:46 PM
    S.B.
    Sean
    San Diego
    15 Taco
    With going slow, ya the tc is not locked thus creating a lot of heat.
    I don't believe that the tc is ever locked with down shifting to control down hill speed.
    But I think I might tackle this this weekend. I'll update this as I learn more about it.
  18. Oct 19, 2012 at 11:13 PM
    badger
    badger Well-Known Member
    07 SR5
  19. Oct 19, 2012 at 11:18 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Thought they were the same size?
    Not really worried about it, plenty of supercharged 4x4 pushing 350+.
  20. Oct 20, 2012 at 12:45 AM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    Having the torque converter lock and unlock manually is a BAD idea. The only people that really need them are the diesel crowd and the drag racers. The converter locks up at 30-40 mph anyways and stays locked up until you either A. Tap the breaks. B. slow down. There is absolutely no reason for this at all unless you are doing trailer pull competition or getting ready to run a 10.68 in a 1/4 mile. It is way better on gas milage, and the engineers design them to 1. Last for a long time, and 2. Allow for the maximum gas milage possible out of the vehicle. Don't mess with the tranny! Trust me, I was a trans tech for years for GM and there where very limited thing that you needed to do on a 4l60e to make it last longer and a little more efficient.
