Manual Transmission needs Replaced
Discussion in '4th Gen. Tacomas (2024+)' started by orignalohiotrojan, Apr 9, 2024.
  1. Apr 9, 2024 at 11:26 AM
    orignalohiotrojan
    orignalohiotrojan [OP] Member
    So picked up my beautiful new 2024 TRD Off Road Orange Taco on Saturday, by Sunday afternoon, gears 2,4, and 6 were nonexistent. Toyota was super nice in picking up the truck and providing a rental. The bad news!?! The district customer service advisor said that ALL manual transmissions were manufactured with a major defect, and ALL of them produced through a certain date needed to be replaced. FML. Want to love the truck and keep forever, but super not comfortable with transmission swap. I mean how many techs at the dealership have even performed a full transmission swap. And I have no faith an engineered and produced superior replacement trans is in the near term? I'm saddened
  2. Apr 9, 2024 at 11:37 AM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    Yeah bullshit...If this was me they would be taking it back, not repairing it if you only had it for a day.
  3. Apr 9, 2024 at 11:45 AM
    sopranojam85
    sopranojam85 Well-Known Member
    2024 Black Tacoma SR DBL cab 4x4 6M
    This is the first I have heard of this. I wonder if what the district manager said is at all true or a made up smoke blower CYA story. What build dates did they give? Any clues on how an owner could check this date? Is it stamped on the transmission itself or what?
    .mr.e. likes this.
  4. Apr 9, 2024 at 11:47 AM
    Korywithak
    Korywithak Well-Known Member
    Central Pa
    2024 TRD Sport Premium in Windchill
    Sounds…. Fishy. :rolleyes:
    Rocko, BrokenMachine and Jeff Lange like this.
  5. Apr 9, 2024 at 11:47 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I'd rather the dealer swap the whole tranny than have someone there open it up and fix what's broken, easily.
    Lucky for you they are just gonna swap it out, eventually. Toyota dealers probably pretty good about doing the swap anyways. Sorry to hear about your rotten luck though.
    drizzoh, RedWings44, crepr12 and 13 others like this.
  6. Apr 9, 2024 at 11:55 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I wonder if it has anything to do with the extension housing for the shifter. Toyota is using mostly the same transmission from the Hilux and the previous gen Tacoma. It's the Hilux transmission, with a Tacoma length input shaft, and a new shifter extension housing to put the shifter where it needs to be in the cab in the new truck, due to the trans being mounted to a 4 cylinder.
    The only part I could see them having screwed up widespread would maybe be something in the extension housing that caused you to no longer engage the rear 3 gears.
    Highly doubt there is a widespread issue with the new trans that will be difficult to fix. As I said, it's mostly built from parts that came out of existing, very similar transmissions. It would be hard for them to screw it up in a bad way.
    Also, I would not be concerned about the dealer installing another transmission. That is not a big deal.
    .mr.e., SR-71A, Chris(NJ) and 6 others like this.
  7. Apr 9, 2024 at 12:08 PM
    orignalohiotrojan
    it's a real reply, they showed me a bunch in california that are awaiting new transmissions. apparently california sales started earlier and has many more manuals on the road that anywhere else. no eta on the replacement transmissions. their reply was legit, they have no reason to bullshit, it actually would be a horrible fish story, they are setting themselves up for lemon law. I just want my truck back fixed.
  8. Apr 9, 2024 at 12:12 PM
    orignalohiotrojan
    I was thinking the same at first, that they extended the shifter and lever point, especially since the symptom felt exactly like that. the symptom was it was like it didn't quite reach those gears, 2,4,6 was like it missed going in by 1/2".
    Steves104x4 likes this.
  9. Apr 9, 2024 at 12:17 PM
    BLtheP
    Plano, TX
    Don't wanna jump the gun, but I would bet that's the problem or at least a significant part of it. Since all 3 of those are on one side, and all feel like they miss by the same amount.
    I would be extremely surprised if it was something internal like the forks or rods or synchros being problematic. Most of those parts are the exact same parts used in the 3rd gen's RC62F, which have been reliable. Hopefully they'll get it sorted soon and send you on your way.
    I'm actually buying that transmission for my 3G, it's on backorder for me currently (1.5 months now) and your post had me concerned, but if that's the problem then I guess it won't affect me because I'll have to remove that housing anyways. 3Gs have no extension housing. Guess we'll see how it turns out.
  10. Apr 9, 2024 at 12:22 PM
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    Isn't this basically the same 6 speed transmission from the 3G? I though Sheldon said it was *mostly* carried over. The shift knob itself is even identical.
  11. Apr 9, 2024 at 12:27 PM
    BLtheP
    Plano, TX
    Kind of. It is the RC60F, but a version that hasn't been created before. It has the RC60 ratios. Same RC transmission family from the 3G. It is essentially a Hilux transmission with a longer input shaft to fit the Tacoma. The Hilux version of the RC60F has an extended shifter housing. The 2024 Tacoma RC60F also has an extended shifter housing, but a different one than the Hilux version. The 3G has the shifter installed directly on top of the opening.
    Sheldon said a few things that made it kind of confusing and convoluted to figure out what they actually did until it was able to be confirmed by the specs. Most of what Sheldon said didn't really make sense.
  12. Apr 9, 2024 at 1:29 PM
    Clearwater Bill
    Billy
    Largo Florida
    It only takes one. For an R & R it can't be all that different than most anything built since the 60's.
  13. Apr 9, 2024 at 1:38 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Not that big of a job honestly. On another note, sorry to hear about your current situation on a brand new truck
    boston23 likes this.
  14. Apr 9, 2024 at 2:06 PM
    ericin1984
    ericin1984 Well-Known Member
    2023 TRD OR Auto
    In the early 2000s I bought a brand new Honda Civic EX manual. Within 100 miles, it was obvious that the transmission had synchro problems, which got steadily worse until I took it in under warranty at 500 miles and the transmission was replaced. I drove the car for another 3000 miles and it still had occasional issues with missing shifts or rough engagement. Traded it in after that.
  15. Apr 9, 2024 at 2:17 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Can you get a refund if your brand new vehicle shits the bed in such a short time?
  16. Apr 9, 2024 at 2:24 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Don't worry about it. If you want to keep the truck long term, the transmission will likely come out a few more times for clutch and throw out bearing replacement, rear main seal leaks, etc.
  17. Apr 9, 2024 at 2:38 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Probably in some states. Most you would have to lemon law it.
    STEELeR43 and SH10151[QUOTED] like this.
  18. Apr 9, 2024 at 2:44 PM
    SunRunner
    SunRunner Rub some dirt on it!
    Scott
    Pennsylvania
    ‘19 ORLB
    That stinks OP. This is why many people won’t buy a first year new-gen vehicle. Nevertheless, I bought a first year 2nd gen Tacoma back in 2005 and it was trouble free for over 100k until I traded for a full size truck. Hopefully they’ll get you fixed up properly and it’ll be nothing but smiles from there. Good luck with the truck.
  19. Apr 9, 2024 at 2:51 PM
    SlippRott
    SlippRott Well-Known Member
    22 Silver OR
    Planning...suspension, front slimline bumper, winch, full skids, 2" lift, SCS Ray 10's, Pizza cutters, Power Tray, Switch-Pro, Alu-Cab Contour Canopy.
    If they have to swap the trans out and it is brand new then wouldn't the warranty on it get extended also as a result? Or maybe you should be asking for that as compensation. 7/72,000 like they do on Certified used?
  20. Apr 9, 2024 at 3:04 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The good news: Manual transmissions are traditionally less than 2% of the trucks built. And they've only released a few 2024's with any transmission, I've yet to see one. There can't be that many out there waiting for a new transmission so it shouldn't take too long. I had to wait almost 2 years to get my leaf springs replaced. But at least I could drive it while I waited.
