Manual transmission Fan Club and BS thread (All Generations Welcome)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Dec 21, 2015.
  1. Aug 12, 2018 at 3:23 PM
    #8641
    Gcsteve
    Gcsteve Well-Known Member
    long island
    2015 Red sold, 2017 Inferno Sport Traded for a Honda w/ payload #1500
    When towing my trailer, if i am starting out in first gear I rev the engine to get started and it seems as soon as it gets in gear the revs are come all the way down and it moves real slow especially if I am starting out uphill. Do you guys think I should bother getting the rpms up or just start out as I normally do when not towing? This is the first manual I ever towed with. My trailer is about 3000lbs. So I figured i would ask you much more experienced people. Thanks
  2. Aug 12, 2018 at 3:37 PM
    #8642
    Beemaster
    Beemaster Well-Known Member
    Stanley
    California
    2016 Silver Tacoma TRD Sport 4x4 6MT
    If you can’t go to 4-LO, you should feather the clutch and get the RPMs up until you get up to speed. Pulling that load uphill at low RPMs will stress the transmission. (It will lug). I’d say shoot to keep it above 2500rpm while towing in any gear.
    Dctaconny likes this.
  3. Aug 12, 2018 at 3:43 PM
    #8643
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    To add to this the RC62F has a bolt on steel guide shaft for the throwout bearing. The aluminum guide tube went away with the RA series transmissions. There is no pilot bearing on the RA or the RC input shafts though witch kind of irritates me.
  4. Aug 12, 2018 at 5:08 PM
    #8644
    D-Rock531
    D-Rock531 Well-Known Member
    Tucson
    2017 TRD "PRO" 6MT ACLB
    Bilstein 5100, ARB Single, 4.88 Gears, 33" on Method 305
    so glad to find this thread! manual transmissions are undervalued and need to be saved!
  5. Aug 12, 2018 at 5:10 PM
    #8645
    D-Rock531
    Tucson
    I'll also throw out that I have 33" tires and just re-geared to 4.88 and it's amazing. I highly recommend the other 3rd gen manual owners do the same. Plus you can sell your 4.30 gears to an auto owner on this forum for at least $500.
  6. Aug 12, 2018 at 5:54 PM
    #8646
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Considering you've been inside this transmission. How durable would you say this transmission is?
  7. Aug 12, 2018 at 6:02 PM
    #8647
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I think that photo is looking through the inspection cover.
    Dctaconny and tonered like this.
  8. Aug 12, 2018 at 6:58 PM
    #8648
    RedBeard1
    Red
    The AC6 in the Tacoma labeled as RC62F really looks to me like Aisin Seiki took the H155f (70 series land cruiser 5speed) beefed it up a little, added another gear and designed a new case for it. Aisin labels it as a high torque transmission. Where as the RA series transmissions from the 2nd gen was categorized as a high torque unit that they no longer produce. Should be a jam up transmission. My hope is that they are as tough as the R150-156 transmissions of the past.
    I am hoping to have my hands on a RC61F in the near future I have a couple of guys watching for a used one to come up in AU, NZ or PH. The first, reverse and sixth gear ratios are much better in them. I am itching to swap one into my Tacoma. Great thing is it should be a direct fit.
    Edited content for correction.
  9. Aug 12, 2018 at 7:32 PM
    #8649
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Is that 4x4 compatible?
    I see it says RWD.
  10. Aug 12, 2018 at 7:36 PM
    #8650
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    However, that said, if you're sourcing a container loaded with RC61F count me in. I'd be all over helping offset shipping. Seriously.
  11. Aug 12, 2018 at 7:47 PM
    #8651
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    If they're still making manuals, I'll be buying them. Looking out at the 3 vehicles in our driveway of our house and there is not an auto to be found. I get it, autos are actually pretty good, especially if you're towing, but the ability to jumpstart is pretty key to me (especially since the wife likes to leave the headlights on:annoyed:), as is the connection to the vehicle. I don't drive much, but I like to engage in the activity, and I RARELY hear issues with manual transmissions.
  12. Aug 13, 2018 at 5:58 AM
    #8652
    RedBeard1
    Red
    I stand corrected on the AY6 my old memory I dint serve me well I was thinking AZ6 for some reason. I will correct my post. Thank you.
    I am trying to get my hands on one RC61F as it stands. Hopefully I can get one from AU as my friend that lives there works for DHL and gets a hefty discount on air freight.
    DaveInDenver[QUOTED] likes this.
  13. Aug 13, 2018 at 7:04 AM
    #8653
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Lucky guy, wish I knew people in Australia or DHL. But both? Nice.
  14. Aug 13, 2018 at 8:45 AM
    #8654
    RedBeard1
    Red
    Own a home in the Philippines and worked overseas for 10+ years you can make lots of connections.
  15. Aug 13, 2018 at 8:46 AM
    #8655
    RedBeard1
    Red
    Yes they are built in both the 4WD and RWD configurations.
  16. Aug 13, 2018 at 8:52 AM
    #8656
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Ever consider using them for a business, like bringing in engines and transmissions? I've never had the chance to travel overseas but imagine this magical land down under that has junkyards full of discarded engines, transmissions and manual t-cases just waiting for homes in Tacomas.
    Dctaconny and specter208 like this.
  17. Aug 13, 2018 at 12:05 PM
    #8657
    RedBeard1
    Red
    I have in the past shipped 3 containers loaded with JDM parts out of the Philippines (cheapest place to get JDM parts I have found) back to the US. It is really a lot of hassle and I don’t have the space for doing it now.
  18. Aug 13, 2018 at 12:53 PM
    #8658
    akTacoBlanco
    akTacoBlanco Well-Known Member
    Omaha, NE
    2017 White Tacoma TRD Off Road M/T
    Stock.
    Right there with you. I had a rental Ram last week and there were at least 5 different times where I went to push the "clutch" and either hit the dead pedal or the side of the brake pedal.
  19. Aug 13, 2018 at 6:43 PM
    #8659
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    Oh it is good to know that I am not alone on this.
  20. Aug 13, 2018 at 6:54 PM
    #8660
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    These issues with the throwout bearing, is that also applicable to the 2.7 5spd in the second gen? I notice more of a diesel sound at idle that goes away when I push in the clutch. Also dealing with squeeky pedal heard both by the floorboard and near the slave cylinder.
