Manual transmission oil: Liqui Moly 20012 GL4+
Discussion in '3rd Gen. Tacomas (2016-2023)' started by whiseve, Oct 9, 2022.
  1. Oct 9, 2022 at 5:40 AM
    whiseve
    whiseve [OP] Active Member
    Ohio
    '21 DCSB 6MT Voodoo Blue
    Hi folks,
    I'm changing the factory fluid in my 6-speed manual transmission because it crunches going into second and third unless I really take my time. I suspect the factory put the same fluid into the transmission as the diff.
    Has anyone tried the Liqui Moly GL4+ in the transmission? According to the data sheet, it it formulated specifically for manual transmissions and not differentials. NAPA carries it. They have a different "GL4/GL5" product sold as a diff lube.
    (I am familiar with Redline MT-90 and have used it in a previous vehicle.)
    W.
  2. Oct 9, 2022 at 6:42 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
  3. Oct 9, 2022 at 7:16 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    I would just swap to redline, I did mine last year and it made a huge difference in shifts to 1st and 2nd gear
  4. Oct 9, 2022 at 7:23 AM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    I’ve tried it. It’s good stuff. The 2nd gears are crunchy. At least on the 5 spd manuals they are which is what I have. It performed pretty well in the winter and summer. I can’t say I had any complains about it. After pretty much trying every manual trans fluid spec’ed for GL4 75w90 I can say I havnt noticed one is a miracle fluid and light years better than another. The only thing I noticed was that the fluid was good for maybe 25k ish where as on redline I typically get 35k or so out of a fluid change before the shifts get crunchy again. They all seem to perform well out of the bottle with varying performance with mileage. I had gotten a good deal on it at the time, I think it was $7 per liter on rockauto. I’d use it again if I find a good sale on it.
    whiseve[OP] likes this.
  5. Oct 9, 2022 at 8:10 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Looks good, similar in most specs to the MT-90 but cold performance should be better.
  6. Oct 9, 2022 at 11:34 AM
    lbhsbz
    lbhsbz Well-Known Member
    Disregard the brand...if it meets GL4 specifications, its the right stuff. Liquimoly is a high end brand. I would choose that in a heartbeat
    cryptolime and whiseve[OP] like this.
  7. Oct 9, 2022 at 3:41 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Wulf, shakerhood and whiseve[OP] like this.
  8. Oct 11, 2022 at 5:43 PM
    whiseve
    Ohio
    My local NAPA didn't have the Moly on the shelf but was able to get it same-day, so that's what I got. Will report back soon on how it drives.
    Is the torque really 27 foot-pounds on those drain and fill plugs? I started getting uncomfortable tightening the plug down and ended up torquing the drain to 25 and the fill to 23. I assume those are lubricated specs since there's no way to have dry threads in this scenario. There's something about tightening something like that with 18" of leverage (1/2" drive torque wrench) that's a little scary.
  9. Oct 11, 2022 at 6:00 PM
    Sep1911
    2016 Taco
    yes it is. I usually do 30 because I’m lazy. Lol
    whiseve[QUOTED][OP] likes this.
  10. Oct 11, 2022 at 6:00 PM
    InThePlains
    InThePlains Well-Known Member
    You can feel the aluminum crush washer deforming, that's it.
    I've put MT90 in all my Toyota manual gear boxes in the past and present, no complaint. 94 4Runner, 99 4Runner, 2008 Tacoma, 2019 Tacoma.
  11. Oct 11, 2022 at 6:57 PM
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    Don't forget the perpetual rockauto 5% discount code!
    RustyGreen[QUOTED] likes this.
  12. Oct 12, 2022 at 11:42 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    don't have a manual tacoma but i had a manual corolla and redline mt-90 fixed all my shifting issues. stuff is like liquid gold. i'm sure any gl-4 oil will work. just don't use GL-5.
    shakerhood likes this.
  13. Oct 13, 2022 at 10:07 AM
    Stewart
    Stewart Well-Known Member
    Kenosha, Wisconsin
    2017 Red SR MT AC 4x4 long bed
    OR Wheels, cruise, intermittent wipers, carhart seat covers, FT-7900R
  14. Oct 13, 2022 at 10:44 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I have not used Liqui Moly before but was happy with the results of MT-90 in my 2016 6MT and now 2020 6MT.
  15. Oct 13, 2022 at 11:51 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    + on MT-90. Good stuff and I used in on my last change-out.
  16. Nov 17, 2022 at 10:26 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    So is the consensus that the trans is crunchy in 2nd? Mine seems to have been since day 1…
    does the new trans fluid improve that?
  17. Nov 17, 2022 at 2:05 PM
    Sep1911
    2016 Taco
    From my experience they all initially improve it but after a couple hundred miles it returns. I find driving a certain way is the cure for it. And really it’s just shifting slow into 2nd at around 2k rpm. To be frank though I have 4.88 gears and the truck will pick up and go even when short shifter, can’t speak for factory gearing
  18. Nov 17, 2022 at 2:13 PM
    maxmk8
    For me it’s just the feeling of engaging the gear. Rpm’s don’t seem to matter. However 2k rpm’s may be a bit on the low side and too slow for accelerating with traffic in this thing.
  19. Nov 17, 2022 at 2:17 PM
    Sep1911
    2016 Taco
    Yeah I know what you mean. If you have to rev it out then you have to rev it out. If it’s of any consolation I’m at 135k it still does it like day 1 and the truck is going strong. I’d like to think it’s because it’s rugged:D
  20. Nov 17, 2022 at 2:18 PM
    maxmk8
    That’s actually really helpful. Are you on the original clutch also ?
