Manual Transmission Remote Start Issue.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CalcityRenegade, Apr 2, 2020.
  1. Apr 2, 2020 at 8:08 AM
    CalcityRenegade
    CalcityRenegade [OP] Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Good Morning Taco Team. I need some help with my manual transmission remote start. I recently purchased a certified used 2016 Taco TRD Sport Premium 6MT. First Toyota product and love it! It came equipped with a Compustar 1WG9R-SP remote start. To equip it for the next start I follow the process the dealership showed me.
    1: Turn key to off.
    2: Pull out key leaving engine running.
    3: Exit vehicle.
    Upon exiting the truck it will shut off and lock the doors automatically. When I press the start button it does start the truck but it does so with the lights flashing and horn honking as if you pressed the panic button. I have tried it many times always with the same result. I have always driven manual transmission but have never had remote start before so am a bit disappointed that I can not use this function as intended as it is still cold season up here in Canada. I appreciate any feedback on this.
    Cheers!
    Junkhead likes this.
  2. Apr 2, 2020 at 8:11 AM
    CalcityRenegade
    2023 T4R ORP KDSS
    They want me to bring the truck in for diagnoses but no known date due to COVID19. Plus I may be on the hook for a diagnostic fee which I would prefer to avoid.
  3. Apr 2, 2020 at 8:16 AM
    Clearwater Bill
    Billy
    Largo Florida
    You should not be, assuming you are still in your warranty period.
    When they demonstrated the remote for you initially, did it work as expected, since you say they showed it to you? Maybe there is a step or two left out of the written instructions?
    What does the Compustar website say? Most places like that have instruction manuals online.
    whatstcp likes this.
  4. Apr 2, 2020 at 8:44 AM
    Lutrev
    Lutrev Well-Known Member
    2018 MT black pro
    2.0 SFOB OV tune, ADM, MESO v4,stage 1 tail,maps and dome,etc
    I have the same remote.. I have to pull the hand brake twice to set the remote before turning key to off position then it will lock and arm the remote after shutting the door.
    Truck was bought at south point Toyota with the remote installed
    CalcityRenegade[OP] likes this.
  5. Apr 2, 2020 at 8:45 AM
    CalcityRenegade
    2023 T4R ORP KDSS
    I purchased Toyota's extended care coverage. I may not be covered as it was not installed by Toyota. I learned this when the brand new windshield was not sealed properly and water poured into the cab when I took it through the carwash. Toyota water tested the truck and found the problem but denied coverage as they did not install the windshield. Buddy who traded it in must have put a new windshield in right before. Only reason they did not charge me a diagnostic fee that time was it was in for a TSB and warranty on the backup camera.
    The salesman started it no problem and I am sure I am following the procedure as it is starting the vehicle. No manual available from Compustar. Only a quick start guide which only mentions hitting the start button.
  6. Apr 2, 2020 at 8:51 AM
    CalcityRenegade
    2023 T4R ORP KDSS
    UPDATE!
    I found these directions under Computstar support which may been my problem. I must have missed the step about holding the brake pedal down. I will try this tonight and see if it makes a difference!
    KEY -
    1. While the vehicle is running place the transmission into neutral, set the emergency brake, and then remove pressure from the foot brake.
    2. Remove the vehicle key from the ignition. If done properly the engine will continue to run after the key has been removed.
    3. Exit the vehicle and close the door. The vehicle's engine should shut off on its own within 10 seconds of closing all of the doors.
    4. Once the vehicle shuts off your system will be in reservation mode and is ready to safely remote start.
  7. Apr 2, 2020 at 8:56 AM
    Lutrev
    2018 MT black pro
    Sorry missed the brake pedal part, they install a micro switch in the handbrake to confirm it’s activated for starting. I do a double on the handbrake as it will sometimes not engage, just a small engagement cycle, not reefing it on twice.
  8. Apr 2, 2020 at 9:05 AM
    CalcityRenegade
    2023 T4R ORP KDSS
    Good to know. I will try this as well. I also bought mine at South Pointe lol.
  9. Apr 2, 2020 at 10:51 AM
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    For my remote start there has to be a sequence of:
    This must start while in gear, takes a while to pick up and perfect ....
    -Push and hold the brake pedal
    -Put into neutral (while still holding down the brake pedal)
    - Engage E-brake (while still holding down the brake pedal)
    - release brake pedal
    - turn off truck
    - truck will stay on until driver door is closed
  10. Apr 2, 2020 at 11:00 AM
    CalcityRenegade
    2023 T4R ORP KDSS
    Thanks. I have been missing the brake pedal part. It did not occur to me as the truck still started lol.
  11. Apr 2, 2020 at 11:20 AM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    I don’t know about compustar settings and such but it sounds like the alarm is getting set off when the remote start turns on the ignition. My Fortin Evo One did the same thing until I realized i had to set it to “unlock before/relock after” to disable the factory alarm. Also it can take a minute or two for the alarm to arm and if you remote start it before the security light starts flashing it won’t set off the alarm, that could be why it didn’t do it when the salesman showed you.
  12. Apr 2, 2020 at 3:21 PM
    Lutrev
    2018 MT black pro
    So does it work now ?
  13. Apr 2, 2020 at 3:45 PM
    CalcityRenegade
    2023 T4R ORP KDSS
    I shall check after work and report back in the morningtide!
    shakerhood likes this.
  14. Apr 3, 2020 at 8:11 AM
    CalcityRenegade
    2023 T4R ORP KDSS
    So I tested using the brake pedal during to procedure as well as the double handbrake technique and no change. Vehicle still starts with horn honking and lights flashing. :confused:
  15. Apr 4, 2020 at 9:30 AM
    CalcityRenegade
    2023 T4R ORP KDSS
    UPDATE! I found someone posted a question on a Compustar website about the same issue with their automatic 2016 Toyota RAV4. It appears the remote start is interfering with the factory alarm system. A remedy was to hit unlock on the factory keyfob before hitting start on the Compustar keyfob. The truck now starts without the horn honking and lights flashing. Only caveat is that you have to remember to lock the truck after is starts. I just remembered that the dealership put a new battery in the truck for me so perhaps they need to reprogram the remote start? I have to take the truck in for my new warrantied backup camera when this COVID19 situation blows over so they will have it anyways. At least I have a workaround in the interim.
    Pickupman2007 likes this.
  16. Apr 4, 2020 at 9:38 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Hmmmm . . . I would never leave any MT parked and out of gear. Guess I'm not a remote start guy.
    G.
  17. Apr 4, 2020 at 10:04 AM
    CalcityRenegade
    2023 T4R ORP KDSS
    Yeah but you live in NC and I live in Canada. The weather sucks up here. You are at 73f right now and we are at 5f and this is the warmest its been all week. However I have driven manual for years and never once had remote start. Feels odd leaving it in neutral. But if the dealerships sell and install these I will trust my truck to stay where I leave it. Plus its only seasonal anyways.
    Garyji[QUOTED] likes this.
  18. Apr 4, 2020 at 10:31 AM
    Lutrev
    2018 MT black pro
    Right on. I use mine all year,never parked on anything but flat surface so never worried about leaving it in gear. Glad you found a workaround
  19. Apr 4, 2020 at 7:12 PM
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    For our 6MT (HKEY manual) kits (and HKEY auto kits as well), we flash the modules to automatically on its own to lock, unlock, lock the vehicle to disable the alarm system after your hit lock 3 times to start it so you DON'T have to remember to do this. Sounds like they installed it and forgot to do that for you because I bet when they tested it after the install, they tested it after shutting the door...which means they remote started it BEFORE the vehicle armed itself. Had they locked the vehicle, and let it sit for a couple minutes (to give the alarm a chance to arm itself, they would HAVE seen this issue).
    If you don't have means to re-flashing it yourself, find the install guide (you'll have to know what model number you have) and there may be two wires you can short together ON the remote start harness (nothing from vehicle) that will do this and you won't need anyone, or any software...
