Manual transmission neutral safety switch
Discussion in '1st Gen. Tacomas (1995-2004)' started by Diddy Spicebush, Jul 21, 2019.
  1. Jul 21, 2019 at 5:20 AM
    Diddy Spicebush
    Diddy Spicebush [OP] Well-Known Member
    Brent
    Saco Maine
    2003 sr5 2wd x-cab,and 2017 6/spd m/t sport
    Yakima roof and bed rack and tubular rear bumper.
    is there anything more to it than the button on the clutch pedal bracket?
  2. Jul 21, 2019 at 8:45 AM
    Glamisman
    Glamisman Well-Known Member
    Other than the clutch start cancel switch no, there is no neutral saftey switch on the transmission at all... I found this rather odd.
    What problem are you having? I have as well as others, wiring diagrams that can be uploaded if you are experiencing start/crank issues.
    License2Ill likes this.
  3. Jul 21, 2019 at 8:55 AM
    Diddy Spicebush
    Brent
    Saco Maine
    Not on the transmission, under the dashboard on the pedal bracket there is a button the pedal pushes down when you step on the clutch.
  4. Jul 21, 2019 at 9:22 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just what are you trying to ask?
    What problem are you having??
  5. Jul 21, 2019 at 10:17 AM
    Diddy Spicebush
    Brent
    Saco Maine
    Put key in ignition, step on clutch, turn key, nothing happens, let off clutch step on it again, truck starts.
  6. Jul 21, 2019 at 10:28 AM
    mullski19
    mullski19 Active Member
    I had this same exact problem a couple days ago (2002 3.4 manual). You are correct there is a button that gets pressed in when you push on the clutch; that is the safety switch. I didn't have the time or patience to try and find the part online, order it, and install it. I ended up just using electric tape and taped a random screw to the back of the clutch pedal so the button would get pushed in more. It fixed the problem instantly.
  7. Jul 21, 2019 at 10:50 AM
    Diddy Spicebush
    Brent
    Saco Maine
    I hear you. 16 years just wore out the contact point and you have pushed it past to another point.
  8. Jul 21, 2019 at 12:20 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The first thing I disconnect nothing but a pain
    Might be your just pushing the clutch in more the second time
  9. Jul 21, 2019 at 12:54 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Try pushing the clutch start cancel switch on the dash. Then make sure your clutch pedal is adjusted properly.
  10. Jul 21, 2019 at 3:06 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    the switch in the dash is magnetic, once tripped it holds “ON” until power is released, usually from key off.
    there is a switch in the clutch pedal rest under the dash that can fail, there is a second switch next to it that is for cruise control release. make sure you get the correct switch
    84520-24010 for clutch start
    84340-32070 for cruise release (4 part numbers for this switch)
  11. Jul 21, 2019 at 8:43 PM
    Diddy Spicebush
    Brent
    Saco Maine
    Thank you,a straight answer. With a caution. I have no clutch start cancel but do have cruise. I’ve only got a few straight answers on TW and a bunch of ball busting.
  12. Jul 21, 2019 at 8:46 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    those are looked up for my ‘97 4Runner, the parts should be the same, but there is a possibility they are different.
  13. Jul 21, 2019 at 10:50 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I don't know about these trucks, but I had to tow a Honda Civic to my place that had a no crank-no start issue. Turns out the plastic bushing that would depress the button for the cutch safety switch just crumbled into pieces due to age. I just shorted the switch connector with a paperclip and it started up fine.
  14. Jul 22, 2019 at 8:30 AM
    Diddy Spicebush
    Brent
    Saco Maine
    Well that was easy. Remove with 14mm, 3 awls or small screwdrivers depress tabs and slide cover off,clean contacts, replace cover, reinstall. 1/2 hour total. There she is in her home.D1F7CD4A-DA3F-4EC2-83EE-927D0BE416F3.jpgB5671160-76B0-4CCF-9479-FC568036E00C.jpg3D7CA5ED-B2F0-4C54-BF54-5AFC93F448A0.jpg6620B8A8-5983-4BCA-BE4A-2EB3C7E8093E.jpg30EB7C6A-E50F-4975-98C1-00D93A3AB4BD.jpg8062A2E3-B81E-482F-AF61-28E16DCD3237.jpg
    DaTacoNL likes this.
