Manual shift knob
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobbybreach, Oct 7, 2015.
  1. Oct 7, 2015 at 4:47 AM
    bobbybreach
    bobbybreach [OP] Well-Known Member
    bobby
    westchester NY
    09 TRD
  2. Oct 7, 2015 at 5:03 AM
    vlodpg
    vlodpg Well-Known Member
    Connecticut
    15 Tacoma TRD Off Road 6sp Supercharged
    TRD Supercharger/URD Stage II Clutch
    Maybe this will help:
    Toyota Tacoma Shift Knob
    Gray w/TRD Logo
    6 Speed Manual Trans
    Genuine Toyota® Brand
    Item# PTR26-35060
    Fits the following Toyota Tacoma applications:
    • Engine type: 6-cyl. 4.0L (1GRFE)
    • Transmission type: Manual (6-speed)
    • Tacoma Model years: 2005 2006 2007 2008 2009 2010 2011 2012 2013 2014
    Features:
    • Custom look
    • Features Metal insert w/ 12mm x 1.25 Threads.
    • Upgrade your interior
    • Feel the quality
    • Best design
    If you want a unique look for your interior then check out this Toyota Tacoma shift knob. Give your interior a new rich look with the addition of this quality Toyota shift knob. This new Toyota Tacoma shift knob will feel great as the smooth shape and finish fits comfortably in your hand and adds that personal touch. This top notch quality Toyota TRD shift knob is made from only the best high impact composite plastics.
    Specifications:
    • Color: Gray
    • Finish: Polished
    • Instructions: Included
    • Logo: "TRD"
    • Material: Includes Lock nut to set seating position.
    • Outside Diameter: Outside Diameter = 2-1/4" (57mm)
    • Pattern: Shift pattern engraved in white on top.
    • Thread Size: 12mm x 1.25
    Rexfordian13 likes this.
  3. Oct 7, 2015 at 9:30 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    That would be a big ol' YES right there. :D
  4. Oct 7, 2015 at 4:20 PM
    bobbybreach
    bobby
    westchester NY
    09 TRD
    Great! Thanks for the info!
  5. Oct 7, 2015 at 5:32 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    The 2016 shift boot connects to the shift knob differently than 2nd gen. It has a twist lock connection. I doubt a 2nd gen knob will work, although you can screw it into the shaft.
  6. Oct 7, 2015 at 6:19 PM
    bobbybreach
    bobby
    westchester NY
    09 TRD
    thank you for the pics!
  7. Apr 14, 2016 at 7:43 AM
    godwinaustin
    godwinaustin Well-Known Member
    Jon
    WYO
    2004 4x4 5VZ + 1982 4x4
    Is anyone producing this style yet, that includes the twist and lock attachment? Does this secure the boot only or the shift knob as well?
    So am I right to assume that an earlier shift knob will fit by threading on the column, but will not allow the shift knob to secure to the boot?
    What are the options here?
    winterwolf likes this.
  8. Apr 14, 2016 at 7:45 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    with enough 3m double sided tape or superglue anything is possible :D
  9. Apr 14, 2016 at 7:47 AM
    godwinaustin
    Jon
    WYO
    ha yeah but Im hoping not to mickey mouse it.
  10. Apr 14, 2016 at 8:03 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Another option is to take off the boot, put some rubber bands around the shaft at the desired height, and put the boot back on. That should hold it up.
    RobP62 and Skydvrr like this.
  11. Apr 14, 2016 at 8:11 AM
    godwinaustin
    Jon
    WYO
    Ok so that would at least hold up the boot - and then is the knob itself threaded in the same way as the old one? Or does it only attach via that plastic piece?
  12. Apr 14, 2016 at 8:11 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Now that I am unsure of. I would assume it's threaded on, but I can't say for sure.
  13. Apr 14, 2016 at 11:12 AM
    godwinaustin
    Jon
    WYO
  14. Apr 14, 2016 at 8:41 PM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    It threads on. The snap ring only holds the boot up.
  15. Apr 14, 2016 at 9:14 PM
    godwinaustin
    Jon
    WYO
    Thanks and same threading as the old shifters - 12x1.25?
  16. Apr 14, 2016 at 9:37 PM
    nevadabugle
    Elko, NV
    Not sure about the threads. I am planning on making my own out of an deer Antler so I am curious as well.
  17. Apr 14, 2016 at 10:31 PM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    The shift knob was pretty easy the upper part of the console comes right off just gently pull up on it. You are removing the whole area of the shift boot cup holders and the front face of the console storage bin. As far as the knob and the boot separating you just twist the chrome ring a 1/4 turn and pull down and it comes loose. Then unscrew the knob. The boot for the park brake lever is attached pretty good to the lever and the upper console so rather than risking messing it up I just lifted and twisted the console so I could modify the shifter boot without messing with it. The chrome ring is held on by one zip tie and a small dab of adhesive. Just snip and pull. I slid the boot wrong side out down the shifter and put a heavy zip tie on it then wrapped it in gorilla tape about 3 wraps to prevent the cut end of the zip tie from eating into the boot in the future. Put the console back down and snapped in place. Got the boot tucked and fitted the way I wanted it. Then I put the jam nut on the shifter applied some blue locktite to the threads screwed the knob down where I wanted it. The jamb nut is a 19mm just ran it up aginst it and tightened down while holding the knob.image.jpg
  18. Apr 22, 2016 at 8:26 AM
    seymourless
    seymourless Well-Known Member
    Is your shifter grey or green? With the knob and the boot being lowered it looks amazing, and makes me want to hop on the manual tacoma wagon!
  19. Apr 22, 2016 at 8:41 AM
    RedBeard1
    Red
    Grey... Parked close to the edge of my drive way in that photo I'm guessing the grass reflection is making it look green... Come to think of it I may have been wearing a work shirt ( high visibility yellow).image.jpg
  20. Jun 4, 2016 at 8:57 PM
    scpdgearhead
    scpdgearhead Member
    Thanks for the post I ordered a black knob with orange shift pattern on it has 12x 1.25 treads if I have any further questions I'll ask !
